CB install help with antenna ideas - BMW Luxury Touring Community
post #1 of 10 Old Apr 15th, 2014, 7:36 pm Thread Starter
james216's Avatar
I just got a J&M CB model 2003. It comes with a nice antenna. As all of you know. Antennas aren't the easiest to mount due to the weird antenna mount. So. Has anyone come up with an alternative or am I stuck having Fabricate something or to buy the BMW CB mount and mast for $200.00 +
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #2 of 10 Old Apr 15th, 2014, 8:41 pm
deanwoolsey's Avatar
Re: CB install help with antenna ideas
I bought one that is designed for through-the-glass use and installed it just above the right saddle-bag trim and just in front of the rear corner. Works fine and the mast bumps the vinyl trim around the speaker.
deanwoolsey is offline
post #3 of 10 Old Apr 16th, 2014, 6:24 am
FatStrat's Avatar
Look around for a used OEM mount. Awhile back I posted on this forum that I was looking for one. Sure enough, a member of the forum had one and I bought it. I had to get creative with the coax and mounting of the Frances' antenna, but it has the "stock look" about it and works perfectly.
Friends know the song in your heart, and can sing it to you when you have forgotten the words.
FatStrat is offline
post #4 of 10 Old Apr 16th, 2014, 6:53 am
I bit the bullet and bought the BMW mount and mast as I wanted to match the existing radio antenna. Expensive, yes, but looks nice and no point in putting a scab on an expensive machine just to save $200. Might find a used one and save some money and still have the factory look.
post #5 of 10 Old Apr 16th, 2014, 8:49 am
I made a mount from a commercial CB mount I had found. It was a flat plate about 10 inches long with a rounded end. I took a chance that it was 5052 aluminum and that I could bend it. It was and this is the end result. That last one it what it started out as.
ID:	53513   Click image for larger version
ID:	53521   Click image for larger version
post #6 of 10 Old Apr 16th, 2014, 4:08 pm Thread Starter
james216's Avatar
That's exactly what I had in mind. I got T6511 aluminum flat stock at work 1/4" thick or 1/8" Just don't know if I can bend it without cracking. The mount you used. Did you have to drill the bolt holes? Or did you get that lucky that they lined up?
I'm a 4 percenter.
james216 is offline
post #7 of 10 Old Apr 16th, 2014, 4:42 pm
My specialty is not materials, but I think that may not bend with out cracks. Try a piece and see. I do know that some will bend smoothly and some will show stress cracks in the radius. My engineering handbook is in my desk at work and I am at home for a while.
post #8 of 10 Old Apr 16th, 2014, 5:52 pm
timgray's Avatar
That is fantastic!
timgray is offline
post #9 of 10 Old Apr 16th, 2014, 6:56 pm Thread Starter
james216's Avatar
I'm going to try flat stock steel. Any guess the thickness of your bracket?
I'm a 4 percenter.
james216 is offline
post #10 of 10 Old Apr 16th, 2014, 9:51 pm
My aluminum was 3/16 thick but I would try a piece of aluminum from your work first before it went with steel. If you do go with steel 1/8 would most likely work best.
Where to install a radio antenna?? PerfectSwitch K1200/1300GT (The Next Generation) 0 May 2nd, 2008 11:25 am
Sirius Sportster 5 Install rab1967 Satellite Radio 4 Mar 13th, 2008 9:22 am
Antenna Help NascaLT K1200LT 5 Jul 29th, 2006 9:28 pm
Holiday Gift Ideas RVB1019 K1200LT 6 Nov 2nd, 2005 10:13 pm
CB antenna mount location ideas k12ltcdodrt Other R-Bike Discussion 0 Oct 17th, 2005 2:10 pm
