Could use some radio help? - BMW Luxury Touring Community
post #1 of 5 Old Apr 6th, 2014, 5:16 pm Thread Starter
quohog's Avatar
Question Could use some radio help?
Good afternoon everyone? Its been a while since I posted. Weather was adequate for a ride this afternoon. While I was out the left side speakers were not working so I only got to listen to the right side of the ball game.
Here is the strange part that I cant find an answer to in the hall of wisdom! When I got home and turned of the bike (run switch first, then the key) put down the kickstand, I put the bike up. Then i kept hearing this noise more like a crackling noise (Static like). I found the noise coming from the left
speakers. Even when the power was off and the radio had already been turned off with key in lock position.
I have an 04 LT and any help would be greatly appreciated.
Thanks in advance
Quohog
Tomorrow is promised to no one!
1993 Honda CBR1000F
2001 K1200LTC (sold)
2004 K1200LT (replaced 01)
2005 Yamaha Road Star (gone)
2009 Harley Road King Classic
2009 Harley Ultra Classic.
quohog is offline
post #2 of 5 Old Apr 6th, 2014, 6:49 pm
johnbaker15's Avatar
Re: Could use some radio help?
What you have is most likely a failed left amp in the radio. If you want to have it repaired do a search for Baris he is in England and will rebuild the radio. BMW wants more than the bike is worth.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #3 of 5 Old Apr 7th, 2014, 5:16 pm Thread Starter
quohog's Avatar
Thanks John.
Could this also be symptomatic of hearing a crakling noise even when the bike is off with key in lock position?
Quohog
1993 Honda CBR1000F
quohog is offline
post #4 of 5 Old Apr 7th, 2014, 5:30 pm
Axle's Avatar
shouldn't be any noise while off, disconnect the battery for a while don't forget to do a tps reset
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #5 of 5 Old Apr 7th, 2014, 6:14 pm
james216's Avatar
If you do have a failed amp. And you do decide to repair the factory unit. Becker in NJ will do an exchange and install a 3.5 jack. But it's $400.00 and the same crappy 20 watt amps with too small of heat sinks. So your problem will happen again. I went with Baris's repair because he uses 45 watt amps with big heat sinks. Yes there is the Sony or Jensen installs. Even one that can wire handlebar controls to a Sony. But I wanted all factory with it's features. All I can say is. If radio reset doesn't work and your amps are fried. Baris is more $$. But my stereo sounds awesome. A way better option to me than Beckers deal. And he will install a 3.5 or RCA or Bluetooth. I highly recommend Baris if factory is your choice.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
Frustrated with XM Radio Customer Service wcarter Satellite Radio 19 Jan 16th, 2019 9:24 am
Radio Repair Update - When is the next LT ready? Vince_nj1 K1200LT 28 Oct 2nd, 2010 2:46 pm
Unusual Radio Issue on an '02 LTE ErnieA K1200LT 20 Feb 14th, 2009 10:12 am
