No Radio reception after repair. - BMW Luxury Touring Community
post #1 of 14 Old Mar 23rd, 2014, 6:47 pm Thread Starter
james216's Avatar
I sent my radio to Baris for repair. When pulling it out of the holder. Looking down at it on the right side there was a tiny cable that was kind of not really plugged in. I had reception before I pulled it out. I tested today.MP3 thru 3.5 works great. Single CD great. All controls Great. No radio reception. When I put it back together. I did my best to plug that tiny little thing in. But it really doesn't stay in.Is that the antenna? Is there a remedy if it is?
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #2 of 14 Old Mar 23rd, 2014, 7:54 pm
Re: No Radio reception after repair.
James
The connector is on the left side opposite the big connector. Here are some shots. In the first two I show the receptacle on the radio and the second one is the plug. In the next shots are the broke plug housing still in the receptacle and the "guts" of the plug. Often these get broken but they can be re-assembled.
Just make sure the center pin is not bent in the receptacle on the radio.
ID:	51626   Click image for larger version
ID:	51634   Click image for larger version
ID:	51642   Click image for larger version
post #3 of 14 Old Mar 23rd, 2014, 8:50 pm Thread Starter
james216's Avatar
My plug looks like the last pic. I think I somehow got it to go in.I sure hope so. I'm going out to try it again in a bit. If not. I'll be needing advice to reassemble. Thanks for all your help as always
I'm a 4 percenter.
james216 is offline
post #4 of 14 Old Mar 23rd, 2014, 10:52 pm Thread Starter
james216's Avatar
Got it reassembled. And plastic plug housing has a chuck broke out of it enough to where it doesn't want to stay on the plug.But I put it on the plug end. Used some electrical tape to hold it on the connector enough. I'm sure it's plugged in now. I turned it on and same thing. Except. I could faintly hear music thru static. And when I grabbed antenna mast and hand grip. It got a little clearer, not much. So I Took apart mast. And behold a white corrosion inside. I cleaned it best i could.Especially the tip of the metal connector on the bottom, but don't think enough, but it's bout the same. Wonder if it's the certain dead zone spot in my garage where bike is parked noting the crappy reception these antennas have to start with. To cold to pull it outside. New BMW antenna? What about a tune trapper? Might help? Driving me crazy..
I'm a 4 percenter.
james216 is offline
post #5 of 14 Old Mar 23rd, 2014, 10:58 pm Thread Starter
james216's Avatar
Make sure the pin is not bent in the receptacle in the radio. You talking about the female antenna plug on the back?
I'm a 4 percenter.
james216 is offline
post #6 of 14 Old Mar 24th, 2014, 10:29 am
Yes you call it a female but it does have a center pin that is male and goes into the center female pin on the cable.
post #7 of 14 Old Mar 24th, 2014, 3:21 pm Thread Starter
james216's Avatar
I will check for this pin. Thanks..
I'm a 4 percenter.
james216 is offline
post #8 of 14 Old Mar 24th, 2014, 4:13 pm
deanwoolsey's Avatar
If you have a meter, check for continuity between your antennae mast and the base mount. You should see none. Then check for continuity between the mast and the male pin at the end of the cable. If you don't see continuity between those points there's a problem. The internal section of the mast can short to ground and ruin reception or it can corrode and in effect develop an open circuit.
deanwoolsey is offline
post #9 of 14 Old Mar 24th, 2014, 8:39 pm Thread Starter
james216's Avatar
Thanks John. That was it. It was bent. Needed a magnifying glass to see it. LOL. I'm getting old.
I'm a 4 percenter.
james216 is offline
post #10 of 14 Old Mar 25th, 2014, 4:58 am Thread Starter
james216's Avatar
Thanks. It seems to be working. Might go with a tune trapper at some point.
I'm a 4 percenter.
james216 is offline
post #11 of 14 Old Mar 25th, 2014, 8:16 am
mwnahas's Avatar
Glad you got it working.
Just Go
Cleveland Ohio
2014 K1600 GTL Grey Wolf.
mwnahas is offline
post #12 of 14 Old Mar 25th, 2014, 4:48 pm Thread Starter
james216's Avatar
Did you join BMWMOC . Me and the wife did. BTW when did you get rid of the LT and pick up a GTL?
I'm a 4 percenter.
james216 is offline
post #13 of 14 Old Mar 25th, 2014, 7:12 pm
mwnahas's Avatar
Already a memmber glad to have you abord. See you next meeting next Thursday if you come. Saw you at the last one but didn't get a chance to say hello. MW was so crowded some of us had to stand outside at the bar.
When did I get the GTL?
http://www.bmwlt.com/forums/showthread.php?t=91138
Just Go
Cleveland Ohio
mwnahas is offline
post #14 of 14 Old Mar 25th, 2014, 9:11 pm Thread Starter
james216's Avatar
Good lord that was ridiculas wasn't it.
I'm a 4 percenter.
james216 is offline
Radio Static / No Reception BeemerBoyLT K1200LT 1 Oct 20th, 2009 9:57 am
weatherband radio reception jpicco K1200LT 8 Mar 10th, 2008 12:39 am
Radio Reception AM vs FM bghubr K1200LT 8 Nov 25th, 2007 9:47 am
RT Radio Reception The_Oracle RT Series 4 Sep 24th, 2006 11:04 pm
XM radio reception poor Vagabond Satellite Radio 3 Apr 29th, 2006 10:41 am
