Spring plate sag - BMW Luxury Touring Community
post #1 of 6 Old Mar 10th, 2014, 3:24 pm Thread Starter
fpmlt's Avatar
Spring plate sag
Here's a pic I just took of the new (left) and old (right) spring plates. Old one had 97,000 miles and 13 years on it. I was actually expecting more sag than I see. Would be interesting to be able to measure the difference in spring tension between the two, but I don't have the means.
Just thought it was interesting.
fpmlt is offline
post #2 of 6 Old Mar 10th, 2014, 4:19 pm
Re: Spring plate sag
that is quite substantial altho strength is the most critical, anytime I have changed a clutch in one of my cars I have always replaced the spring/pressure plate.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is online now
post #3 of 6 Old Mar 10th, 2014, 7:14 pm
That looks impressive but not a realistic measure of spring sag since the contact point for the pressure plate is fairly close to the outer rim of the spring. But overall it does suggest that it should always be renewed with a new clutch. I did anyway even though I measured no difference in mine.
A better test would be to invert the springs and level the pressure plate on the spring and measure the distance to the reference point. That would show the sag on clutch pressure.
post #4 of 6 Old Mar 10th, 2014, 7:15 pm
That seems pretty substantial. Is there a BMW spec for the spring height?
post #5 of 6 Old Mar 10th, 2014, 7:55 pm Thread Starter
fpmlt's Avatar
I haven't seen any specs.
Really the only reason for posting this so that some other dumbass, such as myself, will just replace it the first time and not have to go through all this again.
fpmlt is offline
post #6 of 6 Old Mar 11th, 2014, 11:26 am
For me that difference looks like pretty big!
Born to be wild so why not
C-A-D is offline
Front Spring Info, If Available Dragonwing K1200LT 15 Feb 6th, 2014 2:21 pm
Newbie ESA question Dann323 RT Series 11 Mar 30th, 2012 3:29 pm
2010 R1200RT revealed by BMW jeffdean RT Series 44 Nov 17th, 2009 1:50 pm
Improved LT Clutch Plate? jarhead354 K1200LT 22 Apr 18th, 2009 7:07 pm
Cracked Footrest Plate when bike dropped RealWing K1200LT 6 Aug 21st, 2006 6:11 am
