Starter free spins on occasion - BMW Luxury Touring Community
post #1 of 3 Old Apr 9th, 2014, 6:56 pm Thread Starter
james216's Avatar
I just had the tank off my 2004 KLT to do air/fuel filters and Jiffytite QD's. Got my fuel issues solved. But now notice every now and then last few days. First start attempt starter will free spin. 2nd attempt and thereafter it engages and starts trouble free. Relay maybe?
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #2 of 3 Old Apr 9th, 2014, 7:09 pm
K100Dennis's Avatar
Re: Starter free spins on occasion
If you are certain that the starter motor is actually spinning (powered up) then it is likely that the starter sprag (overrun clutch) is beginning to gum up and slip rather than grip the hub to turn the engine over. Plenty has been written about the issue here. Search starter sprag clutch. In the K100 days I always used a high detergent diesel engine oil and never did short runs, this ensured the engine oil always came up to operating temperature so reducing the chance of forming condensate and sludge, both enemies of the starter sprag.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #3 of 3 Old Apr 9th, 2014, 9:28 pm
Sprag clutch slipping. That is one witch of a job to replace! Please don't ask me how I know. 8>)
You may be able to avoid ever replacing it though. Much has been written over the years, the easiest thing to try is running CD-2 oil detergent for some time, then changing the oil. http://www.autozone.com/autozone/acc...er=238992_0_0_
Also, you can pull the crankcase cover, and spray carb cleaner into the three holes in the sprag clutch housing. (Don't worry, you do not remove the crankshaft. That is the only picture I had with the crank cover off.)
A little hard to get to, but that should flush out most of the sludge in the clutch. Of course you would immediately change the oil before starting the engine.
Name:	Sprag Location.JPG
Starter motor spins chuckle K1200LT 11 Apr 5th, 2013 8:22 pm
Starter spins but won't engage Scotty2 K1200LT 12 Jun 4th, 2008 8:10 pm
