Clutch slipping above 6000 RPM - BMW Luxury Touring Community
post #1 of 6 Old Mar 17th, 2014, 5:19 pm Thread Starter
MattKas's Avatar
My 2009 LT with 27K miles on it started slipping clutch if I rev the throttle to above 6000 RPM. It is more noticeable at 4 and 5th gears. Is there anything I should do now or shall I wait to see if or when I will completely loose the clutch? Any opinions?
Matt Kas
"Riding Year around"
MattKas is offline
post #2 of 6 Old Mar 17th, 2014, 5:21 pm
Re: Clutch slipping above 6000 RPM
Very common problem. Get ready for a rebuild. I nursed mine along for about a year, but in the end you'll have to get a new clutch. I paid the dealer about $2,200 for the whole job.
WildernessJeep is offline
post #3 of 6 Old Mar 17th, 2014, 5:24 pm
when the clutch is slipping it is generating a lot of excess heat in the clutch carrier which can cause damage to the friction surfaces also it destroys any rubber parts that are attached - seals
up to you how long you leave it but makes sense to repair earlier rather than later
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 6 Old Mar 17th, 2014, 9:23 pm
To edit, when I say i "nursed mine along", that was with a deliberate effort to reduce slippage (use lower gears and higher RPM's). He is correct; you can cause additional damage if you don't change your driving habits and continue to ride.
post #5 of 6 Old Mar 17th, 2014, 9:36 pm
mwnahas's Avatar
You're at 4th and 5th gears at 6000 rpm? Slow down.
You're in for a clutch rebuild. Happened to me at 60K miles. Got so bad that even the cruise control wouldn't hold speed on the highway and disengage.
Just Go
Cleveland Ohio
mwnahas is offline
post #6 of 6 Old Mar 17th, 2014, 11:26 pm
RonKMiller's Avatar
Find a concrete wall at 6pm during the work week - and place your front tire on it. Rev the hell out of that sonomabeach and slip the clutch in 2nd gear until it gets red hot, smoke starts coming from the crankcase, your rear tire is chirping and your final drive is puking gear oil.
Then, let it cool down overnight. You've just burned off all the accumulated "glaze" from weak titted, low rev shifts.
Problem solved. It worked for me over 10K miles ago... and that includes towing a trailer for most of them.
..and if not - the neighborhood kids got a good show. You'll forever be known by them as "that cool guy down the street".
Your local dealer will also benefit from the $3K you're about to spend to make it right again. You have nothing to lose. Resistance is futile.
"Like Butt-ahh!"
RonKMiller is offline
Does too much clutch slipping on the LT cause excessive clutch wear? greg09 K1200LT 19 Aug 30th, 2010 7:13 pm
What's worse then a slipping clutch on a 2005 LT? smithbs K1200LT 6 Apr 22nd, 2009 11:19 am
03 LT clutch slipping at 61K the_rocketman K1200LT 2 Aug 10th, 2008 3:24 pm
