Stripped Rotor Bolt - BMW Luxury Touring Community
post #1 of 2 Old Mar 19th, 2014, 5:50 pm Thread Starter
mactuba's Avatar
Stripped Rotor Bolt
I wanted to get rid of the rattle and clang of the infamous loose rear rotor by replacing it with the EBC rotor and pads. The wheel came off nicely and I was ready to tackle the rotor removal. I used a heat gun on one of the rotor bolts and I thought I got it up to a high enough temperature to release the loctite. I put the hex wrench in and ended up stripping the bolt. UGH! Well, I searched the forum and found that someone had just drilled the bolt heads off (leaving the threaded part in place), and replaced the new rotor over the "studs" that were remaining. It was explained that the rotor bolts are only there to hold the rotor on when the wheel is removed as the wheel studs hold the whole assembly together. Is this a possible solution to my stripped rotor bolt problem? Or, do I need to try to somehow remove the bolts and replace them (I'm worried I will be completely frustrated by this). Thanks for your help.
mactuba is offline
post #2 of 2 Old Mar 19th, 2014, 6:57 pm
Re: Stripped Rotor Bolt
You may want to some day but the wheel lug bolts hold it just fine. If one of the screws is OK it will be enough to hold the rotor on when the wheel is off (as well as the caliper holding it).
Stripped threads. Now what?? asteude K1200LT 17 Sep 17th, 2013 10:12 am
Rocker arm gap; stripped valve cover bolt JayJay RT Series 3 Mar 4th, 2013 2:38 pm
Rear shock preload tensioner stripped smahon K1200LT 5 Jul 10th, 2012 1:58 pm
Stripped thread- Now what? beemer100 K1200LT 20 Oct 18th, 2010 11:45 am
Stripped Cylinder Cover Bolt rshondo RT Series 8 Jan 20th, 2010 1:56 pm
