Taper Bearing Final Drive - BMW Luxury Touring Community
post #1 of 10 Old Apr 18th, 2014, 6:38 pm Thread Starter
rovero's Avatar
The taper bearing on the crown wheel of my final drive is loose. Anyone know a fix to replace stock taper bearing with one with a smaller inside diameter. Have put green loctite on but do not have much hope that it will hold up. Short of replacing final drive does anyone have any recommendations. Also anyone venture to guess how long I can safely ride without replacing final drive? Presently no wheel wobble or metal in final drive oil. Just a loose taper bearing.
rovero is offline
post #2 of 10 Old Apr 18th, 2014, 7:01 pm
deanwoolsey's Avatar
Re: Taper Bearing Final Drive
http://www.henkelna.com/industrial/p...=8797931667457
Not used it myself, but worth a try if you think your inner race is within limits.
deanwoolsey is offline
post #3 of 10 Old Apr 18th, 2014, 9:18 pm
Have you measured how much material is missing? I had the same thing but I was missing 0.75 mm of material off the spindle. A friend here made me a sleeve out of 1 inch diameter seamless steel tubing. I'll find the post and list it here.
If it is not wobbling on the spindle but you can hand slide it off the loctite sleeve retainer (green) should hold it OK. Just clean it up with acetone and let it cure over night. It takes 400 degrees to break it loose.
Here is the link to my fix.
post #4 of 10 Old Apr 19th, 2014, 7:24 am
K100Dennis's Avatar
I would be very suprised if you have much metal missing from the aluminium trunnion as it is running in oil. It possibly feels worse than it is. Have someone accurately measure the diameter and compare to the bearing inner raceway bore. As JZ mentioned, he had 0.003" (0.075mm) clearance. Loctite retaining compound will take that up. Here in Oz the product number is 690, but there are variations around the world. Prime the (both) surfaces with Loctite Primer T (aerosol can), allow to dry, do not touch the surfaces. Then apply the retaining compound to both parts, slide the bearing on and leave the assembly in a vertical position over night, preferably in a warm environment. Wipe off the excess before assembling the FD unit. As an aside, an old engineering trick, should the wear be too severe, is to knurl the trunnion (in a lathe). This will increase the diameter. Then follow the above loctite preparation steps and push the bearing into place. HTH
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #5 of 10 Old Apr 19th, 2014, 11:32 am
Actually Dennis it was 0.75 mm or 0.029" . No amount of loctite would fix that so I sleeved it. I had not changed the oil in the FD for almost 20 K and there was a wobble I could feel while riding. But you are correct get a proper measurement at a machine shop and a slight knurl would also be in order.
post #6 of 10 Old Apr 19th, 2014, 1:37 pm
The shade-tree version of knurling is a spring loaded center punch. Just carefully mark off some lines equal distance around the shaft with a permanent marker and apply the needed number of punches.
post #7 of 10 Old Apr 19th, 2014, 8:04 pm
K100Dennis's Avatar
Yes Dean, correct. Both methods will work equally well if the total clearance is not too great initially. I've seen plenty of people 'freehand' the centre-punching as well. Used correctly, the loctite will be a permenant solution, actually creating a fit with higher shear strength then the original interference fit. As for JZ's 0.75 mm clearance, now I understand the comment about the s/s pipe sleeve. (I though it was some clever machinist who could spin up a sleeve with 0.00015" wall thickness !)
Dennis
1987 Yamaha TY250R
post #8 of 10 Old Apr 19th, 2014, 9:15 pm Thread Starter
rovero's Avatar
Thanks to all for advise. Thanks to a member of this board who sold me a used drive for Very Very reasonable price, I decided that replacing the drive with the loose taper bearing would be the best solution. I'm going to Have Ted at the beemer shop inspect the used drive and do any adjustments/parts replacements (if needed) then have it installed in my LT.
rovero is offline
post #9 of 10 Old Apr 19th, 2014, 11:11 pm
It was 1 inch OD tubing (25.4 mm) and the inside was turned down to 24.2 mm. So it was 1.193 mm (0.047") thick. Still an impressive feat considering the old lathe he was working with. Even more fun to press it on the spindle. We turned down to the final diameter after it was fix on the shaft with the sleeve retainer Loctite.
post #10 of 10 Old Apr 20th, 2014, 10:33 am
Guest
11862's Avatar
The wall thickness of the sleeve was actually .047 / 2 or .0235 in.
If necessary I still have raw 4130 tubing material & could make up another one, but not a thinner wall! It was a fun challenge tho.
11862 is offline
Poll...How many folks have had final drive problems missusfinz RT Series 126 Aug 16th, 2015 8:59 pm
FD failure. The solution? simon K1200LT 65 Dec 11th, 2008 9:20 pm
Final Drive murray K1200LT 22 Sep 28th, 2008 10:02 am
So what is a final drive worth ? Patric K1200LT 12 Jun 27th, 2007 4:47 pm
Pictures of my "spare" final drive in pieces.. hoodoodrum K1200LT 4 Jun 4th, 2006 10:49 pm
