Front brake line burst - things to look for. - BMW Luxury Touring Community
post #1 of 11 Old Apr 13th, 2014, 9:02 am Thread Starter
timgray's Avatar
While I have the bike apart for service, I was wondering if there is any tell-tale signs of the front brake line is getting closer to failure and should be replaced?
They both feel fine and are flexible, I dont see any cracks although one is bent more than the other.
timgray is offline
post #2 of 11 Old Apr 13th, 2014, 9:22 am
Re: Front brake line burst - things to look for.
Age. If 10 or more years old, replace for sure. 7-10 is a judgement call. Mine turn 7 this year so I am starting to look at Spiegler and other options.
post #3 of 11 Old Apr 13th, 2014, 9:40 am
smahon's Avatar
If either of the short pieces of brake hose are bent in a U shape rather than straight, you are near failure. That bent line shouldn't be. Eventually, it will burst.
'15 GTLE
smahon is offline
post #4 of 11 Old Apr 13th, 2014, 9:55 am
14wntr's Avatar
Brake lines are not something to leave unchanged. Change them now. you are overdue
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #5 of 11 Old Apr 13th, 2014, 10:27 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Plus 1
Better to do it with the bike already apart.
Click Here
Stevie Shreeve
katnapinn is offline
post #6 of 11 Old Apr 13th, 2014, 11:46 am Thread Starter
timgray's Avatar
This right here needs to be in a "Things you MUST look for" document in the Tech section.
I am assuming they are stock as none of the PO documents show that they were ever replaced and one of them has a slight U shape to it as can be seen in the photo.
Ordering replacements right now.
Anything to watch for in replacing them? tricks to make replacing them and then flushing easier so I dont get air in the system?
timgray is offline
post #7 of 11 Old Apr 13th, 2014, 12:17 pm
Oh if you replace a line you will get air in the system. There are some tips to keep the amount of air that actually gets to the ABS unit to a minimum. On the control circuits you want to push fluid (syringe and hose) from the ABS bleed port up to the reservoir, rather than the other way around for a flush. This will minimize the amount of air introduced into the unit. Run the fluid down to the end of the hose before you put it on the bleed port.
The wheel circuits are a piece of cake. You start out with full reservoirs and you then push fluid out to the calipers with the pump. Just keep the reservoirs full and once you get some fluid at the caliper, you can use a long hose from there back to the reservoir and pump until the hose is free of bubbles.
post #8 of 11 Old Apr 13th, 2014, 12:24 pm
deanwoolsey's Avatar
I was stubborn and just replaced one at a time until I had done four of them. Order the Spieglers and be done with it. When replacing the front lines, break the system open where the master cylinder line enters the hard lines on the steering head. This will allow you to drain the master cylinder line and caliper lines without getting air into the ABS unit.
deanwoolsey is offline
post #9 of 11 Old Apr 13th, 2014, 12:31 pm
Scouter-50's Avatar
Search for Spiegler install by Scouter-50. I got tons of great advise from everyone. Saddleman told me about cutting down a 6mm hex key so that nothing major had to be removed from the handlebars and Dean Woolsey told me the proper order to remove the hoses. I don't know how to link that post to this one so all I can say is search. It was not a difficult job to complete, just a little time consuming.
P.S: Speedbleeders are wonderful.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #10 of 11 Old Apr 13th, 2014, 12:46 pm
johnT's Avatar
Tim,
I just had one burst on my 2002 .... no obvious signs of cracking or deterioration...
like others have said, your probably overdue.
if your gonna replace the entire brake line sytem, start on a friday and don't plan on getting done until sunday....
seriously, it's a maze.
but not impossible... just time consuming.
johnT is offline
post #11 of 11 Old Apr 13th, 2014, 2:42 pm
zippy_gg's Avatar
I just had a right front line failure on my 05. Replacing with new technology material at a much lower cost than BMW of course. A local company in Northridge is making custom hydraulic lines for the LT for West Valley Cycle BMW, the cost is comparable to Spiegler but I will get the lines in a couple of days. Based on the feedback I read on this forum I ordered the BMW copper washers for the banjo connections. Then of course I will not only bleed but also flush the entire system while I am there, using John Z's video . The clutch was bled a few months ago when I replaced the clutch and slave cylinder.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
2010RT Front Brake cessna RT Series 20 Sep 15th, 2014 4:43 pm
Brake Line Number Three deanwoolsey K1200LT 9 Oct 25th, 2012 10:53 pm
The Front Brake FrankNitti K1200LT 23 Oct 19th, 2012 12:38 am
front brake line ...grrrrrr ! wolfflow K1200LT 0 Aug 12th, 2011 4:46 pm
Front Brake ?'s Ekim K1200LT 18 Feb 1st, 2007 7:35 pm
