Hitches.. - BMW Luxury Touring Community
post #1 of 6 Old Apr 6th, 2014, 3:25 pm Thread Starter
timgray's Avatar
Hitches..
I have a Single wheel trailer that I built over the past year that is like the http://n-line.com/products/single-wh...cycle-trailer/ N-Line trailer.
What would be the best hitch? Should I get a UniGo hitch and build my receiver for that mount plate they have? or should U get a bushtech and just use the Ball mount Adapter I already have?
My worry about the bushtech is that it is not designed at all for a single wheel trailer that has rotational loading while the Uni-Go hitch looks like it could barely hold a six pack of beer in weight.
Anyone have any experience with either hitch? or better yet anyone pull the larger N-Line style trailer?
timgray is offline
post #2 of 6 Old Apr 6th, 2014, 5:48 pm
kellenbenz's Avatar
Re: Hitches..
Hi Tim,
I have used the Bushtec and the Dauntless hitch on my LT and just the Dauntless on my RT. I have not pulled a single wheel trailer with either but here is my 2 cents on the different hitches.
The Dauntless is a much cleaner install and the visible part un-clips and removes when not in use. It also allows for tire changes by swinging up out of the way to roll the tire out the back. I have pulled my Bunkhouse camper(450 LB loaded) with both of these hitches with no problems
http://www.dmcsidecars.com/hitches/hitches-for-bmw/
The Bushtec is probably just a bit more heavy duty but is a total PITA when you have a flat on the road. It must be taken off to remove the rear tire without a lift. If you get this one be sure to carry 2ea 9/16 combination wrenches in your tool kit.
HTH,
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #3 of 6 Old Apr 6th, 2014, 6:05 pm
tconnell's Avatar
Re: Hitches..
Tim,
Dauntless for me without a doubt. I have both the '99 LT and the 2007 LT and both have had the Dauntless on them. To change the tire on either, I just put it on the center stand and remove the two pins from the underside of the hitch and pull the hitch Ball assembly out of the tubes. Then I remove the stem from the tire and let it get totally flat. Then I remove the bolts from the wheel assembly and remove the wheel and tire. I have to squeeze the tire a bit or get the lean just right, but then it rolls out.
So changing a tire with the Dauntless is simple. I don't know a thing about the single wheel trailers so hope this on the hitch helps you in the decision.
Tommy
IBA #48786
MOA #164466
tconnell is offline
post #4 of 6 Old Apr 6th, 2014, 8:09 pm
jaskjb's Avatar
Re: Hitches..
+1 on the dauntless, works great with unigo trailer
Jim G - Rochester, MN
BMW MOA #123976
2000 K1200LTC
jaskjb is offline
post #5 of 6 Old Apr 7th, 2014, 6:55 pm
bowdon's Avatar
Re: Hitches..
I agree, Dauntless all the way.
I have pulled an Aspen Sentry, and a Home made cargo trailer and have had no problems except for lower gas millage.
+1 on the Dauntless.
Bowdon
bowdon is offline
post #6 of 6 Old Apr 7th, 2014, 10:26 pm
UNclebudintx's Avatar
Talking Re: Hitches..
I have a unigo hitch on my rt and I pull a unigo trailer with it... no problems with hitch, it is fine, I dont think a tire change would be big deal..
On my lt it has a bushtech hitch that I pull a bush tech trailer and it pull like a dream...
I am going to rig an adaptor to pull the unigo trailer with the lt bushtech hitch... just for grins..
I saw a lady pulling a bushtech trailer with a r1150rt like mine one time but it looked like a load..not sure I will try that...
Either hitch will be fine.
Unclebud in TX
Plainview TX
2007 Kawasaki KLX300r (dirt days)
1969 HONDA TRIAL 90 ( miles of smiles)
200? Unigo ( AKA The Pig)
2002 K1200 LT (AKA Nicci )
2004 Bushtect Roadstar (AKA Elli)
2014 R1200GSA (AKA FreeBird)
OTHER BIKE I HAVE OWNED
2004 R1150 GS (crashed) (AKA GRAY WOLF)
2004 R1150 RT ( Sold) (AKA SILVER BULLET)
1981 KAWASAKI KZ1000ST (SOLD)
1991 HARLEY SPORTSTER 883 (SOLD)
The flogging will continue untill morale improves!
UNclebudintx is offline
Questions About Dauntless and Bushtec Hitches hschisler Trailers, Sidecars, & Trikes 22 Jan 3rd, 2014 9:36 am
Trailer Hitches aikelec K1600GT/GTL 6 Feb 22nd, 2012 9:04 am
Trailer Hitches drifter36 Trailers, Sidecars, & Trikes 7 Aug 21st, 2010 4:38 pm
Trailer Hitches & "Cooler" Racks DonNJ Trailers, Sidecars, & Trikes 4 Jun 17th, 2006 1:03 am
Trailer Hitches DonNJ Trailers, Sidecars, & Trikes 4 Jun 15th, 2006 10:15 am
