How to get to plug for heated passenger backrest? - BMW Luxury Touring Community
post #1 of 5 Old Apr 2nd, 2014, 3:40 pm Thread Starter
I have looked and could not find. How to get to plug for heated passenger backrest. I am putting on different heated backrest and wire is going into trunk area. My replacement backrest (OEM) has a short wire with plug. I just thought if someone has done this, it would be helpful.
Notahog is offline
post #2 of 5 Old Apr 2nd, 2014, 4:10 pm
Re: How to get to plug for heated passenger backrest?
Plug for heated backrest is behind left side rear speaker cover, IIRC.
post #3 of 5 Old Apr 2nd, 2014, 5:42 pm Thread Starter
OK thanks for your help. Now I know what to take off.
Notahog is offline
post #4 of 5 Old Apr 2nd, 2014, 10:32 pm
Munmi's Avatar
There are two T20 torx screws holding the cover in place. Remove the screws then you will be able to hinge upward to remove cover.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #5 of 5 Old Apr 2nd, 2014, 11:10 pm
sweetride's Avatar
Not being overly picky here, but it's not actually under the speaker, but the cover for the controls or plugs on the left side below the speaker. Two Torx 20 screws, one on the inside, one on the bottom. Then you can swing the cover up as if it is hinged. Just had this apart last Sunday in order to install a rack.
Stan
1999 K1200LT
2006 R1200GS
1996 R850R
sweetride is offline
New Style Inner Drain Plug katnapinn K1600GT/GTL 13 Oct 10th, 2019 12:24 pm
BMW Passenger Floorboards & Rider Ground Reach SEG Accessories, Gadgets, and Gear 8 Jan 11th, 2009 9:53 am
What type of Passenger Backrest with a Fort Worth Rack? al2it Accessories, Gadgets, and Gear 4 May 14th, 2008 10:14 am
New passenger backrest check it out RT-Hollywood RT Series 5 Jan 30th, 2008 6:11 pm
Russell Seat Rider Backrest Question BruceHarrisJr Chit Chat 3 Feb 18th, 2006 6:34 pm
