Should this Bolt be Loose? - BMW Luxury Touring Community
post #1 of 5 Old Mar 14th, 2014, 8:46 pm Thread Starter
Captain_Wayne's Avatar
I have a 2000 LT. I had new shocks installed by a dealer and when I recently took off the tupperware for maintenance and I noticed that the right side rear bolt that attaches the seat frame to the aluminum frame was loose (see photos).
The bolt and nut were tight together but the bolt and nut rotated as one unit easily by hand. I suspect the dealer cross threaded this bolt and forced the nut
Is my suspicion correct, or should this bolt normally rotate for some reason?
Thanks.
ID:	50946   Click image for larger version
ID:	50954   Click image for larger version
ID:	50962   Click image for larger version
______________
Captain Wayne
Currently owned,
1966 R50
2000 K LT
Captain_Wayne is offline
post #2 of 5 Old Mar 15th, 2014, 8:06 am
mtrevelino's Avatar
Re: Should this Bolt be Loose?
It should be tight.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #3 of 5 Old Mar 15th, 2014, 10:42 am
Upper left hand corner of last picture, is that the computer and has it been replaced? That bike is really clean underneath
mexicoboy is offline
post #4 of 5 Old Mar 15th, 2014, 6:03 pm
Axle's Avatar
yes it is, Its got rhine west sticker on it so I would assume the cpu has been re-chipped, has it also got aftermarket exhaust?
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #5 of 5 Old Mar 15th, 2014, 9:49 pm Thread Starter
Thanks Mike for the reassurance that the bolt should be tight. My brother and I went over the entire frame of the LT and found other loose bolts - I guess the dealer forgot to torque them to specs.
It's a good thing BMW overbuilds the bike, the loose bolts didn't cause any noticeable problems when riding, imagine if you had that problem with some other brand bikes.
Lesson learned - as much as I would like to trust a dealer that I pay a premium price for work done - next time I'll check all the possible items that could have been neglected.
Mexicoboy and Linton: concerning the CPU/ Rhine West chip. Yes a Rhine West chip was installed by me and the stock exhaust was kept. At the same time I installed iridium spark plugs, removed the air temperature sensor, and replaced the "wet" K&N air filter with the original BMW (Mann) paper element. The combination gives me smoother accelaration and the bike keeps on pulling without any hesitation whatsoever, I guess some would say a "better linear performance". I keep up with my brothers' K1600GT (except when he sometimes cracks his throttle - I don't think that many vehicles could keep up with him - but I try, and the LT keeps pouring on the speed). Oh did I mention, a clean bike always seems to go faster.
______________
Captain Wayne
Currently owned,
1966 R50
2000 K LT
Rear Shock Upper bolt size sgroover K1200LT 3 Oct 30th, 2013 10:03 pm
What bolt? budzee K1200LT 13 Oct 21st, 2011 12:48 pm
99 R1100RT shift lever gets loose? biometrics RT Series 3 Oct 11th, 2011 7:06 pm
K1200LT Rear shock mounting bolt Newport Shocks and Suspension 0 Nov 13th, 2010 3:25 am
Shock bolt mounting BMWphreak K1200LT 4 Apr 18th, 2007 11:46 am
