electrical gremlins ate my lunch - BMW Luxury Touring Community
post #1 of 9 Old Apr 18th, 2014, 12:01 am Thread Starter
Well if it wasn,t for bad luck, you know this song . Got the LT rewired with a used wiring harness and a used reverser module. my choices are somewhat slim here in Mexico but i believe the parts were ok.
However, turn the key on, dashboard lights come on, including ABS warning lights, and starter button does not function, turn key off and in fact pull key out of ignition , lights stay on.
From what I read it should be one of the relays and in fact only way to kill lights is to pull the ground from the battery.
We were looking at the wiring again and my friend hit the front brake which made the windshield raise up. If I was not crying it would have been funny. In fact mechanic called BMW in Cancun, told him about it and he did laugh.
So I imagine that my only recourse is to turn it over to BMW and see if the computer will find the faults and be able to fix it right. that will work will it not.
mexicoboy is offline
post #2 of 9 Old Apr 18th, 2014, 12:19 am
deanwoolsey's Avatar
Re: electrical gremlins ate my lunch
Highly unlikely in my opinion that a BMW shop will be able to fix your bike for an acceptable price. I believe you'll be way ahead to part it out and start over with another machine.
deanwoolsey is offline
post #3 of 9 Old Apr 18th, 2014, 1:33 am
fpmlt's Avatar
Curious, after you put a new wiring harness in, what changed, and what remained the same?
fpmlt is offline
post #4 of 9 Old Apr 18th, 2014, 9:49 am
Changing out a partial harness is tough. I had an MGB that suffered a fire and it melted every thing under the hood. I spliced in a year later harness but I spent two days before hand and after verifying every wire went to the correct item. It was a pain but every thing worked the first time. Sounds like that is what you need to do since a brake switch operated the windshield. Either that or just find a complete harness from your model year and install that. Other wise you spend 50-100 hours trying to track down the faults. Sorry man.
post #5 of 9 Old Apr 18th, 2014, 11:33 am Thread Starter
Jzeiler, first off thanks for your patience and help. Mechanic ran complete harness up to the point where it goes forward of the electrical box and thru the frame by the radiator. Here he cut and spliced the forward wires. Noticed today that that does not include ignition switch wires.
most important change is that it does not burn up wiring again LOL. Seriously the difference is the windshield raising up, new helper guy said something was seeking a ground, dunno.
I believe you were correct when you told me starter had hung up , kept running and caused original short, starter will turn over if crossing the starter relay.
My next step as the original mechanic checked all wires for short,s will be to trace the ignition switch wiring and the right multifunction switch.
Where is the main ground for this bile located, other than where the reverser hooks to both ground spots.
Appearance is of a frozen relay and I read one of your earlier posts about how to check them and they seem to be working.
To anybody else, I cannot part bike out, my wife has said no more on another motorcycle purchase. She did not say I could not ship it to the boys in Illinois however LOL.
post #6 of 9 Old Apr 18th, 2014, 10:09 pm
The LT uses wire only for the ground not the frame, so yes a bad ground connection can cause a lot of trouble.
On the windshield all the relays are up on the frame by the motor for the windshield. The inputs from the handle bar are as follows:
1. From the handle bar control; Green wire is power, Blue is lower, Gray is lift.
2. A connector up under the dash or in the relay box; wire colors change to Green/Black, Blue/Yellow, and Gray/Yellow. Same functions.
Don't see how this could ever be related to a brake switch even if a ground was missing. I suspect a cross wiring was done in the junction box where one of the handle bar multi-function switches ties in and the brake light relay as they are side by side. This may help you sort it out. This is where the colors change on the windshield control lines.
post #7 of 9 Old Apr 19th, 2014, 12:14 am Thread Starter
Will check wiring and see how it is, could not get it to work again today but am making progress as now, horn, turn signals, flashers,neutral light. cruise control light,tail lights and brake light are all back.
I may have had a short or burned out wire to the Hall effect sensor which may be causing me some problems. The Clymer manuel is helping as are members of the forum.
Ignition lights and all work fine and when I pull out the relief relay they will go out. That is the only way they will go out however unless I disconnect the ground. As mentioned progress is slow but I am retired so lots of time and I am stubborn so will keep on posting till I ride again.
O bye the way do you want an all expense paid trip to Cozumel Mexico Mr.Jzeiler.LOL joke of course
post #8 of 9 Old Apr 19th, 2014, 1:18 am
mycamel's Avatar
he'll be of no help to you there. i suspect he is more in the prone position than erect at this point. maybe if you put him on a flat board and send him down by train or bus. he'll be of no help since he'll drink his way down. and besides----if he likes it he'll stay and i won't be able to ride over from Atlanta and have him fix my issues (with the bike that is). and you're going to have a large terremoto so he'll have to wait that out! and it's too cold down there!
Mike Hammel (My Camel) [WB9GMO/4]
2002 K1200LT-E
1998 ACE Burgundy (now 'retired')
1998 ACE Yellow/Black Tourer (now 'retired')
19?? Suzuki 500 (now 'retired')
1962 modifed 49cc>~55cc Sears MoPed (LONG 'retired')
US Army Security Agency 0582L68 ('64-68)
moderator and owner:
Retired from the business world (finally--sigh --poor and proud)
Georgia Patriot Guard Riders
Roswell, GA
mycamel is offline
post #9 of 9 Old Apr 19th, 2014, 8:46 am
With issues like this, patience and persistence are 90% of the solution. It sounds like you are well equipped. Just confirm each circuit in turn, both supply and return and you will eventually remove all of the gremlins.
2002 K1200LT Electrical Gremlins and Other Adventures bmwollman K1200LT 15 Dec 29th, 2013 11:16 pm
electrical gremlins oldtimer54 K1200LT 7 May 29th, 2012 12:51 am
Missing bits... cfell BMWLT Site Support Forum 3 Oct 9th, 2007 10:51 pm
Lunch for Five RMoore007 Northern California 8 Dec 31st, 2005 12:27 am
The Sillycon Valley Lunch Bunch Eats Again! DavidTaylor Northern California 0 Dec 13th, 2005 10:43 pm
