Brake servo not working.. what to check first? - BMW Luxury Touring Community
 1Likes
  • 1 Post By johnT
post #1 of 16 Old Apr 9th, 2014, 1:09 pm Thread Starter
johnT's Avatar
the brake servos stopped working on the LT this morning. (2002)
any suggestions on what to check first?
fuse? brake switches? elect. plug?
not quite sure where it is actually..
I know where the main brake control unit is under the seat...
gonna go sniff around and see if I can find anything obvious...
it was fine when I parked it in the fall.....
but I know that dont mean much.... I am familiar with murphys law..
thanks for any advice....
johnT is offline
post #2 of 16 Old Apr 9th, 2014, 1:44 pm Thread Starter
johnT's Avatar
Re: Brake servo not working.. what to check first?
I just took a quick video
I fear the servo is shot...
All fluids are full
Any ideas??
http://www.youtube.com/watch?v=NIGfYEzsNLo
johnT is offline
post #3 of 16 Old Apr 9th, 2014, 8:50 pm
OK Two things could be happening based on your video. A failure of the front half of the ABS unit. The other thing is that something is stopping the ABS unit from fully completing the start up self test. With no brakes applied check to see if the brake light comes on when you turn the key. If it does come on find the cause as this could be a stuck brake switch stopping the self test from completing. Might just get lucky.
post #4 of 16 Old Apr 10th, 2014, 6:38 pm
blueknightga6's Avatar
My 2002 will give the fast flash when the ignition is turned on and in a few seconds go to slow flash until the drive away test. It does (as you know) look like it not completing its check.
Chris Ehlbeck
blueknightga6 is offline
post #5 of 16 Old Apr 13th, 2014, 7:47 am Thread Starter
johnT's Avatar
Update.
Took the ABS unit out and found a burned chip in the printed circuit board and also the servo motor for the front calipers was dead.
there was a good amount of tarnish and dark brown discoloration inside the unit (on the front brake section) the rear was very clean...
I decided to remove the entire system and run SS lines from the master cylinders to the calipers. (like god intended)
I removed the electrical portion of the unit and insulated it. The speedo and brake lights run through it. so it must be kept.
I removed the ABS relay under the tank.. which stopped the wig wag lights.
Thanks to John Z. and sgroover for help.
probably won't get the SS lines on until next weekend...
I had the stock lines hooked up and bled but the stock rubber hose ruptured at the right caliper...
the lever felt very solid ... before it ruptured..
I think going direct (from master to calipers) applies more pressure... ?
rather than going to the control unit and back.... could have been air in the control unit or lines also... who knows...
I'm just glad to be rid of about 8 lbs. and a maze of brake lines.
Gained some under seat storage room also....
will update when I get her buttoned up and take a good test ride.
johnT is offline
post #6 of 16 Old Apr 28th, 2014, 2:49 pm Thread Starter
johnT's Avatar
Slight delay in getting my custom lines from Galfer... but lets move on...
The Brake lines fit perfectly ... One line from front master to right caliper, double banjo bolt and another short line over to the left caliper.
Rear is one line from the master to the caliper.
Bleeding was EZ as could be. (speed bleeder bag)
today was my first trip with the bike to work and back... 50 miles round trip. Most of my trip is twisty backroads... the brakes work great.
Not better than the servo assist IMO, but not worse.... I think it's about the same.
In any case, the brakes work great, no warning/fault lights... the brake /tail lights and speedo work as normal.
As far as losing the ABS and linked brakes, Thank God. I hated that crap. I very rarely use the back brake unless it's a slow speed maneuver or holding the bike at a light..... but I used to go through rear pads at the same rate as the front or quicker...
I am very happy I yanked the techno brake system and went back to simple.... and effective.
thanks again john Z and sgroover.
johnT is offline
post #7 of 16 Old Apr 28th, 2014, 3:37 pm
Glad it is working out OK for you. Enjoy.
post #8 of 16 Old Apr 28th, 2014, 10:32 pm
Some additional reading on ABS if interested.... there's a thread on I-BMW for K12GT slant 4 bikes where they've been repairing the ABS servo motor for "stuck brushes"... and module masters have chimed in there indicating they completely replace the motor brushes with a different type...
not sure if it has any bearing on our LT ABS system or not.. but I guess they'd be pretty similar?
post #9 of 16 Old Apr 29th, 2014, 6:33 am
sailor's Avatar
This thread is about another newer ABS modulator installed on all "slant 4" models 2007 and later - this ABS modulator was never installed on the K1200LT.
Early "slant 4", K1200S/K1200GT beginning in 2005/2006, had an ABS-Modulator very similar to the 2nd generation of K1200LT (2005+) with servos. After production of August-2006 (mainly sold as 2007 models in USA), BMW introduced a simpler and lighter ABS modulator on all these models. Although they are simpler to bleed, these have problems with the brushes of the single motor. This is what this thread is about on I-BMW.com
John (Montreal, CANADA)
sailor is online now
post #10 of 16 Old Apr 29th, 2014, 8:34 am
OK, irrelevant info... thx Sailor.... brain is getting confused trying to take in so much extra info lately... :-)
post #11 of 16 Old Apr 29th, 2014, 9:59 am
Those are on some of the later model GS bikes (mine) as well. Stuck brushes well documented.
post #12 of 16 Old May 28th, 2014, 2:53 pm
Do you happen to have the measurements you used for the custom lines? I think I need to get a set made for my 06 K1200LT
pricebri is offline
post #13 of 16 Old May 28th, 2014, 3:08 pm Thread Starter
johnT's Avatar
master to right caliper 40"
caliper to caliper 17"
rear- master to caliper 45"
I would measure twice before you order... not sure if my 2002 is the same as your bike.
big_ed likes this.
johnT is offline
post #14 of 16 Old May 28th, 2014, 4:35 pm
Thanks so much for the quick response!
I do plan to measure myself, just wanted a baseline so I knew if I was close
pricebri is offline
post #15 of 16 Old Aug 21st, 2014, 12:58 pm
whtmtn2000's Avatar
Exclamation Re: Brake servo not working.. what to check first?
John T or any others I need just a little help on this,
Ordering Lines from Galfer. If I could get a former order number and date for these custom lines it would be great. Or the last name of John T. so they (Galfer) can look up the order that way. I want to order the same line configuration for my 2002 LTC. For example the Indexing of the Banjos and the Banjo Type/Angle etc are needed and I would rather not try to guess as some of you have already got them perfect from Galfer.
Your help as always is appreciated,
Mark
Mark D.
Groveland,MA
2002 KLT (JETBLUE)
1993 ST1100 (retired)
1982 GPz 1100 EFI (retired)
1979 750F (retired)
whtmtn2000 is offline
post #16 of 16 Old Jul 5th, 2015, 4:04 pm
big_ed's Avatar
Thank you for posting the details. Want to delete on my 2003 too. Out to the garage
big_ed is offline
More brake issues joseph_p K1200LT 10 Feb 13th, 2014 8:28 pm
BMW Motorcycle Quality 150flyer Bike Talk 5 Oct 28th, 2013 8:30 pm
Brake hose in control circuit kend52 K1200LT 6 Jun 16th, 2013 7:49 pm
