How to remove the fairing nose piece - BMW Luxury Touring Community
post #1 of 11 Old Apr 11th, 2014, 8:19 am Thread Starter
timgray's Avatar
I need to fix my headlight adjuster, and I can not for the life of me fine any info on removing the nice piece. the bike is undressed except for that and it is acting like there are two screws still holding it on.
timgray is offline
post #2 of 11 Old Apr 11th, 2014, 9:14 am
rhawk's Avatar
Re: How to remove the fairing nose piece
Have you got the grey piece off that covers the windshield brackets?
Rand & Susan Hawksworth
2000 K1200LT
rhawk is offline
post #3 of 11 Old Apr 11th, 2014, 9:24 am Thread Starter
timgray's Avatar
Ahh so there are screws under that.
So now to figure out how to remove the grey cover...
timgray is offline
post #4 of 11 Old Apr 11th, 2014, 9:36 am
rhawk's Avatar
There's a hidden screw under the aux dashboard light. Be careful not to drop the screw! You also may have to move the windshield brackets a little.
2000 K1200LT
rhawk is offline
post #5 of 11 Old Apr 11th, 2014, 10:00 am
hallzee's Avatar
+1... That's the one that "gets everyone". Remove the auxiliary dash light with a flat blade screwdriver, and you'll see it up under there.
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #6 of 11 Old Apr 11th, 2014, 10:07 am
dvgb131's Avatar
That's been posted a few times. They un-snap.
Put pressure from outside edge toward center and peel up inside edge.
Apparently they make a loud snap.
I'll be doing the same maintenance (for the first time,)you describe in your other thread very soon.
Good luck on yours.
Doug B.
2000 LT purchased July 2013
dvgb131 is offline
post #7 of 11 Old Apr 11th, 2014, 10:19 am
tconnell's Avatar
Tim, If you haven't done so yet... remove the dash/map light by inserting a small flat bladed screwdriver in the left hole and popping that light out. Behind it is a T25 screw that has to come out. Will help to have a small flash light to illuminate in there. Careful not to drop the screw.
That screw and the two screws on the sides where the windshield raising/lowering arms go through those slots got me on the first removal of my '99 years ago.
So to be sure... there are a total of 7 T25 screws holding on the instrument panel cover. Four for the base of it, two on the sides (These are really short so as not to rub) and then the one for the map light.
Hope this helps a bit.
Tommy
IBA #48786
MOA #164466
tconnell is offline
post #8 of 11 Old Apr 11th, 2014, 10:32 am Thread Starter
timgray's Avatar
Note: the windshield arms hide two screws, you need to raise it a bit to remove them, then raise the windshield arms all the way to get it off, and there is that screw dead center front
Thanks everyone!
timgray is offline
post #9 of 11 Old Apr 16th, 2014, 2:08 am
joh0665's Avatar
Do you have to remove the tupperware in order to take the front fairing off? Please say no! I have to resecure the headlamp to it, and I dread taking the tupperware off, again.
03 K1200LT
Radio & Comm System with single CD Player
It's not about the destination, It's about the ride
joh0665 is offline
post #10 of 11 Old Apr 16th, 2014, 2:22 am
Milton,
I think we all dread taking the tupperware off. The thing to remember is that the more often you do it the easier it becomes.
Brian.
bfree is offline
post #11 of 11 Old Apr 16th, 2014, 2:24 am
Oh! forgot to mention, a battery screwdriver helps. Be sure not to iver tighten the rubber mounts though.
Brian
bfree is offline
Initial Fairing Removal Pics ... mneblett K1600GT/GTL 8 May 30th, 2011 6:16 pm
Torque Value for the Fairing screws? cessna RT Series 26 Dec 21st, 2010 4:23 pm
2006 Side Fairing Removal...Help browad K1200LT 36 Jan 12th, 2007 6:22 pm
The night is truely mine markbreen Lighting 9 Apr 20th, 2006 10:11 pm
Handle Bar Adjustment jorawro K1200LT 19 Dec 22nd, 2005 12:28 pm
