Handlebar Reservoirs Seeping - BMW Luxury Touring Community
post #1 of 5 Old Apr 3rd, 2014, 7:14 am Thread Starter
Tobster's Avatar
If it's been addressed before - I can't seem to find it. Winter project including flushing clutch fluid and brakes after Spiegler install. Prior to tinkering with it, neither reservoir showed signs of seepage. Now that I've flushed everything BOTH reservoirs on the handlebars are slightly seeping at the seam. The screws are good and snug and fluid level is halfway on the sight. The rubber under the caps appears to be fine and seated correctly. I've tightened the covers about as far I can without stripping or breaking something.
Toby
03 K1200LT
Tobster is offline
post #2 of 5 Old Apr 3rd, 2014, 7:30 am
Re: Handlebar Reservoirs Seeping
if the screws have been over tightened at some point the rubber will be deformed and possibly leak
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #3 of 5 Old Apr 3rd, 2014, 7:40 am
mwnahas's Avatar
I was wondering if they were over tight also.
Just Go
Cleveland Ohio
2014 K1600 GTL Grey Wolf.
mwnahas is offline
post #4 of 5 Old Apr 3rd, 2014, 3:38 pm
During a flush and re filling the bar reservoirs it is not uncommon for a little bit of seepage. It is usually caused by the rubber diaphragm dipping into the fluid and transfer some fluid out before it seals. Even though it is sealed a little will be at the seam. Just wipe it down and loosen the screws then just make them snug. Very easy to strip trying to stop a non existent leak.
post #5 of 5 Old Apr 3rd, 2014, 9:53 pm Thread Starter
Tobster's Avatar
Thanks guys. Removed both caps today and gave them and the rubber a thorough cleaning - then just snugged them up. After wiping off the residual it seems to be improved. I'll check them again tomorrow. JOHN - good to have you back to posting! Hope the R&R is going well.
Toby
03 K1200LT
Tobster is offline
2003 K1200GT Handlebar Extension Rocketman90251 K1200/1300GT (The Next Generation) 2 Feb 25th, 2012 2:35 pm
Seeking pic handlebar cover mod for 05 throttle cables CharlieVT K1200LT 12 Feb 13th, 2009 6:07 am
Mounting Video Camera. Handlebar or Not? barryst1100 K1200LT 15 Dec 7th, 2007 3:27 pm
Handlebar Vibration? ronlray GS Series 4 May 2nd, 2007 2:47 pm
Handlebar pressure...i cfell Chit Chat 37 Nov 18th, 2006 9:18 am
