Replacing clutch actuation pressure hose, lower section - BMW Luxury Touring Community
post #1 of 9 Old Mar 11th, 2014, 6:10 pm Thread Starter
cluainsi's Avatar
Hi All, My clutch pipe at slave end is leaking, is it possible to replace this clutch hose without too much work?
cluainsi is offline
post #2 of 9 Old Mar 11th, 2014, 6:59 pm
Re: Replacing clutch actuation pressure hose, lower section
You will have to pull the wheel but you should be able to get to the bolts that hold the lines as they are on the side of the slave. You have to pull the swing arm to remove the slave. Not a lot of room to work in. The line here shows where the swing arm is in relation to the slave (picture is tilted from level).
post #3 of 9 Old Mar 12th, 2014, 5:22 am
murray's Avatar
I would first try to snug the fitting at the slave. You may get Lucky Laddie..
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #4 of 9 Old Mar 12th, 2014, 2:16 pm
14wntr's Avatar
I had to replace mine too since it was heavily rusted. Not too bad once you get the swing arm out of the way. Seal up the top protector hose with silicone to prevent water from running down and rusting it.
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #5 of 9 Old Mar 12th, 2014, 7:28 pm Thread Starter
cluainsi's Avatar
I found that by removing the exhaust and crossmember I was able to undo the hose connection to the slave, not for big hands. The end of the hose has rusted but the leak appears to be coming from the crush washers which had been reused last year when I replaced the slave. For the moment I will replace the washers and test the pipe. Hopefully this will get me out of trouble.
cluainsi is offline
post #6 of 9 Old Mar 12th, 2014, 7:42 pm
Enjoy The Ride
saddleman's Avatar
I had one of the banjo bolts crack when I removed it once & it leaked like it was a bad crush washer.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #7 of 9 Old Mar 13th, 2014, 6:21 am
murray's Avatar
Hmmm, as noted above. Hope it's a good outcome.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #8 of 9 Old Mar 13th, 2014, 10:16 am Thread Starter
cluainsi's Avatar
Smile Re: Replacing clutch actuation pressure hose, lower section
it is not necessary to remove the swing arm to replace this pipe, just a little tight to work but can be done.
cluainsi is offline
post #9 of 9 Old Mar 18th, 2014, 5:03 pm Thread Starter
cluainsi's Avatar
This cured my leak, thanks for your help
cluainsi is offline
Two Up Tire Pressure? gphusky1 RT Series 43 Sep 20th, 2013 8:55 am
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
Replace Lower Clutch Pressure Hose ksailor North East 1 Sep 24th, 2006 8:43 pm
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 3:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 9:38 am
