ABS Pump Running Intermittently with key off - BMW Luxury Touring Community
post #1 of 10 Old Apr 12th, 2014, 5:20 pm Thread Starter
Question ABS Pump Running Intermittently with key off
The bike is a 2009 LT. When I turn the key off and hit the front or rear brake the abs pump activates just like when the bike is running. The other problem is the pump will turn on at any time and drain the battery. I borrowed a GS911 and found I have a code 17919 (Fault Occurred during recognized voltage drop). Does anyone know what causes this code or had this problem? It almost sounds like a relay is not releasing. I asume the relay is internal to the ABS module?
ben_jerry is offline
post #2 of 10 Old Apr 12th, 2014, 7:02 pm
Re: ABS Pump Running Intermittently with key off
Unfortunately there are no relays involved in powering the ABS unit. The main power to feed the unit is on a line from the battery and alternator. This is constant power. The unit should not "wake up" until switched power is applied so either you have a problem with your switched power circuits or a problem with the ABS unit.
If you are up for some troubleshooting and have a meter you can pull the big connector on top of the ABS unit and find both pin 5, with a Gray/Black wire, and pin 3, with a green wire. These are the two switched power leads at the unit. There should be no voltage here with the key off and voltage should be there only in the on position. It is a starting point.
post #3 of 10 Old Apr 13th, 2014, 4:17 pm Thread Starter
As you suggested I checked 5, and pin 3. Key on 12 volts. Key off 0 Volts. I thought it was fixed when I re-installed the abs connector back on the module. Everything appeared normal. Came back into the garage 1/2 hour later I could hear the pump running on it's own.
I'm thinking of having the pump rebuild. Is that a good idea or should I go new ? Will I be able to bleed the system on my own once I have the abs module repaired or will it require dealer service? I've changed the fluid myself for the last three years. This is the first year I didn't change fluid due to the fact I only put 3000 miles on the bike. Thanks you very much for the info. Kind of thought it was the module but wasn't really sure.
post #4 of 10 Old Apr 13th, 2014, 10:37 pm
I don't know of any shops that have successfully rebuilt this version of the ABS module. So your choices are limited. I guess one more thing you could do to isolate it to the unit is to apply 12 volts to the pin 2 connector pin ON the unit itself. This would simulate the unswitched power and no other inputs to the ABS and if the pumps run again you will have a positive answer that the unit is bad. It can be a small wire that will open like a fuse if the pumps run.
post #5 of 10 Old Apr 14th, 2014, 8:49 am Thread Starter
I took the connector off the ABS applied power to pin 2 nothing happened. Placed the plug back on the ABS module connected the battery the bike starts up normal ABS appears to be working normally. Shut the bike off hit the brake and you can hear the servo working. I believe what BMW changed was an ABS relay for a FET(Field Effect Transistor) to save money. I can ride the bike and the ABS appears to be working normal. www.modulemaster.com appears to have a rebuilt unit available in June of 2014 or I may call MAX BMW where I bought the bike and see what they'll charge for a ABS Module. If I do take out the ABS unit will I be able to bleed the system? I realize if it's possible it will require a number of repetitions from front to back brakes to get all the air out of the system. I've replaced all the lines on a Ford F150 pick up with ABS but this system is entirely different. Again thanks for the help.
post #6 of 10 Old Apr 14th, 2014, 1:37 pm
It is not a difficult process to bleed the unit when you replace it. There are three ports each for front and rear control circuits on the ABS unit and you have to cycle through the three is specific order doing the first one a second time.
The wheel circuits are a snap to do as you use the pump motors to move the fluid out to the calipers.
Not sure what relay the dealer changed as there are only two associated with the ABS and they are the warning relay and the brake light relay and they are all driven by the ABS unit.
That is good news from Module Masters (but we have heard it before). The main issue is parts availability since BMW never intended to repair the units.
post #7 of 10 Old Apr 14th, 2014, 7:25 pm Thread Starter
Where the short appears to be intermittent I decide to run a fused 12 volt supply to pin 2 with the connector off and the battery connected. I used a 1.6 amp fuse as I was afraid of the leads heating up and causing a fire if I wasn't around. I sat and watched the fuse for 5 minutes. The fuse did not blow. Went back in the house and above a 1/2 later checked the fuse. It was blown! Looks like the ABS module is defective. The good news is Tyler at modulemaster.com said he can fix the electronics. The electronics can be separated from the module and sent out for repair. I'll keep out informed of the results.
Thanks for the help
post #8 of 10 Old Apr 14th, 2014, 10:45 pm
That is good news. Keep us posted on how they do.
post #9 of 10 Old May 6th, 2014, 7:37 pm Thread Starter
Smile Re: ABS Pump Running Intermittently with key off
Update just finished installing the ABS pump and it works like a charm! Having sent just the circuit board to Tyler at Modulemaster.com they discovered corrosion of the circuit board which was the cause for the pump to run intermittently. Four screws separate the electronics from the pump. The cables to the pump are all plastic connectors that can be easily removed. I would definitely separate the two before I purchased a new ABS pump.
Before I sent the circuit board to ModuleMaster.com I did see a trace of corrosion on the board. I'm still amazed that was my problem. Thanks for all your help
post #10 of 10 Old May 6th, 2014, 7:52 pm
That is good news and I will file this data away for future reference. Yes the board is quite easy to remove so that should be a "go here first" rule when strange behavior is noted in the unit.
Name:	Electronics internal board 6.JPG
ID:	55537   Click image for larger version
Trading Harley on an LT today WillieC K1200LT 25 Jun 18th, 2012 11:13 am
My Father purchased 2002 K1200LT with 7000 miles the abs pump stays on all the time Autodeal1 K1200LT 6 May 2nd, 2012 7:02 am
2000 K1200LT ABS unit disassembly CharlieVT K1200LT 13 Sep 11th, 2011 3:40 pm
ABS Brake Problem JeffB K1200LT 4 Jun 16th, 2010 9:36 pm
ABS Pump Staying On - Why? kevincook K1200LT 8 May 22nd, 2008 10:02 pm
