Oil for the Gearbox and FD - BMW Luxury Touring Community
post #1 of 10 Old Mar 21st, 2014, 6:19 pm Thread Starter
Probably this is a pretty common question...
But I couldn't find a definitive thread (or didn't look hard enough)
Can I use Fully Synthetic Hypoid 75W-90 oil on my gearbox?
What about the final drive? What oil? same 80/90, or is it 80/140?
Thanks!
mondrage is offline
post #2 of 10 Old Mar 21st, 2014, 6:28 pm
zippy_gg's Avatar
Re: Oil for the Gearbox and FD
You can use the same fluid for the transmission and the final drive, either dino or synthetic, and both 75W-90 and 80W-140 will do... Just use quality lubricants and you will be good!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 10 Old Mar 21st, 2014, 6:33 pm Thread Starter
Thanks!
I found an answer (extended) also here: http://www.i-bmw.com/showthread.php?t=39603
Thank you!
mondrage is offline
post #4 of 10 Old Mar 21st, 2014, 7:24 pm
sailor's Avatar
Originally Posted by mondrage View Post
Thanks!
Thank you!
Within that link (long thread on the K1200RS forum), the most important post is the following:
"Ordinary 75W90 or 80W90, GL-5 rated oil is all BMW calls for. Synthetic or mineral oil, makes little difference (the stuff labelled "synthetic" or "full synthetic" usually isn't, anyway)."
Just keep-it-simple - there is no need to pay twice the amount for that oil - neither is there any proof that the Final-Drive will last longer with the most expensive stuff. Ask John Z (jzeiler) here if you want a 2nd or 3rd opinion ;-)
John (Montreal, CANADA)
sailor is offline
post #5 of 10 Old Mar 21st, 2014, 7:53 pm
I use Walmart full synthetic! On the rear drive I do change it frequently just to keep up with the drives condition. That is more important than what you put in it.
But seriously the transmission on the LT does seem to shift better if you move from Dino to synthetic. Made a believer out of a fellow in Canada who had already bought a spare transmission. Told him to give it a little time and sure enough all his shifting issues vanished.
post #6 of 10 Old Mar 22nd, 2014, 7:46 am
rattler50's Avatar
I use Royal Purple synthetic. It's a nice purple color...........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #7 of 10 Old Mar 22nd, 2014, 8:40 am
Gold Supporter
GHOSTRACER's Avatar
Amsoil 75w-90 at every oil change. Maybe a little anal, but, a ounce of prevention......
USN Retired
IBA #37743
2005 K1200LT O'l Blue (Mine)
2002 R1150RT (Hers)
Cage-2006 SLK 280
Previous Rides: 2006 VTX 1300R, 1986 CB650 Nighthawk, 1982 CM450, Countless Dirt Bikes
GHOSTRACER is offline
post #8 of 10 Old Mar 22nd, 2014, 11:30 am
blueknightga6's Avatar
In the For What It's Worth department.
I just changed all three oils. For the transmission and FD I once again used Valvoline 80w90 GL5 (NON synthetic) gear oil as I've used for the past few. As both drained I could tell they were still a dark golden brown. Darker than when they went in, but still golden and translucent.
Chris Ehlbeck
blueknightga6 is offline
post #9 of 10 Old Mar 22nd, 2014, 1:33 pm
gbob's Avatar
I use Redline 75/90 gl5 and noticed softer ,smoother shifting.
Redline will confess its base stocks , no BS double talk. Look up MSDS for different oils , not much BS double talk allowed there.
Bob g
99LT sold
11RT
gbob is offline
post #10 of 10 Old Mar 22nd, 2014, 7:25 pm
UNclebudintx's Avatar
My new to me 02 lt only has 7k mikes on it.. not knowing the maintenance history i changed all the oils last weekend. I wen t all synthetic, mobile one for engine, and lucas 70/90... thinking now maybe I should r&r the coolant , and do a brake flush, I might let the dealer do the brake flush.
I too change the final drive oil with ever engine oil change. ? More so to just monitor the condition
Unclebud in TX
Plainview TX
2007 Kawasaki KLX300r (dirt days)
1969 HONDA TRIAL 90 ( miles of smiles)
200? Unigo ( AKA The Pig)
2002 K1200 LT (AKA Nicci )
2004 Bushtect Roadstar (AKA Elli)
2014 R1200GSA (AKA FreeBird)
OTHER BIKE I HAVE OWNED
2004 R1150 GS (crashed) (AKA GRAY WOLF)
2004 R1150 RT ( Sold) (AKA SILVER BULLET)
1981 KAWASAKI KZ1000ST (SOLD)
1991 HARLEY SPORTSTER 883 (SOLD)
The flogging will continue untill morale improves!
UNclebudintx is offline
RT Gearbox oil change BigKev RT Series 9 Sep 5th, 2013 4:56 pm
Oil filter question, r1100rt (1996) rabbipal RT Series 5 Jun 15th, 2011 10:37 am
Gearbox oil change on sidestand ? simoncharles K1200LT 10 Jan 31st, 2011 10:30 am
Draining Gearbox Oil on LT tip ronslaverda K1200LT 13 Jul 31st, 2010 12:58 pm
Gearbox oil "creamy" simon K1200LT 5 May 19th, 2008 3:01 pm
