EHCS - BMW Luxury Touring Community
post #1 of 9 Old Mar 15th, 2014, 7:24 am Thread Starter
rattler50's Avatar
Exclamation EHCS
I've overhauled mine twice. The first time I cut the seal installing the rod. The rod was pitted from water so I got a new rod and seals and overhauled it again. Now it leaks worse than ever. I must be doing something wrong....
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #2 of 9 Old Mar 15th, 2014, 11:36 am
Re: EHCS
Seals all facing the right direction?
post #3 of 9 Old Mar 15th, 2014, 3:33 pm Thread Starter
rattler50's Avatar
Re: EHCS
As far as I can tell, the seals are facing the right direction. I installed them just like I've installed thousands of seals in automatic transmissions. With the pressure behind the seal I figure there's only one way it can go and hold pressure. That's why I'm puzzled by the leak.........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #4 of 9 Old Mar 15th, 2014, 8:38 pm
Re: EHCS
Where is it leaking? At the shaft?
post #5 of 9 Old Mar 15th, 2014, 8:41 pm Thread Starter
rattler50's Avatar
Re: EHCS
Yes, it's right at the end. At first it just leaked a couple of drops but the last time I used it there was a solid stream under the bike......Any ideas?
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #6 of 9 Old Mar 15th, 2014, 8:43 pm
Re: EHCS
Sounds like the rod damaged the seal. The cup was facing the piston, correct? i.e. This side faces the piston on the shaft.
post #7 of 9 Old Mar 15th, 2014, 8:56 pm Thread Starter
rattler50's Avatar
Re: EHCS
Yes, the cup faces the piston. I smoothed the edges of the shaft and used Teflon tape to get the rod through. No leaking at first.
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #8 of 9 Old Mar 15th, 2014, 8:59 pm
Re: EHCS
Hopefully you used a new seal. I'll send you a PM.
post #9 of 9 Old Mar 17th, 2014, 3:02 pm
Foiler's Avatar
Re: EHCS
I am in the same boat. I thought I had the seal pictured in backwards but now........i am fairly certain i have it in the same way JZ is saying.
Foiler is offline
EHCS checking switches and relays tibbe K1200LT 14 Jun 24th, 2013 3:28 am
EHCS flushing and elec. motor maintenance TSQUARED North West 1 Mar 26th, 2013 7:34 am
Bleeding/Flushing fluid in EHCS on 05+ LT's TSQUARED North West 2 Apr 27th, 2011 3:15 am
EHCS motor problem - solved. pozo_izquierdo K1200LT 2 Dec 4th, 2010 7:48 am
Most likely cause for EHCS not working? atps1234 K1200LT 4 Mar 11th, 2007 2:29 pm
