Bad front end shake/tank slap when decellerating abruptly from 40 mph - BMW Luxury Touring Community
post #1 of 12 Old Apr 10th, 2014, 7:02 pm Thread Starter
wildwestrider's Avatar
Hey guys!
Been a while since I've been here. trying to sort out a front end near tank slapper like handle bar oscillation on a 2006 K1200LT with only 12,000 miles on it.
Its most pronounced when abruptly rolling off the throttle at about 40 mph with very light hand pressure on the handle bars. We just put a new tire on it, thinking that would fix it. No change. I have thought I heard a bit of clacking in the area of the front end with rolling throttle on and off quickly and loading/unloading the suspension.
Any ideas?
BC
wildwestrider is offline
post #2 of 12 Old Apr 10th, 2014, 7:18 pm
deanwoolsey's Avatar
Re: Bad front end shake/tank slap when decellerating abruptly from 40 mph
Could be the front or rear tire, weak shocks, loose bearings on the swing arm attachment points, bad ball joint up front, bad balance, or a bad steering damper. Personally, I think out of round tires or stretched beads is the cause. That's my opinion. There are lots of others out there. It is a common problem. I have not had it occur since I started being very careful about stretching the beads when mounting my tires. If you hear a "pop" when you are spooning the new tire on, it is my belief you have streched the bead and you will have the problem.
deanwoolsey is offline
post #3 of 12 Old Apr 10th, 2014, 10:03 pm
My bet is on steering dampener. Freshen up the oil and maybe new seals.
2003 K1200 LTE
2004 Yamaha WR250F
1997 Suzuki RMX 250
1996 Yamaha WR250
1983 Yamaha IT 175
1976 Kawasaki KD 175
2000 BMW 528I M Sport
1997 BMW 540I
2001 BMW 330I
Liv'in The Dream
ktmdrz400 is offline
post #4 of 12 Old Apr 10th, 2014, 10:07 pm
I had a new front that developed that as soon as I changed it. Turned out the new tire was out of round by 1/4 inch. This is almost always caused by a tire problem, front and rear both can cause it.
post #5 of 12 Old Apr 10th, 2014, 10:25 pm
Miles of Smiles
Hilton's Avatar
Including tire issues check the pressures.
Most run higher than recommended.
I use 40 psi front and 46 psi rear.
Some use 42 / 48.
Can sometimes help.
Or just hold onto the bars.
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #6 of 12 Old Apr 10th, 2014, 10:31 pm
BC
I've had Bridgestones and Metzeler tires on the front and both did it, the Metzeler's the worst. Currently have a new Bridgestone and there is no wobble whatsoever. But before mounting the tire I found the heavy spot of the rim, aligned the yellow mark on the tire with the heavy spot on the rim, and carefully balanced the wheel.
If you cannot find the heavy spot on your rim, align the red mark on the tire with the tire valve. If the tire is currently mounted like that, or if your new tire doesn't have any markings, try rotating the tire 90 degrees on the rim and rebalance it. There is no guarantee that this will fix your problem, but at least you will have the satisfaction that you tried.
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #7 of 12 Old Apr 10th, 2014, 11:25 pm
johnT's Avatar
. We just put a new tire on it, thinking that would fix it. No change..
did you balance it?
johnT is offline
post #8 of 12 Old Apr 11th, 2014, 10:40 am
14wntr's Avatar
If I remember right, when the changed the suspension geometry it created a problem with this.
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #9 of 12 Old Apr 11th, 2014, 10:46 am
johnT's Avatar
Say what ???
johnT is offline
post #10 of 12 Old Apr 11th, 2014, 11:01 am
Originally Posted by johnT View Post
Say what ???
They changed the rake angle slightly (63.00 vs. 63.96) on the 05 and up units, but tires are almost always the cause. I have re-balanced part way through the wear of a front (installed Smartire system) and the previous wobble went away with that tire.
post #11 of 12 Old Apr 11th, 2014, 11:09 am
rhawk's Avatar
If the steering is damp, then all you have to do is dry it off.
However I don't believe that the steering damper plays That much of a role on this bike.
If you're hearing clanking or clunking from your front end, You'd better check that out soon.
Bike on center stand, scissor jack & wood block under engine to lift the front.
Check Everything for play!!
Rand & Susan Hawksworth
2000 K1200LT
rhawk is offline
post #12 of 12 Old Apr 11th, 2014, 1:43 pm
johnT's Avatar
Originally Posted by jzeiler View Post
They changed the rake angle slightly (63.00 vs. 63.96) on the 05 and up units, .
Yeah.
I know
But the bike is 8 years old.
If it was a problem with the rake, I think it would
Have been noticed long ago
Headshake in most bikes is due to tires
Also steering head bearings
I have not taken apart an LT front end yet
So
Not sure what parts may or may not be worn or loose.
johnT is offline
Front wheel removal eibacher K1200LT 20 Dec 13th, 2012 10:56 pm
tires, Front wheel stand,tire changer for 06KGT HowardRichman K1200/1300GT (The Next Generation) 12 Jul 24th, 2011 4:01 pm
Front and shake/ shimmy front, ... revisited andy K1200LT 12 Jan 12th, 2007 8:16 pm
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 11:48 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 11:37 am
