Windshield will not go up - BMW Luxury Touring Community
post #1 of 10 Old Apr 6th, 2014, 8:56 pm Thread Starter
I have an 05 K1200LT .On my trip this weekend I lowered the windshield. We left the bike parked outside and there was some frost on it in the morning. I do not know a lot about the bike but am trying to learn. I can not find the fuse block. I was thinking the a fuse was blown. Rode 400 miles home with the windshield down. Was an experience. Please advise me where I should look for the fuse for the motor that operates the windshield. I do not want to go to the local dealer for this.
dcsorric is offline
post #2 of 10 Old Apr 6th, 2014, 9:05 pm
Munmi's Avatar
Re: Windshield will not go up
I used to have intermittent issues until I got the system lubed. Until that time, I would give the windshield a little nudge and it would then move normally. Maybe you could be so lucky.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #3 of 10 Old Apr 6th, 2014, 9:26 pm Thread Starter
Will check that out. I do not hear anything trying to do anything. I just got home from a 700 mile 3 day trip. I love the bike just worry about problems with it.
dcsorric is offline
post #4 of 10 Old Apr 6th, 2014, 9:39 pm
the 4 pivot pins probably just need lubrication - best choice is to remove them clean and apply a little grease when reassembling - they corrode slightly
you can try lifting the wind shield when operating the switch to see if it will go up with help
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #5 of 10 Old Apr 6th, 2014, 9:44 pm Thread Starter
Will try . Hope it goes up. Have to work tomorrow but will check it out. Thanks
dcsorric is offline
post #6 of 10 Old Apr 6th, 2014, 10:02 pm
Here is the answer to your question on fuses. And the circuit that operates the windshield. Four relays mounted up at the base of the frame.
ID:	52409   Click image for larger version
post #7 of 10 Old Apr 7th, 2014, 4:29 am
Miles of Smiles
Hilton's Avatar
I use a couple of drops of Super Lube on the pivots.
A dry lube which will not attract dirt.
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #8 of 10 Old Apr 7th, 2014, 11:20 am
tconnell's Avatar
I believe I'd check the fuses first and then remove the windshield and the instrument panel cover and do the lube that's been suggested.
Remember to get the instrument cover off there are the four T25 screws that attach the cover down in front in the windshield area. There is a T25 screw just inside of each windshield arm and also you have one T25 that is inside of the map light. You'll need an extension and a flashlight to get that one out after you use a small flat blade screwdriver to pop out the map light from the left side.
If the fuse is not the problem, the windshield arms might have stopped in the inappropriate place to where you can't get your T25 to the two screws there and/or be able to remove the instrument panel cover because the arms are in a low position.
So hopefully the two 15amp fuses will be the fix.
Tommy
IBA #48786
MOA #164466
tconnell is offline
post #9 of 10 Old Apr 8th, 2014, 11:51 am Thread Starter
I got to look at it this morning and low and behold the fuse was blown. What a relief that was. I will be lubing the pin also as I believe that the fuse was just the beginning of my problem. Thanks For ALL the info you guy's are great. I knew there was a reason I joined.
Dave Sorrick
05 K1200LT
08 Gl1800 Roadsmith Trike
1989 Gl1500 with 205K Sold
Always looking for an excuse to ride!
dcsorric is offline
post #10 of 10 Old Apr 8th, 2014, 1:35 pm
tconnell's Avatar
There you go! I always go for the simplest thing first and then go for the other things. You did good looking for the simplest thing, a blown fuse.
You can just mail me the money for the tip.
Ride Safe.
Tommy
IBA #48786
MOA #164466
tconnell is offline
Windshield landing zone on a í12 RT, can it be adjusted? Ajaxthedog89 RT Series 3 May 26th, 2013 11:11 am
Ztechnik VStream Windshield. 2nd review strsout Ergonomics & Rider Comfort 33 Dec 31st, 2010 10:30 am
California Scientific windshield kevonrainy Ergonomics & Rider Comfort 0 May 24th, 2009 1:35 pm
Windshield Jamboree and Swap Meet dfinazzo Curve Cowboy Reunion 14 May 13th, 2009 6:45 pm
Oh no, not another windshield question!!!! FloridaBMW Ergonomics & Rider Comfort 11 Oct 20th, 2008 12:01 pm
