BAKUP Backrest Question... - BMW Luxury Touring Community
post #1 of 15 Old Mar 4th, 2014, 11:51 pm Thread Starter
CaptJDavis's Avatar
Is anybody using this product with a factory standard LT seat?
I just bought one from a fellow member on this board and it's in good shape and all but;
when I installed I realized that little bottom plate used as the platform where the adjustment screw base sits on is digging into the passenger seat badly.
It is so badly digging into it, where I feel like it may damage the front portion of the passenger seat.
Anyone of you had the same problem?
If so, how did you guys prevent it damaging the passenger seat?
Capt.Jim
2018 R1200 GSA
'18 R1200RT
'18 K1600GTL
'16 R1200GSA
'14 R1200RT
'12 K1600GTL
'06 R1200GS
'03 R1150RT-P
'07 K1200LT
'05 R1150RT-P
'99 HONDA Valkyrie
'06 R1150RT-P
'05 K1200LT
'05 HONDA Goldwing GL1800
'99 HONDA Valkyrie Interstate
'98 HONDA SHADOW
'98 YAMAHA Super Tenere
'93 HONDA CBR 1000F
'91 HONDA Transalp
'88 JAWA 500
CaptJDavis is offline
post #2 of 15 Old Mar 5th, 2014, 10:17 am
Re: BAKUP Backrest Question...
Jim, mine's the same way. That half radius shaped part leaves an indent on the passenger seat. It goes away after you've had the backup off for awhile. I haven't noticed any wear to the seat cover as of yet. You might be able to place shims between the backrest and where it mounts to the bike to raise it a bit. Not sure how that would affect the seat latching though.
2003 KTM 525EXC
2006 KTM 300 XCW
2011 Suzuki 650 Vstrom
2009 BMW K1200LT
socaltrailrider is offline
post #3 of 15 Old Mar 5th, 2014, 2:33 pm Thread Starter
CaptJDavis's Avatar
Thanks buddy... I talked to Bakup company and they told me that there should be a plastic molding where that base digs into passenger seat. On mine it didn't have that part, Backup sending me one with no charge.
After installing that piece and the sleeve over it I've been told that it won't tear the passenger seat.
I wish they build that adjustment screw portion of the backrest 1,5 inches higher than its current location.
Well, Thanks for the response buddy!
Capt.Jim
2018 R1200 GSA
'18 R1200RT
'18 K1600GTL
'16 R1200GSA
'14 R1200RT
'12 K1600GTL
'06 R1200GS
'03 R1150RT-P
'07 K1200LT
'05 R1150RT-P
'99 HONDA Valkyrie
'06 R1150RT-P
'05 K1200LT
'98 HONDA SHADOW
'93 HONDA CBR 1000F
'91 HONDA Transalp
'88 JAWA 500
post #4 of 15 Old Mar 5th, 2014, 5:24 pm
Upright's Avatar
My Bakup does the same thing...and I don't have the plastic piece either. Looks like I'll be making a call. Thanks for the heads-up!
'99 K1200LTC
'00 R1100RT
'98 H-D Road King Classic
'86 Suzuki Cavalcade LX
'79 Yamaha XS1100
MOA #179460
IBA #57873
Upright is offline
post #5 of 15 Old Mar 5th, 2014, 8:01 pm
There should also be 1 inch spacers (came with it when new) that you use under the mounting points that raise it up. Even with that mine does leave an impression on the pillion seat but no damage in 9 years.
ID:	50650   Click image for larger version
ID:	50658   Click image for larger version
post #6 of 15 Old Mar 5th, 2014, 8:30 pm
GaryEm's Avatar
John I wonder if they designed them different on the newer ones because I do not have the spacer but mine sets on the pillon seat the same way yours does and John it looks like you put something around them plastic mouldings that slide over the top of that sharpe edge to keep them on
Gary
2003 K1200LT
GaryEm is offline
post #7 of 15 Old Mar 5th, 2014, 9:48 pm
tconnell's Avatar
I don't know why I haven't thought of the spacers on the bottom of the mount. I probably don't need a full 1 inch but mine would feel better a little bit higher. I've never seen the spacers but you can get metal or plastic ones at most any Ace Hardware in the section where they have all the thin drawers with small parts.
