where does your clutch engage? - BMW Luxury Touring Community
post #1 of 16 Old Mar 15th, 2014, 4:15 pm Thread Starter
fpmlt's Avatar
Finished buttoning up my 01 after installing new spring plate. Bled the clutch system and took it for a spin.
Seems like my clutch engages sooner now that before. I'm engaging after releasing the lever about 3/4". Is that normal? Or sooner than it should? It seems to release completely, as it shifts smoothly, and goes into 1st or 2nd without grinding the gears.
fpmlt is offline
post #2 of 16 Old Mar 18th, 2014, 6:07 pm
cluainsi's Avatar
Re: where does your clutch engage?
check what setting your clutch lever is on . If 1 then change to 2 or 3 to give a longer throw and move the release point farther forward.
cluainsi is offline
post #3 of 16 Old Mar 18th, 2014, 6:17 pm
cluainsi's Avatar
When bleeding the clutch or flushing the brakes change the lever setting to 3 to give a longer throw and pump more fluid with each squeeze.
cluainsi is offline
post #4 of 16 Old Mar 26th, 2014, 12:46 am
BecketMa's Avatar
One time I drove my self crazzzy!!
I changed the brake fluid one day. Another day I changed the clutch fluid and could not figure out what I had done wrong?!! It just didn't feel like the brake did!!
After redoing everything a few times, I pulled the clutch lever all the way, started her, backed out of my garage and went for a ride--worked perfectly.
don't know why I knew the clutch had to feel like the brake did?
BecketMa is offline
post #5 of 16 Old Mar 26th, 2014, 10:58 am
14wntr's Avatar
Mine did the same thing after I changed out the clutch and slave cyl.
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #6 of 16 Old Mar 26th, 2014, 11:52 am
As did mine... Can be explained by the thicker clutch plate / way how spring plate works.
Born to be wild so why not
C-A-D is offline
post #7 of 16 Old Mar 26th, 2014, 12:12 pm Thread Starter
fpmlt's Avatar
OK, thanks guys. I had it out for a spin the other day, and it's probably just going to take some getting used to - the engagement point. Not a bid deal, just thought maybe I'd done something else wrong.
fpmlt is offline
post #8 of 16 Old Mar 26th, 2014, 1:22 pm
Having a decent understanding of his hydraulic brakes and clutches work, I am having a hard time contrmplating this. The engagement point should not change from thick to thin clutch disk unless the travel of the slave cylinder is insufficient for the normal range of thickness.
Same thing for brakes. The point your brakes engage should not depend on how worn the shoes/pads are.
post #9 of 16 Old Mar 26th, 2014, 1:38 pm
dukey33's Avatar
The difference is the clutch has a return spring that pulls the pressure plate away from the friction disc whereas the brakes do not have a positive release, only the runout of the disc to push the pads away.
So the pulling the clutch lever results in a full stroke of the cylinder regardless of the thickness of the friction disc and that will result in an earlier engagement when the disc is thicker than when it is worn out.
-2000 K1200LT
dukey33 is online now
post #10 of 16 Old Mar 28th, 2014, 7:01 pm
I haven't had an LT apart, but every other clutch I have seen has the clutch diaphragm spring clamping the pressure plate against the clutch disk, not pulling it away.
post #11 of 16 Old Mar 28th, 2014, 8:02 pm
You are right but when you pull the lever the rod goes forward against the diaphragm spring (3) compressing it and this releases the pressure plate (4) from the disk. When you release the lever then the spring (3) returns to normal state pushing the pressure plate (4) into contact with the disk (5) and traps it against the "flywheel" (6).
Just like any car, only backwards. Leave it to BMW.
post #12 of 16 Old Mar 29th, 2014, 9:32 am
Thanks, John, the principle of operation is still the same as most other clutches I've worked on. I still disagree with the others who suggest the clutch lever position at engagement should vary with friction disk thickness.
Yes, the position of the slave cylinder piston and actual rod will vary with disk thickness, but the lever position should not. As the clutch wears, the volume of fluid in the slave will decrease as the piston moves away from the pressure plate as the disk gets thinner, but this just means that the fluid level in the master cylinder will increase as the excess fluid gets pushed into the master cylinder reservoir when the port is uncovered as the master cylinder piston goes to it's starting position.
The length of stroke of the slave cylinder is determined by the master cylinder. Since it moves the same amount of fluid each time you squeeze the lever, the slave will move the same distance each time. Since the reference point for the start of the slave cylinder stroke is the fully engaged position the friction point during clutch engagement is also referenced to the fully engaged position.
The master cylinder doesn't know the starting position of the slave cylinder. It only pushes it a certain distance and releases it. That stroke length will always be the same and will always start at the same reference which is the fully engaged position. So, the clutch engagement point at the clutch lever should not vary with clutch disk thickness since the hydraulics self adjust to let the slave cylinder continuously retract as the disk wears.
post #13 of 16 Old Mar 29th, 2014, 10:37 am
Enjoy The Ride
saddleman's Avatar
The lever engage position is much different with a new clutch vs a worn clutch disc.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #14 of 16 Old Mar 29th, 2014, 11:23 am
Why? Makes no sense to me and that has not been true for other vehicles I own or have owned. Just trying to understand what is unique about the LT clutch. And understand why the LT doesn't self adjust like other hydraulic vehicles do.
My 94 Chevy clutch works the same as when new and it's original clutch had 146,000 miles of snow plowing. It has to be well worn, but engagement point is unchanged. My 06 Sonata has 98,000 on original clutch with no change in engagement.
Just not seeing the difference with the LT from the diagram a John posted.
post #15 of 16 Old Mar 29th, 2014, 12:20 pm
all my vehicles have been standards - new disk and pressure spring feels quite different from worn out clutch - more bite at contact - might feel like it is engaging differently at lever
diaphragm spring fingers do not lose strength evenly/equally and can affect feel
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #16 of 16 Old Mar 29th, 2014, 12:39 pm
That's a good point. I definitely see how a stiffer spring would feel different. No question there.
Clutch failure sonnata K1200LT 12 Aug 14th, 2007 11:19 am
latest clutch analysis cyclecamper K1200LT 17 Feb 27th, 2007 10:00 pm
