J-Peg Highway Pegs - BMW Luxury Touring Community
post #1 of 32 Old Apr 16th, 2014, 12:05 am Thread Starter
bmwollman's Avatar
J-Peg Highway Pegs
Got my new JPegs in the mail today, set out to install them right after work. Took approximately 2.5 hours, mostly spent on modding the black plastic tip over protectors.
First thing is to replace the tip over bar with the new peg mounting bar, and reinstall the chrome plastic piece.
The black plastic piece has to be modded, a template is provided, see photo. Be advised the template is imprecise, holes were off about a quarter inch. When I did the second one, I mounted the plastic back on after I drilled the pilot holes, and was able to mark and redrill more precise ones. The hole saw was a tremendous help. You will have to do some trimming with a blade to complete the fit. I was wishing I had a dremel tool. I think in time I will make a complete cutout, instead of holes, so the plastic can be removed without removing the pegs.
ID:	53377   Click image for larger version
ID:	53385   Click image for larger version
ID:	53393   Click image for larger version
ID:	53401   Click image for larger version
ID:	53417   Click image for larger version
ID:	53425   Click image for larger version
ID:	53433   Click image for larger version
[SIGPIC][/SIGPIC]
bmwollman
02 K1200LT
bmwollman is offline
post #2 of 32 Old Apr 16th, 2014, 12:14 am Thread Starter
bmwollman's Avatar
Re: J-Peg Highway Pegs
Unfortunately I didn't photograph the detent system installation. The orange tape covers a hole with a spring in it. You leave the tape in place until you finish the cover mod and are ready to install the peg, then remove it. It's also held in by a gob of grease. I added an additional gob of grease and stuck the ball bearing to it, then threaded the peg bolt and the silver sleeve pressed the ball bearing into the hole with the spring. Two screw holes in the surface of the silver sleeve act as detents for the open and closed positions.
ID:	53449   Click image for larger version
ID:	53457   Click image for larger version
[SIGPIC][/SIGPIC]
bmwollman
02 K1200LT
post #3 of 32 Old Apr 16th, 2014, 12:15 am Thread Starter
bmwollman's Avatar
Here's some photos of the finished product.
ID:	53473   Click image for larger version
ID:	53481   Click image for larger version
ID:	53489   Click image for larger version
[SIGPIC][/SIGPIC]
bmwollman
02 K1200LT
post #4 of 32 Old Apr 16th, 2014, 6:08 am
JNW003's Avatar
Hi Brian, thanks for the pictures on your installation. Just out of curiosity, had you been able to take any longer rides on your '02 before deciding to get the J-pegs (not sure how long you've had the bike since you joined the group in the dead of winter and live in Colorado). Also, are you running a stock seat? I have an RDL and it provides a very comfortable riding position, even without the J-pegs and floorboards others have installed on their rides. The stock seat was a real pain last summer when I rode out your way - I was squirming, standing, and moving my legs all over just to get comfortable and thought about getting some J-pegs, but now I'm not sure they'd be worth the additional expense, since I got the RDL.
JNW003 is offline
post #5 of 32 Old Apr 16th, 2014, 8:50 am
What is the RDL ?
Jim
Jimbo3 is offline
post #6 of 32 Old Apr 16th, 2014, 9:15 am
timgray's Avatar
Note: be sure to clean up the detent and clean re-grease it every few years. Mine are so jammed with road gunk that I had to dig everything out and spent 10 minutes in a parts washer to clean everything up and reassemble again. The grease felt like it was more grit than grease.
timgray is offline
post #7 of 32 Old Apr 16th, 2014, 9:52 am
TeddyTelco's Avatar
I'm guessing Russell Day Long seat
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
post #8 of 32 Old Apr 16th, 2014, 12:18 pm
JNW003's Avatar
+1 for TeddyTelco!
JNW003 is offline
post #9 of 32 Old Apr 16th, 2014, 12:23 pm
copperstatetour's Avatar
Thanks for the write-up, I picked up a second hand set of j-pegs last year (which I still haven't had a chance to install ) and so I am at the disadvantage of not having instructions or a template. Seemed pretty straight forward to me, but this write-up will help me out I am sure. Now to find time...
-Steve
2009 BMW R1200RT
2000 BMW K1200LT (was supposed to be replaced by above, but can't keep above running long enough to replace
2000 BMW R1200C
copperstatetour is offline
post #10 of 32 Old Apr 16th, 2014, 12:24 pm
Correct: http://www.day-long.com/gallery_BMW.html
-Steve
2009 BMW R1200RT
2000 BMW R1200C
post #11 of 32 Old Apr 16th, 2014, 11:07 pm Thread Starter
bmwollman's Avatar
I'm not sure what seat I have, I think it's an upgraded one, and it's very comfortable, but when I started riding the bike I found that after an hour or so my legs started screaming for a stretch, so I thought these would be the answer. Today I rode to work to try them out. They are up high, so it's quite an effort to get my feet up on them, and then I didn't really feel stretched anyway. They're definitely not the same laid-back feeling as my Harley ones. The web site said they have extended ones for over six footers, I am 5' 11", so I got the regular, but after trying them I think maybe the extended ones would be a better fit. I might contact them about an exchange. Hopefully, they'll give me some relief on extended rides.