A pair of metal ones with a pair of longer Metric Allen heads and a dab or two of JB Weld to hold them and that will fix that up. A good project for this Saturday as it's probably going to rain.
Tommy
IBA #48786
MOA #164466
tconnell is offline
post #8 of 15 Old Mar 5th, 2014, 10:22 pm
I bought a couple of 1/2" thick plastic washers at Ace Hardware and ground about 1/3 of the radius out placed them between rest and frame and installed longer bolts which raised the complete back rest. Never had a problem after that. Fits me better too.
JQFAST is offline
post #9 of 15 Old Mar 5th, 2014, 10:45 pm
I bought a 2nd hand one, and have it set as low as possible, no packing spacers were provided either.
Saw same potential problem, so packed some 6-8mm dense foam cut from an old ground mat (the kind you put under a sleeping bag) around that adjustable support piece before pulling the cover down over it, so it protects both the passenger and the seat from those sharp metal edges, as the vinyl cover doesn't seem to give a lot of protection.
No issues with it cutting seat or passenger.
post #10 of 15 Old Mar 6th, 2014, 12:01 am
Hmmmm, I don't have the sleeve to fit over mine either, or the spacers......... Picked mine up used as well. Guess I have a project for this weekend.
2003 KTM 525EXC
2006 KTM 300 XCW
2009 BMW K1200LT
post #11 of 15 Old Mar 6th, 2014, 12:33 am
azccj's Avatar
I bought mine new last year and there was no spacers or plastic piece in the box. I tucked the bottom part of the supplied vinyl cover, under the metal part of the backrest that touches the rear seat. So far so good. On my bike both the front and rear seats along with both backrests were redone by Russell. If someone has a picture of this mystical plastic piece, I would like to see it.
Current Bikes
2013 Triumph Trophy SE
2013 Suzuki Burgman 650, Ya it's a scooter but it will do over 100 MPH
2005 BMW K1200LT
2004 BMW R1150RT
1972 Moto Guzzi Eldorado
azccj is offline
post #12 of 15 Old Mar 6th, 2014, 9:18 am
MountianMama's Avatar
Thanks for the pics John.
That was excellent
Eric von Laue
3Cyl Kawa ( a long time ago)
450 Yamaha Seca ( maybe it was a Maxim )
1100 Honda Magna
650 Honda XR ( to Guatemala and back)
1990 Honda PC800 ( Mountain Mama )
2000 BMW 1200LT ( Maxamillion )
Keep the rubber side down
MountianMama is offline
post #13 of 15 Old Mar 6th, 2014, 8:27 pm
I got tired of them coming off and the glue was a sticky mess. I used waxed lacing cord (just because I have a ton of it). It does not come off any more.
post #14 of 15 Old Mar 8th, 2014, 12:59 am Thread Starter
CaptJDavis's Avatar
When it arrives I'll post pictures of this mystical plastic part!
Capt.Jim
2018 R1200 GSA
'18 R1200RT
'18 K1600GTL
'16 R1200GSA
'14 R1200RT
'12 K1600GTL
'06 R1200GS
'03 R1150RT-P
'07 K1200LT
'05 R1150RT-P
'99 HONDA Valkyrie
'06 R1150RT-P
'05 K1200LT
'98 HONDA SHADOW
'93 HONDA CBR 1000F
'91 HONDA Transalp
'88 JAWA 500
post #15 of 15 Old Mar 8th, 2014, 11:20 am
Upright's Avatar
Bought mine new last month and it didn't come with spacers or the plastic piece. I'll be making a trip to the hardware store for some spacers today. Thanks for the tip!
'99 K1200LTC
'00 R1100RT
'79 Yamaha XS1100
MOA #179460
IBA #57873
Upright is offline
Bakup backrest issues, need photos Sit K1200LT 3 Sep 3rd, 2010 9:58 am
Bakup backrest with Sargent seat? ridesmith RT Series 2 Mar 25th, 2010 10:55 pm
No seat lock with bakup backrest jers99lt K1200LT 14 Apr 17th, 2007 11:37 am
Question on Bakup Backrest??? michman Ergonomics & Rider Comfort 10 Dec 7th, 2006 10:21 pm
