HID Headlight Won't Lite - BMW Luxury Touring Community
post #1 of 8 Old Apr 6th, 2014, 1:52 am Thread Starter
dwillie's Avatar
Hi everyone. My formally working HID headlight is now _not_ working. Fuse is fine, so maybe the bulb or igniter has failed. When a normal bulb is burned out, you can see the filament is broken. How do you tell if a HID bulb is burned out? Any suggestions as I begin to trouble shoot? Thanks, dwillie.
dwillie is offline
post #2 of 8 Old Apr 6th, 2014, 6:25 am
cwo
cwo's Avatar
Re: HID Headlight Won't Lite
I HAVE THE DDM HID ON MY LT, AND SOMETIMES I HAVE TO REMOVE BULB, AND RE-INSERT FOR THE HID TO WORK. MAYBE A GROUND OR SOMETHING??
CHRIS OGLE
Life is ephemeral. Don't waste it lookin up big words.
cwo is offline
post #3 of 8 Old Apr 6th, 2014, 7:24 am
mtrevelino's Avatar
For as cheap as they are, just order another kit and be done with it. Mine went out on my LT after about five years, I just replaced the kit and be done with it.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #4 of 8 Old Apr 6th, 2014, 8:42 am
vespacar's Avatar
I go as far as having a spare bulb and ballast around. On my Piaggio I went through a few (cheap chinese ones). But what I did find that my battery was going as well. Replaced the battery with a nice AGM battery and guess what , no more burnt out HID bulbs/ballasts, could there be a connection, maybe. There's not really much to fault check, you can make sure all of the connections are connected, move the wires around, but really that's about all.
Who did you order the kit from and how long ago? Some offer a warranty. Remember you can always put back a H11 so you can ride until your new Kit arrives. Also I've always ended up replacing both the bulb and the ballast. You could get lucky, but order both anyway.
Cheers,
Tross
2002 K1200lt
2010 Piaggio MP3 500
1982 Lambretta GP225
vespacar is offline
post #5 of 8 Old Apr 6th, 2014, 11:37 am
rowie's Avatar
These things can be sensitive to a low battery. Make sure your battery is fully charged and try again. Mine was a bit intermittent until the battery was charged, then it was fine. If this isn't the problem, the bulbs rarely die, usually the box that the bulb is connected to is the culprit.
Hope this helps.
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #6 of 8 Old Apr 6th, 2014, 2:51 pm
Zeke's Avatar
They are cheap now for the whole kit,Not sure what year you have but on my 02
what i did was just switch the high and low, if it works you know the issue.
But I think I bought mine ,30$ for 2 bulbs.
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
post #7 of 8 Old Apr 6th, 2014, 5:37 pm
If the quartz globe in the center of your HID bulb is shattered then the bulb is bad. Otherwise it is your ballast/igniter. heck any in line fuse for corrosion as well and the ground run (stock headlight area).
post #8 of 8 Old Apr 6th, 2014, 8:59 pm Thread Starter
dwillie's Avatar
Thank you all for your suggestions. I am on it. Possible relay gone bad (Song Chuan 804-1a-c1), 30Amp. I will also check the bulb and all ground connections. d.
dwillie is offline
Ducati Design Headlight HID upgrade ridinredfox K1200LT 3 May 18th, 2011 11:19 am
HID xenon headlight bulb on eBay??.. And is my relay goin bad? beemerguywhotravelsalot K1200LT 3 Jun 23rd, 2009 2:49 pm
Pondering pathBlazer &/or HID Headlight Addition? lawrider K1200LT 2 Mar 15th, 2009 5:44 pm
'02 Headlight with HID Low & High a headlight on ebayon EBay carl_faller Chit Chat 1 Sep 7th, 2007 3:36 am
Headlight Modulator and Low Beam HID ihbond K1200LT 8 May 9th, 2007 5:39 pm
