2009 radio on button - BMW Luxury Touring Community
post #1 of 4 Old Apr 18th, 2014, 4:21 pm Thread Starter
The on button on my radio stays lit. With key off is this normal?
Jim
Jimbo3 is offline
post #2 of 4 Old Apr 18th, 2014, 4:30 pm
deanwoolsey's Avatar
Re: 2009 radio on button
First click from the run position is the accessory position. It will be lit in that position. You can remove the key in that position. Poorly designed. Second position is at about 7:00 and is the lock position which requires the bars to be turned fully left or right. The key can be removed in that position. The button does not light there or in the park position which is about 6:00 and leaves the tail lamp and small marker lamp in the headlamp assembly lit.
deanwoolsey is offline
post #3 of 4 Old Apr 18th, 2014, 6:57 pm Thread Starter
Update. Light went off. Must be on a time delay? Anyway problem fixed it self.
Jim
Jimbo3 is offline
post #4 of 4 Old Apr 18th, 2014, 8:14 pm
Yes it stays on for a while and then goes off. In fact the radio will auto shut down after 2 hours even while riding. This applies to the 05 and up only. There is a setting you can change to keep it on while riding more than 2 hours.
1999 LT Radio Cables Foodle K1200LT 12 Feb 18th, 2011 5:04 am
Radio/CD Problem JohnR K1200LT 22 Jun 28th, 2009 8:43 pm
PTT button for FRS radio ezriderfrank K1200LT 3 May 14th, 2008 4:18 pm
No Radio, No Motolights hschisler K1200LT 15 Oct 3rd, 2007 9:05 pm