I've attached the instructions and template for those of you with used ones that you need to install.
[SIGPIC][/SIGPIC]
bmwollman
02 K1200LT
post #12 of 32 Old Apr 17th, 2014, 12:19 am
Gruivis's Avatar
I'm 5 11 and have the XL Jpegs, they fit nicely and allow a good stretch.
Looks like you ended up with an excellent install. After my install there was a 1/4" gap between the bumper cover and the trim piece. One day I'll order another bumper set and see if I can't eliminate that gap.
Airwolf - 2018 K1600GTL (planned acquisition!)
2005 Charcoal LT - 48K
2003 Antracite LT - 76K
2001 R1200C 24K
1999 Honda Magna - 5K (RIP)
Gruivis is offline
post #13 of 32 Old Apr 17th, 2014, 12:35 am
JNW003's Avatar
Hi Brian again,
Could you post a picture of your seat? I'm curious how it looks, as my initial reaction after I got the bike was that the seat was comfortable too, but on trips over an hour or so, my bottom rebelled and legs couldn't get comfortable. My new seat cured all of that.
JNW003 is offline
post #14 of 32 Old Apr 17th, 2014, 6:13 am
deputy5211's Avatar
The JPegs tend to give me cramps in my hips.
Try the Mick-O-Pegs. They have a more natural position. You can buy a kit to add them to your JPegs, or I can sell you my combo kit and you can recoup some of the cost by selling your existing JPegs.
Email me at aol.com if you want to discuss further.
Antony (Tripod)
Dallas' Northern Suburbs
and many, many others.
deputy5211 is offline
post #15 of 32 Old Apr 29th, 2014, 11:52 pm Thread Starter
bmwollman's Avatar
Smile Re: J-Peg Highway Pegs
Well, I got my replacement JPeg XL pegs today, installed and tried them in the garage, and I gotta say my initial reaction is PERFECT. They are much easier to get my feet up on, and feel much more relaxed and stretched than the standard ones. They do not feel nearly as high as the standard ones. My knees are slightly bent, and my calves are lightly resting on the black tip over covers. Hips feel great, were cramped on the standard ones. It's really an amazing difference from the standard size, I didn't expect this, very pleased. They feel similar to the highway pegs on my Harley. This is what I was hoping for when I ordered them initially. Again, I am 5' 11", 33-34 inch pants. The company (ascycles.com) gave me a free exchange. I guess I gotta pay for shipping back the old ones. Pardon the darkness of the photos, it's nightime.
ID:	54681   Click image for larger version
ID:	54689   Click image for larger version
ID:	54697   Click image for larger version
ID:	54793   Click image for larger version
[SIGPIC][/SIGPIC]
bmwollman
02 K1200LT
post #16 of 32 Old Apr 30th, 2014, 12:10 am Thread Starter
bmwollman's Avatar
JNW003, Here's a photo of my seat - I don't know if it's stock or not. It does get uncomfortable after an hour or so. Any suggestions on an upgrade? The heater is broken, so I don't have any problem getting rid of it.
[SIGPIC][/SIGPIC]
bmwollman
02 K1200LT
post #17 of 32 Old Apr 30th, 2014, 4:29 am
JNW003's Avatar
Hi Brian, thanks for posting a picture of your seat. That isn't a stock one and I'm not sure of what make it is, but know it's not a Russell Day Long like mine. The backrest is also aftermarket, maybe a Bak-Up backrest? The problem you would be faced with in upgrading the seat is that most of the aftermarket companies won't work on one that has already been modified (i.e., Russell won't use your seat pan if it had been modified by Rick Mayer, Corbin, or some other brand). You may have to buy a spare seat pan for your '02 to have them modify it. Another option would be to try an aftermarket covering that many people are happy with at a fraction of the cost of a new custom seat. Here's a picture of my RDL with it's matching RDL backrests. I ordered the RDL with leather seating surfaces & vinyl sides; the RDL backrest; and had the pillion seat & backrest recovered to match. Hope this helps!
JNW003 is offline
post #18 of 32 Old Apr 30th, 2014, 9:19 pm Thread Starter
bmwollman's Avatar
That is a cadillac looking seat there. I think mine is a BMW upgrade option.
[SIGPIC][/SIGPIC]
bmwollman
02 K1200LT
post #19 of 32 Old May 1st, 2014, 1:34 am
deputy5211's Avatar
Originally Posted by Jimbo3 View Post
What is the RDL ?
Jim
Russell Day Long
Antony (Tripod)
post #20 of 32 Old Jan 30th, 2015, 10:05 am
Louis's Avatar
I have that seat also ... I think the tag under says Millers seat heat works fine i can get you the number if you want
Louis is offline
post #21 of 32 Old Jan 30th, 2015, 11:06 am
Louis's Avatar
what is your final review on these pegs ! I`m concerned with the durability . Are they still as strong ?
Any rattles ?
