ABS system removal on a 2005 - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 17 Old Mar 10th, 2014, 2:12 pm Thread Starter
Hi everyone I hope the answer to this is a "yes" has anybody managed to do an ABS servo modulator removal on a 2005 LT I'm having trouble with mine at the moment and a new unit is 1500 which is way out of my pocket at the moment. If the system is removed I don't think the speedo would work has anyone worked around this yet?
Cheers Bren
Airportech is offline
post #2 of 17 Old Mar 10th, 2014, 3:52 pm
james216's Avatar
Re: ABS system removal on a 2005
There are company's that rebuild them. One I believe is in Germany for about 1/2.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #3 of 17 Old Mar 10th, 2014, 7:19 pm
On an 05 and up you loose both the odometer and the speedometer as both signal come from the ABS. You could leave the unit in electrically but disconnect or bypass it hydraulically.
post #4 of 17 Old Mar 11th, 2014, 11:32 am
One interesting question (at least for me ) is: Has anybody successfully done this with newer (servo powered brakes). I mean are measurements of main & slave cylinders such that you get enough braking power after bypassing the servo-hydraulics? The old ABSII is simple and the braking power comes from the brake lever but are these servo-powered units built to operate perhaps only by servo? Perhaps stupid question but the system could have been designed so that you won't get enough braking power without servo.
Born to be wild so why not
C-A-D is offline
post #5 of 17 Old Mar 11th, 2014, 1:55 pm Thread Starter
I did wonder if that would work - just remove the hydraulics and leave the electrical circuit connected. Here in the UK it will pass its ministry test along as you remove the whole system, I'm hoping someone will chip in and say they've done it, I suppose it's only a matter of time before it's investigated.
Cheers Bren
post #6 of 17 Old Mar 11th, 2014, 2:04 pm Thread Starter
Maybe if the part numbers for the master cylinders were compared across the different systems, and the calliper piston surface areas were investigated and found to be the same as the other models you would think that it would give comparable braking efficiency. Does anybody have this info?
Cheers Bren
post #7 of 17 Old Mar 11th, 2014, 4:34 pm
james216's Avatar
Try modulemasters.com
I'm a 4 percenter.
james216 is offline
post #8 of 17 Old Mar 11th, 2014, 9:31 pm
My 2006 has hydraulic brakes only and I have all speedo, cruise, lights, etc functionality by doing what John mentions. I took the electronic piece off the iABS module and plugged it back into the large plug on the bike. This allows everything to work great.
Regarding the Master cylinders, yes they are the same size as the non-servo version of our K1200LT's and work great with straight hydraulic pressure.
Module Masters told me last month that they are not sure when they will be rebuilding the iABS modules, but could be in a few months. They been saying this since August 2013. I pulled my module in Sept and re-plumbed it with Speigler SS lines and I love it. Works great, quiet and smooth.
Very do-able and nice results on my bike. I've put several thousand on it since Sept with no issues at all. YMMV
Hope this helps.
Sammy
sgroover is offline
post #9 of 17 Old Mar 12th, 2014, 3:11 am Thread Starter
Hope this helps.
Sammy
That's good to hear thanks for your input, I have been offered a secondhand unit which I'm going to fit, it comes with a six month warranty so if it doesn't perform I will do a conversion, did you discard all the steel pipes and fit SS braided in their place?
Cheers Bren
post #10 of 17 Old Mar 12th, 2014, 8:37 am
timgray's Avatar
Hope this helps.
Sammy
This is awesome, I was wondering if BMW did the typical overengineering and put on tiny masters. Glad to hear the masters are normal sized and just plumbing around the Servo assist and ABS will make a bike functional again. I hope mine lasts for a good long time, but at least I have an option to go to standard brakes if needed.
timgray is offline
post #11 of 17 Old Mar 12th, 2014, 11:14 am
Hope this helps.
Sammy
Next time you have her stripped down, can you take some pictures of how it looks? I really like ABS, but I would not like paying to get it fixed should mine die.
post #12 of 17 Old Mar 12th, 2014, 11:38 am Thread Starter
That would be great
post #13 of 17 Old Mar 12th, 2014, 10:21 pm
Will do on the pics. I first re-plumbed using the metal brake lines, but after I saw how good the brakes worked, I removed them and went straight SS lines from each MC to the calipers. Got a custom set made by Speigler so it all matches up great. I love ABS too, but not the cost for this repair. Bleeding is so easy now too!
Sammy
sgroover is offline
post #14 of 17 Old Apr 5th, 2014, 10:11 am
Hi All, have read many threads on this subject. My 2003 LT . ABS failed before Xmas, I took it apart and the system running the front brakes had brake fluid that was almost black and had no servo assistance. Having removed the ABS unit and all the associated brake hoses, I reverted to conventional brakes. The only problem I have is that the speedo and mileometer do not work, I have retained the ABS module , I have also swapped the front ABS sensor to the rear but with no success , would this be down to a failure of the ABS module?
Tuatua is offline
post #15 of 17 Old Apr 5th, 2014, 1:00 pm
In your case you need to remove the circuit card from your ABS unit and insulate it. Then plug it back in so the speedo and odometer will continue working. The rear ABS sensor feeds the speedo and odometer signals to the ABS unit before sending them to the dash.
You will have the flashing warning lights but you can cut the brown/yellow wire on pin 10 and the brown/red on pin 9 to eliminate those warnings.
Frenchy likes this.
post #16 of 17 Old Apr 10th, 2014, 1:38 pm
johnT's Avatar
Great info.
johnT is offline
post #17 of 17 Old Apr 10th, 2014, 11:19 pm
james216's Avatar
Good to know Just in case. I really love the ABS. Saved me and a golden retriever who ran out in front of me on a 2 lane one dark night. Couldn't believe how smooth and controlled of a stop it was. But if it goes, not worth $2,200 to fix on a bike that's worth 6K..
I'm a 4 percenter.
james216 is offline
LT rear ABS ring removal Problem Rigger394 K1200LT 8 Jan 19th, 2012 6:08 am
BMW Bulletin on Installation of Steel Brake Lines rdwalker Bike Talk 5 Feb 12th, 2011 11:25 pm
BMW System V Visor removal ArthurCal Rider's Gear & Luggage 4 Jun 16th, 2008 8:08 am
abs system R1150 GS steeler34 Other R-Bike Discussion 1 Jul 23rd, 2007 8:08 pm
seat removal k1200 lt 2005 namrehwp Ergonomics & Rider Comfort 3 Apr 25th, 2006 11:59 am
