1200 mile inspection - BMW Luxury Touring Community
post #1 of 14 Old Mar 7th, 2014, 4:15 pm Thread Starter
Greetings everyone. I have a question about the valve clearance check on an '02 K1200LT. When is it done? It's embarrassing but my mileage is only around 12600 after all these years. I'll fix that soon, if it warms up a bit.
Being lazy and cold I took advantage of a local dealers winters specials and had brake service, tires, and a 12000 mile service done. Free pickup and delivery. Looking over the invoice I notice nothing about valves. Called and the rep told me no, valves get checked at 16000 miles. All references I can find point to 12000. Have things changed? It's certainly possible I'm confused. How about trans and final drive oil?
Thanks!
Of course the title should be "12000 mile inspection". Sorry.
johnbrock is offline
post #2 of 14 Old Mar 7th, 2014, 5:01 pm
zippy_gg's Avatar
Re: 1200 mile inspection
Probably just a valve clearance check at 12k miles, but the transmission and final drive gear oil should be changed.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 14 Old Mar 7th, 2014, 6:20 pm Thread Starter
Thanks, 12k is what I thought, for the valves and other two oils. I'll continue to research, and ill call the service manager tomorrow. I didn't specifically mention valves beforehand as I thought it was part of the 12k inspection.
post #4 of 14 Old Mar 7th, 2014, 6:29 pm
I think they did change the interval to 16 K for valve checks but I have no documentation to show that. The brakes are important. Tranny is 24 K and the rear drive is very easy to do and can be done almost four times with a quart of oil. The best reason to change it is to look at the drain plug magnet - grey fuzz = good; shiny stuff = bad.
post #5 of 14 Old Mar 7th, 2014, 6:50 pm
zippy_gg's Avatar
I think because of the age of the bike, and probably the last fluid change date, I would replace engine (oil + filter), transmission, final drive, and as John eluded brake fluid for the brake circuit AND the clutch circuit.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #6 of 14 Old Mar 7th, 2014, 7:26 pm Thread Starter
Re: 12000 mile inspection
Originally Posted by jzeiler View Post
I think they did change the interval to 16 K for valve checks but I have no documentation to show that. The brakes are important.....
Thank you. sir. 16k wouldn't surprise me, but I wonder where it's written. The little service booklet isn't set up for it! The brake service lured me in, I needed tires, and figured what the heck, let pros do the valves the first time. I wouldn't have gone for the 12000 mile service if I'd known it didn't include valves and all the oils. My fault, I'd assumed certain things would be done based on, well, every reference I had available, but I should have gone over it more with the service writer.
It's okay, just a reminder to get off my ass and take care of it myself!
post #7 of 14 Old Mar 7th, 2014, 7:36 pm Thread Starter
Yes, I agree. They did the brakes and clutch, I'll do the transmission and final drive, and the valves too, like I just should have done in the first place. Just wish there were a little more room in the garage. And maybe a little warmer, too!
post #8 of 14 Old Mar 8th, 2014, 5:52 am
When I purchased my 05 the interval was 12,000 to check the valves.
Painterman is offline
post #9 of 14 Old Mar 8th, 2014, 7:40 am
TeddyTelco's Avatar
I have an 09 and had the 12k service done last year. The Mothership moved the valve check to the 18k check
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
post #10 of 14 Old Mar 8th, 2014, 10:55 am Thread Starter
Thanks to everyone for your replies.
I haven't called yet but it's looking like maintenance schedules have indeed been changed up a bit. My mistake for assuming a 12k service was what it used to be, but damn that was a whole boatload of money and I thought I'd be getting a little more.
From the wisdom of the forum I should have known better and been a little more careful. If I can get something in writing about changed intervals I'll post it.
post #11 of 14 Old Mar 8th, 2014, 11:19 am
sailor's Avatar
I have all BMW manuals for both generation: in PDF for 1999-2004 and as Windows application for 2005-2009 and nothing is changed in either. Also, had access for many years (not anymore) to service-bulletin(s) and I have never seen a change there either.
In reality, this is not critical - experience shows that checking at 12,000 miles will often leads to measurements that requires a change (in shim/bucket) only every 24,000 or 36,000 miles on average. So it is a moot point to extend this to 16 or 18k miles.
For you, WHAT IS CRITICAL, is to do the ABS modulator bleeding every year even if you do not ride it. The IABS system (with Servos) is partially ventend into the air (wheel circuits reservoir) and experience shows that extending this will often leads to higher failure rate of these modulators.
John (Montreal, CANADA)
sailor is offline
post #12 of 14 Old Mar 8th, 2014, 11:56 am
zippy_gg's Avatar
A lot of time/labor is spent removing the Tupperware, and even more if the tank has to come off for a fuel and air filters replacement.
That is when your time becomes valuable!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #13 of 14 Old Mar 8th, 2014, 1:27 pm
I did all my checks at 12 K and did not have to adjust any buckets until 48 K and did three buckets then. The next one at 62 K and one more at 76 K.
I am thinking now it is the K1600 that has the 16 K interval.
post #14 of 14 Old Mar 11th, 2014, 8:03 pm Thread Starter
All is well.....
Greetings, To recap, I asked, on the phone (pickup and delivery), after a 12k service, how the valves were. Was told no, that's now 16k.
I emailed the service manager and got a nice reply that the rep I talked to was new, mistaken, 12k is where the valves are checked and indeed they were. In spec, but did not have specifics. Everything on the check sheets and in the service booklet are as they always have been.
Thanks all for the comments and recommendations! The brakes and clutch was serviced there and I'll do the rear drive tomorrow. I spent the nice warmer day cleaning the big girl and doing the shift linkage, which really needed it.
Thanks again. I've learned a lot here over the years.
2011 BMW R 1200 GS Triple Black jeffdean GS Series 10 Apr 1st, 2011 11:13 am
Still take it easy after 600 mile break-in? Pitons98 K1200LT 2 Aug 21st, 2006 11:09 am
MOTO GUZZI RT rival? NORGE 1200 ustasub Chit Chat 10 Nov 24th, 2005 9:49 am
