clutch not working - BMW Luxury Touring Community
post #1 of 6 Old Mar 13th, 2014, 11:16 pm Thread Starter
clutch not working
2 years after selling my last 05 LT, I've just bought another! This is my 3rd 05 in 8 years...
Previous guy was the original owner and appears to have taken extremely good care of her. She has only 10k on the clock and looks barely a year old as its been garaged and polished regularly. He changed the oil (synthetic) for me and said he changed all the fluids last year ). The service manual conveyed with the purchase. Sorry for the Soap opera, but I thought these details might be important.
I made the trip from NJ down to DC on Superbowl Sunday and she drove perfectly (180 miles). She's been parked in my garage on the centerstand ever since.
As this has been the coldest and snowest winter in years, I hadn't had an opportunity to ride til this evening as I also just recently purchased a used Gerbing jacket and gloves. She fired right up and I backed her out the garage. As I went to turn the bike around toward the street, the infamous tip over occurred. This was my softest drop ever on the left side at 0 mph. I caught her and let her down gently, before reversing myself (using the proven backside walk up method) and easily lifted her back upright. I hadn't had to do that in years!
So all plugged up... me, my new jacket and gloves were underway, when I immediately felt the clutch go weird. She shifted okay at first but eventually my 20 mile inaugural ride turned into a "limp home and pray" event. The 1 2 3 dial on the clutch handle clicked easily, giving some resistance but ultimately things aren't really engaging...
Anybody have any good news? Should I attempt a limp to my nearest service or tow?
P.S.
I live 25 mins to Bobs BMW or 20 mins to Battley Cycle...
videojoe is offline
post #2 of 6 Old Mar 13th, 2014, 11:36 pm
zippy_gg's Avatar
Re: clutch not working
I suspect air got into the system when the bike took a nap, especially if the left reservoir was not at full level.
The good news is that bleeding the air out is not difficult. Not sure if you do your own maintenance; otherwise it is something the dealer can do rather quickly.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 6 Old Mar 14th, 2014, 8:32 am
First instinct of mine is "+1"...
Born to be wild so why not
C-A-D is offline
post #4 of 6 Old Mar 14th, 2014, 7:33 pm
Just rotate the bars to the far right and put a tie on the clutch lever holding it in part way. Leave over night and check again in the morning. This may allow the air to escape back into the reservoir.
post #5 of 6 Old Mar 14th, 2014, 8:33 pm
deanwoolsey's Avatar
I'll disagree with John on this one. Open the reservoir cap and see how much fluid is in there. Holding the lever down blocks the relief hole between the master cylinder and the pressure in the slave cylinder, so just make sure the hole isn't clogged and let it set overnight with the bars turned all the way to the right so the reservoir is the highest point in the system. If clogged, clear it with a small diameter wire. Then in the morning, gently and slowly work the lever and watch for air coming from the relief hole. Hopefully you'll see some and that'll cure it. Cover the hole with a quarter before you work the lever or fluid will shoot everywhere. If it's still soft you'll need to pull the right panel and try bleeding the clutch.
deanwoolsey is offline
post #6 of 6 Old Mar 15th, 2014, 7:42 pm
Notice I said "part way", as this does open the vent hole (as in the squirt you get). Pull it all the way in and it does block the vent.
I fought the clutch and the clutch won. Slammer Chit Chat 3 Apr 14th, 2013 11:56 pm
Clutch Failures - 2 at 20,000 miles Hanshi K1200LT 49 Oct 5th, 2012 5:53 pm
Clutch adjustment luis K1200LT 10 Sep 5th, 2010 11:08 am
Clutch Party Report! hallzee K1200LT 5 Jan 17th, 2010 8:06 pm
