coolant service interval.? - BMW Luxury Touring Community
post #1 of 7 Old Apr 7th, 2014, 10:46 pm Thread Starter
UNclebudintx's Avatar
My new to me 02 lt only has 7200 mile onit.. I have all the tupperware off , replacing the fuel couplers and checking the air filter...
Would you replace to coolant at this time?
Is that a bigger job than it sounds like?
Unclebud in TX
Plainview TX
2007 Kawasaki KLX300r (dirt days)
1969 HONDA TRIAL 90 ( miles of smiles)
200? Unigo ( AKA The Pig)
2002 K1200 LT (AKA Nicci )
2004 Bushtect Roadstar (AKA Elli)
2014 R1200GSA (AKA FreeBird)
OTHER BIKE I HAVE OWNED
2004 R1150 GS (crashed) (AKA GRAY WOLF)
2004 R1150 RT ( Sold) (AKA SILVER BULLET)
1981 KAWASAKI KZ1000ST (SOLD)
1991 HARLEY SPORTSTER 883 (SOLD)
The flogging will continue untill morale improves!
UNclebudintx is offline
post #2 of 7 Old Apr 7th, 2014, 10:58 pm
Re: coolant service interval.?
It is not a bad one it is just hard to get to the radiator cap with the body work and fuel tank on. I would save it for the next major service when the tank is off. Coolant is an annual and is done every 4 years. If you can get to the cap OK go for it. The book has you pull the temp sensor down at the oil/water pump unit to drain (you can just pull the lower hose and get most of it out). Not an issue just be careful when you re-install it as it is NOT pipe thread and should only be tightened to 9 Nm (which is just snug).
When re-filling it helps to loosen the clamp on the top radiator cross hose to allow air to burp out. Capacity is 2.64 US quarts with a 0.63 on the overflow tank.
post #3 of 7 Old Apr 8th, 2014, 9:13 am
vespacar's Avatar
Do it now I did it over the winter, it's really easy with all of the body panels off. It only takes 20-30 mins to do. I didn't even bother to loosen the hose clamp like in the video's. I just ended up squeezing the hose to help it burp. Bought a gallon of 50/50 mix and ended up using around 3/4 of it if you include replacing the reservoir.
Cheers,
Tross
2002 K1200lt
2010 Piaggio MP3 500
1982 Lambretta GP225
vespacar is offline
post #4 of 7 Old Apr 10th, 2014, 10:13 pm
Does anyone used Water Wetter?
Pdrude is offline
post #5 of 7 Old Apr 11th, 2014, 8:00 am
vespacar's Avatar
Just covered by this thread:
http://www.bmwlt.com/forums/showthread.php?t=95393
I learned something by reading it.
Cheers,
Tross
2002 K1200lt
vespacar is offline
post #6 of 7 Old Aug 13th, 2014, 12:46 pm
CR125Honda's Avatar
FYI....
Just replaced the fluid in my 03 LT.
Removed the water/oil pump due to an oil weep.
Noticed the refill capacity was 2.64 qts (plus amount in reservoir) in a few threads and in my Clymer manual. It also states the total capacity as 3.1 qts and .63 in reserve tank.
I put a little over 3 qts in the radiator spout during my refill.
I'm guessing about .46 qt remains in the pump area after a normal system drain.
During my next flush, I'll probably fill/drain with distilled water a only couple times.
Then the final fill, add 1.6 qts of straight coolant and top off with water.
Probably not a big deal, but it is almost a half qt of a 3 qt system that's not getting flushed.
Just a heads up.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Couple Mini Trail's QA' & CT's
CR125Honda is offline
post #7 of 7 Old Aug 13th, 2014, 11:02 pm
Just replaced mine with this waterless coolant. Runs great no problems at all. http://www.evanscooling.com
BMWMOA
Never ride faster than your Guardian Angel can fly
2007 K1200LT Storm Grey metallic
Uni Go Trailer
Chayside is offline
Waterless coolant gunny K1200LT 16 Jun 14th, 2014 10:10 pm
Service Interval Message? 150flyer RT Series 4 May 29th, 2011 11:32 am
Service check list? hip001 K1200LT 4 Feb 8th, 2008 12:36 pm
My Dissapointment at BMW Motorcycles of Miami. ArlesF80ST Dealer Experiences 0 Jan 24th, 2008 5:22 pm
article by Scott Mckay, Sierra BMW Service rkirker Bike Talk 2 Jan 3rd, 2007 8:23 pm
