Another EHCS issues / question - BMW Luxury Touring Community
post #1 of 2 Old Mar 24th, 2014, 11:55 am Thread Starter
LTOehler's Avatar
Question Another EHCS issues / question
Seems to be a popular subject. The stand on my 05 has stopped working, no oil leak and the fuses are good. I push the button and the light flashes at 60htz. Could this be as simple as swapping out the motor or is it more likely that this is just the tip of a very involved repair ??
Dave Oehler
2005 LT Dark Graphite - "K-Ship"
BMW-MOA 121422
LTOehler is offline
post #2 of 2 Old Mar 24th, 2014, 12:33 pm
Re: Another EHCS issues / question
Sounds like a motor to me. Before you go buy one, pull yours off the unit. Then open it up (2 Phillips screws), but use a vise to gently hold the output gear as you pull the case off. That way you will not have to mess with resetting the brushes. There is a plastic base with two screws and the screw that grounds one of the brushes may be corroded. A quick cleanup often restores operation. I don't have a picture but will post one tonight when I get home.
Easy question Ised8m Intercom, CB, & 2-Way Radios 9 Jul 3rd, 2009 9:33 am
Chasing GT Tech Issues with Broken Processes DavidTaylor K1200/1300GT (The Next Generation) 19 Dec 19th, 2008 6:37 pm
Progress/Autoswitch/fuel line question yechave K1200LT 6 May 7th, 2008 4:23 pm
Suspension adjustment assembly question davek1 K1200LT 2 May 8th, 2007 10:24 am
Dauntless Wiring Question pieceofficer K1200LT 12 Apr 16th, 2007 11:35 pm
