stowage compartment wont open - BMW Luxury Touring Community
post #1 of 10 Old Apr 12th, 2014, 5:50 pm Thread Starter
Otto27's Avatar
I cannot get the front stowage compartment lock to open/unlock. Key turns in lock but when I push on it it will not open? Any ideas?
thanks
Bill
1973 B!W 75/5 lwb 1979-2006 60000 miles great bike should not have sold it
1989 BMW GS didn't like it 2006-07 sold it
1971 BMW 75/5 remembered that old school was not that comfortable sold it
2005 LT bought it on a lark and I like it. 2012
Otto27 is offline
post #2 of 10 Old Apr 12th, 2014, 6:14 pm
Re: stowage compartment wont open
Press hard on the cover while cycling the FOB. If it is locked with the FOB the key will not open it. These only jam when some one has installed too long a screw on the gray tongue of the stingray on the left side of the lock. The screw can jam the actuator. After a few cycle of lock / unlock smack the lock with the palm of your hand and it should open.
post #3 of 10 Old Apr 12th, 2014, 6:50 pm Thread Starter
Otto27's Avatar
Thank you jzeiler. I tired it a couple of time without success but will give it a shot again after my cast sets. Just kidding but it is pissing me off. You are correct I was playing around with locking the bike with my fob which I never use. Everything else unlocks but not the storage compartment. After your post I listened while cycling the locks with the fob and I can hear the mechanism trying to work the lock of the compartment but with no success. Maybe tomorrow. Thanks again
Bill
Otto27 is offline
post #4 of 10 Old Apr 13th, 2014, 11:26 am
When you do get it open this is the screw that needs to be very short.
Name:	Short Screw.JPG
post #5 of 10 Old Apr 13th, 2014, 2:50 pm Thread Starter
Otto27's Avatar
Finally got it open, kept cycling the lock via fob with no success and then pried at locking bar with small screw driver while cycling lock and it opened. Removed the two screws on either side of lock which appeared to never been removed. Both were the same at 1" in length. Lock works fine using key, don't think I will use the fob again if stowage cover is closed.
Bill
Otto27 is offline
post #6 of 10 Old Apr 13th, 2014, 3:05 pm
If both are the same length, then they have been removed and the short one lost.
I thought I could find it in the fiche, but no luck yet. The lock works fine with the fob as long as it is assembled correctly with a short screw on the left side.
post #7 of 10 Old Apr 13th, 2014, 5:18 pm
Those screws look to be M5x20 flanged button heads which were not originally fitted to that position. Find yourself an M5x10 socket button head screw for the left and a M5x12 or M5x16 of the same type for the right side at a hardware store. It will probably not have a Torx socket head but a standard hex socket head, which should be OK as long as you have the right wrench. Keep the two 20mm screws as spares, they are used all over the fairings. You may need to cycle the lock a few times to clean the lock pin where the tall screw caused an imperfection.
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #8 of 10 Old Apr 15th, 2014, 7:20 am
FatStrat's Avatar
When I was putting the plastic back on after a repair, I couldn't remember which side the short screw went on. I removed the catch from the glove box door and inserted it into lock mechanism. If it failed to release with the FOB, with the door not being in the way, I could just back out the screws and switch them.
Friends know the song in your heart, and can sing it to you when you have forgotten the words.
FatStrat is offline
post #9 of 10 Old Aug 8th, 2016, 4:52 am
ian
Just a quick note to endorse this response.
Stowage compartment lock worked perfectly untill the LT returned from the dealer for an unrelated clutch repair.
I reduced the length of the screw in question by adding two washers to it and now seems to be working just fine.
Makes absolutely no sense as to how this could have effected it but seems to be the answer albeit early days as only made the adjustment last night - here's holding thumbs.
ian is offline
post #10 of 10 Old Aug 8th, 2016, 7:57 am
It will once you know that the actuator rod from the actuator (circled in yellow) passes directly under that screw (red). A long screw will bear down on the rod and jam it up.
Tags
stowage compartment
Top 50 BBQ Joints In Texas Lonewuff South Central 35 Dec 18th, 2013 9:26 am
Open face helmet P-Smity Rider's Gear & Luggage 16 Apr 18th, 2013 11:28 am
how to open the K1200lt seat bikerj K1200LT 15 Apr 11th, 2013 4:48 pm
Front Compartment merk1106 K1200LT 16 May 29th, 2006 8:37 am