Any negative feedback would be appreciated. The cost to import to canada is very high
Thanks for your reply
Louis
Louis is offline
post #22 of 32 Old Jan 30th, 2015, 4:25 pm
james216's Avatar
I used the dremel on mine.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #23 of 32 Old Jan 30th, 2015, 5:44 pm
CharlieVT's Avatar
I have a set of J-pegs. Standard, not the extended ones. I found I don't use them very much.
I'm in the process of putting the bike back together; I'll ship 'em to anyone who wants them for 250$.
I can swap out tip over wing covers too since mine already have the cutout for the J-pegs.
Offer to be withdrawn as soon as I get the bike back together.
Send me a PM on this site if interested.
CharlieVT is offline
post #24 of 32 Old Jan 30th, 2015, 9:17 pm
gbaltyn's Avatar
PM sent.
gbaltyn is offline
post #25 of 32 Old Jan 31st, 2015, 2:50 am
Louis's Avatar
Ok But what is your final user review
thanks
Louis
Louis is offline
post #26 of 32 Old Jan 31st, 2015, 6:04 am
norton's Avatar
My bike had the J pegs when I bought it and they are way to high and hard to deploy. The Mick o pegs look to be a more comfortable option unfortunately they are much less attractive so I now just stop and stretch when the body starts to hurt.
norton is offline
post #27 of 32 Old Jan 31st, 2015, 7:57 am
CharlieVT's Avatar
Any rattles ?
Louis
I've had J-Pegs on my bike for 70-80K miles.
Deployment: they can be deployed with the tip of a toe or by reaching down with a hand. Either way is a little bit of a stretch, but it's okay.
Retraction I always did with the heel of my boot.
Remember to retract them before stopping; there have been reports that things don't go well if they are deployed and you drop the bike.
Rugged: no rattles, plenty strong. No noticeable flexing when using the J-pegs to push yourself back in the seat.
Esthetics: they tuck out of the way unobtrusively when retracted.
Comfort: The position is a little high, which is why lots of folks opt for the Mick O Pegs. I am 5'10" and have the standard J-Pegs. I found that when using the J-Pegs I'd push back in the seat and lean back against my BackUp back rest, sort of slouching as in a recliner. It provided a nice change on long rides, but isn't the most natural riding position.
Durability and maintenance: J-Pegs are a rugged design but will collect road grime. I only cleaned them every 12K or so when I had the bike apart for 12K BMW "Inspection". I ride lots of dirt and gravel roads, my bike gets as dirty as any; while the J-Peg spring and ball assembly got plenty dirty they never became resistant to deployment. (Unlike the side stand which I find will bind up and need greasing more frequently).
I tested a set of Mick O Pegs: I found the riding position a little more relaxed. Reportedly the MickOPegs are very strong but they did flex under load when pushing against them.
And while I am in favor of "form follows function", I thought the MickOPegs looked funny.
That said, the combo of J-Pegs and MickOPegs is probably the best of both worlds for the long distance rider looking to stretch out. I never did it, but it is possible to add the MickOPegs to previously installed J-Pegs.
post #28 of 32 Old Jan 31st, 2015, 8:47 am
james216's Avatar
I like mine. I am 5'8" I find them easy to use. Deploy and retract with my boot tip. I also find them sturdy & rattle free. I use them to stretch out but am never on them longer than 20 minutes at a time. I trade positions between pegs and upright factory mounts. It does help. You do slouch a bit using them. But that's not bad.
I'm a 4 percenter.
james216 is offline
post #29 of 32 Old Jan 31st, 2015, 2:07 pm
Louis's Avatar
Thanks for a ll your great comments. It will help
Louis
Louis is offline
post #30 of 32 Old Mar 27th, 2019, 9:34 pm
Thanks for the great photos of the installs. I was handed a set of parts this weekend and it didn't make sense until I saw I'm missing parts. I think I can cobble together what's needed.
bruincounselor is offline
post #31 of 32 Old May 4th, 2019, 11:26 am
Reached out to CVM (CVM Touring Accessories - BMW Motorcycle Highway Pegs) and Jerad responded in a few days asking for photos of the set. He said he could fix them up if I sent them in. They were returned with some new machining on the old mounts and new hardware and work great.
Hats off to CVM and Jerad!
post #32 of 32 Old May 6th, 2019, 5:29 pm
I have Jpegs XL and mick o pegs,I use them both mick o pegs hit ground when cornering.
I also have oem peg lowering mounts.
If I could only have one, it would be the oem peg lowering mounts
red85k100rs is offline
Highway Pegs on my K1200S Ric_Holder Other K-Bikes Discussion 2 Oct 30th, 2014 12:49 am
Highway Pegs markmoloney K1200LT 8 Oct 18th, 2011 1:52 pm
Which highway pegs for Touratech engine bars? rdg238 RT Series 7 Jul 25th, 2011 10:04 am
Highway Pegs Steveb1959 North West 8 Feb 17th, 2011 4:21 pm
Highway pegs and GS style cyl guards jrhSeattle RT Series 1 Apr 2nd, 2010 8:13 pm
