Eliminate Servo Brakes? - BMW Luxury Touring Community
post #1 of 14 Old Mar 19th, 2014, 1:26 pm Thread Starter
I have a 2005 with the servo brakes. The brakes failed last fall. I've put off dealing with it all winter, and now it's time to bleed the system and get the verdict.
Just in case the worst has happened, has anyone eliminated the servo entirely? I watched a YouTube video of a private bike mechanic demonstrating the complete elimination of the servo system on a different BMW model. (It involved a lot of uses of the F-word every time he'd mention the servo brakes.) He's eliminated the system for several customers.
Basically you bend up some custom brake lines and fittings to splice everything together, and simply get rid of the big, heavy, expensive, silly, useless servo. You also lose your ABS in the process, which matters to some people, but not to others. And what you end up with is....regular motorcycle brakes. No serious increase in effort. Just front and rear brakes, like God intended, and a couple thousands bucks in your pocket.
Has anyone done this on their LT? There is NO WAY I'm replacing that unit. I'll burn the bike first.
Bitsko is offline
post #2 of 14 Old Mar 19th, 2014, 1:29 pm Thread Starter
Re: Eliminate Servo Brakes?
By the way, one of the comments on the video was, "What if I try to sell it and the buyer won't buy it without the system?" Answer: "Find a different buyer who knows how to ride a motorcycle."
Hard to argue with that.
Bitsko is offline
post #3 of 14 Old Mar 19th, 2014, 3:23 pm
johnbaker15's Avatar
That would most likely be Chris Harris out of Manchester New Hampshire, he just closed his repair shop after 13 years.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #4 of 14 Old Mar 19th, 2014, 4:23 pm Thread Starter
I believe you're right. I'm just wondering if it's been done with an LT. Just in case. If not, for $3000 I'll happily be the guinea pig.
This may be encouraging: I installed a new battery and checked the servo function.....and noticed that the bike is leaking brake fluid like a sieve out of the front brake line, right where the line is attached to the fork just above the caliper. Seems like that might cause some issues, eh? I HOPE that's the problem. The servo sounds like it's struggling, but maybe they always sound like that. I don't know. The servo brakes may be the worst idea BMW has had since the Isetta.
Knock on wood, but I suspect the brake line might be less expensive than a servo. Though it would be my luck if they're both toast.
I'm not rich enough to live on the brink of doom like this. I may sell the bike when I get it fixed and then hie me to the Triumph dealer and pick up a Tiger.
Bitsko is offline
post #5 of 14 Old Mar 19th, 2014, 6:04 pm
Did he close it or get closed? I am not sure I would advertise on YouTube that I was disabling a safety system. Don't know that it is a legal issue in the criminal sense, but it is pretty much the same as walking through a lawyer convention wearing a "sue me" sign on your back.
post #6 of 14 Old Mar 19th, 2014, 6:07 pm
His web site is still up.
http://affordablebeemerservices.com/AboutUs/
post #7 of 14 Old Mar 19th, 2014, 8:55 pm
james216's Avatar
If you do have a servo or ABS issue Try. www.modulemaster.com. They do rebuilds.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #8 of 14 Old Mar 19th, 2014, 11:42 pm
chuckle's Avatar
I went with a full set of Speigler brake lines when my rear brake line started leaking. Cheaper than OEMs and the work better as well as look better.
Chuck
chuckle is offline
post #9 of 14 Old Mar 20th, 2014, 7:27 am Thread Starter
Servo brakes are not a safety system. ABS is, but many bikes with ABS have a "disable" button.....and most bikes still don't have it at all.
Brakes that require electrical power to operate properly are a safety LIABILITY. It's got to be the dumbest thing I've ever encountered. BMW apparently agrees, since they stopped doing it.
Bitsko is offline
post #10 of 14 Old Mar 20th, 2014, 7:32 am Thread Starter
Thanks. I'll keep that in mind!
My original question stands.....and now I'm wondering if other ABS units WITHOUT the servo function can be spliced in.
I guess anything is possible if you have the know-how.
Bitsko is offline
post #11 of 14 Old Mar 20th, 2014, 9:41 am
He announced the closing on his Utube channel, starting a new venture. Something called Team monkey?
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
post #12 of 14 Old Mar 20th, 2014, 8:17 pm
smahon's Avatar
I replaced my OEM lines with Speiglers as well. When I did mine, that same hose that is leaking on yours was bent in a U (supposed to be straight) and about to burst. No doubt this is your issue, as this is a very common failure point in this system. I suspect you could just replace that one line, bleed it, and all would be well, but the Speiglers are just way stronger than OEM. If you intend to bleed the entire system, then that is the time to replace all the lines.
'15 GTLE
smahon is offline
post #13 of 14 Old Apr 9th, 2014, 7:03 am
johnT's Avatar
I am thinking about doing the same thing
My servo unit stopped working
I am thinking of eliminating everything and running
New braided lines.
Has anyone done this before?
Any tips?
johnT is offline
post #14 of 14 Old Apr 9th, 2014, 7:35 am
johnT's Avatar
Actually would like to remove the servo assist
Linked brakes and abs.
I hate the way this bike goes through rear
Brake pads, especially since I rarely use the rear brake.
Earlier LT's didn't have any of this stuff and they
Get down the road just fine...
With less maintenance headaches and $$
johnT is offline
04 RT Servo Brakes Hiram RT Series 7 Jul 4th, 2013 4:08 pm
Source to Fix Servo Brakes Modules twkBMW RT Series 1 May 22nd, 2012 3:37 pm
Would you pass on a used RT if it had servo brakes? Humbucker RT Series 21 Mar 11th, 2011 11:34 pm
What year on servo brakes cliffy109 GS Series 5 Jan 29th, 2010 1:24 pm
No more servo assited brakes for bmw? tmgs K1200LT 7 Aug 16th, 2007 8:58 am
