RCRG replacement bushes for paralever trunnion pivots - BMW Luxury Touring Community
post #1 of 5 Old Apr 15th, 2014, 8:43 pm Thread Starter
K100Dennis's Avatar
I need to replace the tapered roller bearings in the paralever trunnion pivots. Some here have used the Rubber Chicken Racing Garage bushes already, any comments regarding the product ? The tapered roller bearings are doomed to failure in this application as they do not rotate as designed, the killer being false brinelling which presents as the "notchy" feeling.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #2 of 5 Old Apr 15th, 2014, 10:47 pm
Re: RCRG replacement bushes for paralever trunnion pivots
I have been running them for 45,000 miles and love them. Never a notchy feel at all and they don't get loose over time.
post #3 of 5 Old Apr 30th, 2014, 1:30 pm
cbpip's Avatar
What should be the labor time to switch out the OEM bushing with the RCRG Paralever bushing. Anything special required to make the switch ?
76 Honda 750 four-departed
65 Pan head (gone)
72 Rickman 6 day Enduro
BMWMOA # 189093
BMWBMW LOCAL CHAPTER Member
BMW MARS CHAPTER Member
BMWRA # 41568
cbpip is offline
post #4 of 5 Old Apr 30th, 2014, 5:35 pm
Enjoy The Ride
saddleman's Avatar
All the right FD pivot pin bearings end up getting notches in them. So what set the preload & forget about it. It is nothing to worry about. The only time I replaced mine was when the swing arm filled up with water because a dealer didn't get the front boot on right. It is now 135,00 miles later & they have notches in them & I won't replace them just because of a small notch.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #5 of 5 Old Apr 30th, 2014, 5:54 pm
I know the ones on My k1100 were a bit notchy but I could not feel it and the LT is 250 lbs heavier so I do not expect to feel it - loose falling apart yes but slightly worn no
I adjust them by feel, same as swing arm, never had a problem with the other two and so far not with the LT
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
