no neutral light and fuel pump doesn't run - BMW Luxury Touring Community
post #1 of 10 Old Apr 7th, 2014, 3:23 pm Thread Starter
I replaced the rear main seal and clutch and when I turned the key on the neutral light doesn't come on and the fuel pump doesn't run. The neutral switch is indicating the right gear and the side stand switch is working. Not sure if problem is related to the work I did but everything worked fine before. Any ideas on what to check would be a big help. And the engine will not crank over not sure what has gone wrong. Thanks!!
Doug47 is offline
post #2 of 10 Old Apr 7th, 2014, 6:02 pm
Re: no neutral light and fuel pump doesn't run
Reverse knob tight up against the F mark?
post #3 of 10 Old Apr 7th, 2014, 6:22 pm Thread Starter
the reverse switch is in the right position and I did disconnect it and made no difference
Doug47 is offline
post #4 of 10 Old Apr 7th, 2014, 6:52 pm
deanwoolsey's Avatar
I bet you broke one of the small tabs off on one of your safety interlock switches.
deanwoolsey is offline
post #5 of 10 Old Apr 7th, 2014, 7:47 pm
BecketMa's Avatar
Sheeepishly I learned the hard way to check all of the fuses.
bob
BecketMa is offline
post #6 of 10 Old Apr 7th, 2014, 9:34 pm Thread Starter
I took an ohm meter to all the fuses I could find and all were good. This is frustrating because I was going riding this weekend. I will keep working on it till I get it fixed!!
Doug47 is offline
post #7 of 10 Old Apr 7th, 2014, 11:45 pm
Considering that you most likely have had all relevant switches (sidestand, gear position, reverse knob) detached(?) during the job, I would start from checking connectors from those.
Born to be wild so why not
C-A-D is offline
post #8 of 10 Old Apr 7th, 2014, 11:58 pm Thread Starter
I will check the plugs and connections hope I find something simple that I have over looked
Doug47 is offline
post #9 of 10 Old Apr 8th, 2014, 5:51 pm
Check all the barrel connectors under the rear seat two (on the left side) are for the reverser controller and the neutral signal and starter signal go through them to the dash.
post #10 of 10 Old Apr 9th, 2014, 12:23 am Thread Starter
You hit the nail on the head!! Now I can get to riding and not working on it. Thank you!! And Thank you to all who helped with suggestions.
Doug47 is offline
2006 LT ABS and Fuel Pump Fuse Hilton K1200LT 5 Feb 11th, 2014 9:55 pm
Octane Booster timgray K1200LT 22 Sep 13th, 2013 6:53 pm
Low fuel warning light calibration cmartin248 K1200LT 1 Nov 2nd, 2010 9:17 pm
Low fuel light stays on cmartin248 K1200LT 1 Oct 5th, 2010 6:55 pm
