Dead Battery then will not start - BMW Luxury Touring Community
post #1 of 11 Old Mar 11th, 2014, 12:11 pm Thread Starter
I have had my K12 in climate controlled storage but forgot to hook up my battery tender. Battery was dead so I put the charger on it for a couple of hours. Alarm went off when I pushed the bike outside. Now the bike will crank over, but will not start. Any ideas?
Jamie Kiel
2002 K1200LT Silver
2005 Harley Davidson Springer Classic
jamiekiel is offline
post #2 of 11 Old Mar 11th, 2014, 2:02 pm
Re: Dead Battery then will not start
Because it turns over I don't think the alarm is keeping it from starting. The first thing I would listen for is the fuel pump turning on when the key is turned on. Should be a very short burst. Easier to hear with the gas cap removed.
Next pull the clutch in and make sure the gear shift, although it may indicate neutral it may not be there.
Next make sure the reverse lever is sitting securely in the unactivated position.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #3 of 11 Old Mar 11th, 2014, 4:11 pm
deanwoolsey's Avatar
The "will not start" checklist:
Neutral light on
Forward-reverse switch in forward
Side stand up
Kill switch centered to run position
Alarm properly reset (this may be your issue)
deanwoolsey is offline
post #4 of 11 Old Mar 11th, 2014, 7:10 pm
Neutral light on
Side stand up
That should be a "will not CRANK" check list vs. will not start.
I would look at fuel as the culprit.
post #5 of 11 Old Mar 12th, 2014, 9:19 am
I am looking at the OptiMate 4 DUAL PROGRAM BMW CAN-bus edition to maintain my battery its a BMW battery that is just under 2 years old. I have been using a regular battery charger to periodically charge the battery. Rode it for several hours on Monday and fear when I check it later this morning it'll not start.
Anyone have any experience with this item?
TIA Douglas
dsherman is offline
post #6 of 11 Old Mar 12th, 2014, 10:55 am
I have used the Battery Tender Junior on my 1999 K1200 and 2010 HD Ultra for years with great success.
Wimauma is offline
post #7 of 11 Old Mar 12th, 2014, 12:12 pm
dvgb131's Avatar
TIA Douglas
The LT is not CAN-bus.
+1 for Battery Tender and Junior.
Doug B.
2000 LT purchased July 2013
dvgb131 is offline
post #8 of 11 Old Mar 12th, 2014, 1:26 pm
mycamel's Avatar
Originally Posted by dvgb131 View Post
~+1 for Battery Tender and Junior.
Also +1 on Battery Tender. Just leave it connected when not riding and all will be well.
(Unless you have a short somewhere and it can't maintain-then you have a problem of another kind.)
Mike Hammel (My Camel) [WB9GMO/4]
2002 K1200LT-E
1998 ACE Burgundy (now 'retired')
1998 ACE Yellow/Black Tourer (now 'retired')
19?? Suzuki 500 (now 'retired')
1962 modifed 49cc>~55cc Sears MoPed (LONG 'retired')
US Army Security Agency 0582L68 ('64-68)
moderator and owner:
Retired from the business world (finally--sigh --poor and proud)
Georgia Patriot Guard Riders
Roswell, GA
mycamel is offline
post #9 of 11 Old Mar 12th, 2014, 4:51 pm
nearmisses's Avatar
Did you check the actual battery voltage using a multi-meter on DC? Mines 2 years old and dead outside now too. One dead cell, 10.something volts. If your voltage is below 11.7 or 11.4V? I believe the bike will not start. 2 years is about all a battery will last, maybe 3 if really properly maintained. Check what the others told you too, especially the reverse switch. I usually turn mine to reverse when winter starts in case somebody wants it more than me. I believe there is something in the alarm system that can turn it off also but I don't think they crank at all then. My alarm system quit once also and I can't remember if it would crank and not start or what, been 2 years for that fiasco. jzeiler above helped me with a fix there to by pass alarm. Yours may have quit too, what year is your LT?
Brian A. Brodhead
God created all men, Samuel Colt made them equal
2005 BMW K1200LT Goldie goodtime plastic fm rock'n roamer
1975 Triumph T160 750 restored "Heather" For Sale
nearmisses is offline
post #10 of 11 Old Mar 13th, 2014, 7:55 am
My LT is a '09. I Checked yesterday and the bike started, though I could tell that the battery was getting low. I thought the BMW LT was a CAN Bus system. Not sure where I read that.
dsherman is offline
post #11 of 11 Old Mar 13th, 2014, 6:28 pm
Nope LT is not CAN Bus. There is a circuit in the starter relay that prevents it from engaging below a certain voltage, 12.2 IIRC.
Won't start after battery change, doesn't unlock immobility security gramiras K1200LT 21 Mar 26th, 2017 11:20 am
Dead Battery 02 LT greggangi K1200LT 12 Apr 2nd, 2008 11:37 am
Dead Battery? k12robert Batteries, Chargers, & Electrical 2 Mar 11th, 2007 10:34 pm
Revive Dead Gel Battery? midwilshire Batteries, Chargers, & Electrical 16 Nov 26th, 2006 6:21 pm
