Confirm/Identify source of front engine 0il leak - BMW Luxury Touring Community
post #1 of 11 Old Apr 25th, 2014, 11:13 am Thread Starter
Hello, Based on these photos, I am guessing the leak source is the timing chain cover, as the oil appears above the water/oil pump. Am I correct on this assumption? Any other possibilities? Thanks for your response.
Doug
ID:	54241   Click image for larger version
MrMartini is offline
post #2 of 11 Old Apr 25th, 2014, 11:20 am
Re: Confirm/Identify source of front engine 0il leak
Doug
Seems like that but I would wash it and let run / drove few miles to confirm the source before starting anything.
Born to be wild so why not
C-A-D is offline
post #3 of 11 Old Apr 25th, 2014, 1:20 pm
+1 What C-A-D says. Really easy to do and you need to clean it up anyway before opening it up. No gasket just sealant IF that is where the leak is coming from.
post #4 of 11 Old Apr 25th, 2014, 1:49 pm Thread Starter
Thanks for the replies. What sealant would you recomend for this application?
post #5 of 11 Old Apr 25th, 2014, 3:57 pm
cbpip's Avatar
Might try Honda Bond HT high temp silicone gasket , need to let set over night before running bike.
76 Honda 750 four-departed
65 Pan head (gone)
72 Rickman 6 day Enduro
BMWMOA # 189093
BMWBMW LOCAL CHAPTER Member
BMW MARS CHAPTER Member
BMWRA # 41568
cbpip is offline
post #6 of 11 Old Apr 25th, 2014, 8:34 pm
That was a common leak in the early LT's. Seems the machining of the covers did not always get the surface flat.
I used Permatex Ultra Black. No need to let it set long before running engine.
Pulling the cover is not a trivial task, as the radiators have to be loosened and moved forward, and the wires to the temp and oil pressure sensors removed from the sensors and threaded through the cover opening. I found it easier to remove the wire connections in the electrical box, as these connections are smaller then the ones on the sensors.
post #7 of 11 Old Apr 26th, 2014, 6:05 am
murray's Avatar
+1 as mentioned ,I would take a shot at retorquing the cover allen bolts. You may get lucky and perhaps the leak is not as bad as it seems.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #8 of 11 Old Apr 26th, 2014, 8:51 am
rowie's Avatar
+1 on the above.
If you end up struggling to find the source after a clean up, run and visual inspection, you can get a dye kit from Autozone. You add a small amount of dye to the oil, run the engine and start inspecting with the UV light. Might help make it easier to see.
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #9 of 11 Old Apr 29th, 2014, 8:44 am Thread Starter
Re: **UPDATE** Confirm/Identify source of front engine 0il leak
I have located the source of oil leak. It appears to be from the channel where the 2 sensor wires emerge from the bottom of the timimng chain cover. Can this be repaired with applying new sealant or is something else involved? Thanks again.
Doug
post #10 of 11 Old Apr 29th, 2014, 9:07 am
That may very well be the front crankshaft seal located in the timing cover. Involves removing the timing cover and not an easy seal to set properly.
Cover must be removed to drive out the seal then install the cover and use special tools to drive in the seal.
But I would still clean the area up to be sure.
post #11 of 11 Old Apr 29th, 2014, 8:41 pm
I agree that it could be the front oil seal. You can check that though by removing the small cover over the ignition timing cavity to see if there is oil in that area. If so, it is the oil seal. If you see that the seal is not leaking, then it is likely the timing cover sealant that is leaking.
What is the best way to break in your new K1600GTL ? DanDiver K1600GT/GTL 7 May 8th, 2011 9:13 am
Gas leak without engine running - 2001 benbob K1200LT 8 Jun 18th, 2010 2:47 pm
Engine head scratcher capnpawkee K1200LT 18 May 1st, 2010 10:00 am
Front and shake/ shimmy front, ... revisited andy K1200LT 12 Jan 12th, 2007 7:16 pm
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 10:48 pm
