best guess electrical - BMW Luxury Touring Community
post #1 of 3 Old Mar 31st, 2014, 7:09 pm Thread Starter
Well it,s me again. What would you look at first to see what is the problem.
New reverser module, new rear wiring harness installed and new actuating switch for reverser. Can find no shorted out wires in front harness at all and have all plastic removed from front end also.
What happens is this, Turn on key, all indicator lights come on, turn off key and all lights are still there except those for ABS system, Starter will still not engage at any point. Lights do not go out unless battery dis-connected.
Could it be ignition switch or is there a relay somewhere that I could check, starter relay looks real good on new harness.
Havin a good time now don,t ya know. Ideas please. I am still waiting on a Clymer manuel but have gotten some wiring diagram pictures emailed to me.
mexicoboy is offline
post #2 of 3 Old Mar 31st, 2014, 7:38 pm
deanwoolsey's Avatar
Re: best guess electrical
It sounds like you have what I refer to as a "loop" in your wiring. Something on the lamp side of the relay is feeding back into the trigger circuit for the relay. So when you activate the key, the lamp side of the relay which comes on with the key supplies electricity to the coil in the relay which activates the lamps. That holds the relay shut until it resets when you disconnect the battery.
deanwoolsey is offline
post #3 of 3 Old Apr 1st, 2014, 1:25 pm Thread Starter
Thanks , Dean. Mechanic is checking wiring again as he had some splices and same colored wires. What I do not like is the starter button does nothing yet, cross the relay and it turns over. My goodness what a mess.
AAAAAAAHHHHHHH!!! Stumped by electrical issue! LTBeemer K1200LT 22 Mar 14th, 2014 11:07 pm
RT electrical faults Stno573 RT Series 7 Aug 21st, 2013 1:48 pm
Electrical Noise Isolation on LT deputy5211 K1200LT 7 Aug 12th, 2012 8:40 pm
electrical gremlins oldtimer54 K1200LT 7 May 29th, 2012 12:51 am
electrical info dlbushey K1200LT 1 Aug 14th, 2006 2:26 pm
