Bad OČ sensor? - BMW Luxury Touring Community
post #1 of 38 Old Mar 4th, 2014, 5:03 pm Thread Starter
Bad OČ sensor?
Hello to all,
I'm currently base lining my new to me 99' k1200lt with 42k miles on it.
So far I've checked the air filter, plug wires, and plugs.
I've several things that concern me of a failing oxygen sensor they are as follows:
1) So far in the 500ish miles that I've ridden it I've managed to maintain a 30mpg average. The highest I ever got was about 32 mpg running 70 mph 1 up with no additional gear.
2) There is the smell of unspent fuel while running.
3) I looked at the spark plug after running the bike momentarily to check for spark escaping from compromised plug wires, or plugs and found a light coating of fuel on the plug. I also noted that the piston has some carbon build up as well.
4) I haven't noticed any hesitation anywhere in the band, but there is a distinct engine vibration in every gear between 4.5k and 5k rpms. Although this seems to be a common occurrence as many have noted in this forum out is usually noticed at 4k-4.5k rpms which may also be a sign that I'm running rich since that seems to be the beginning of the power band and it is taking just a bit longer for my engine to clear it's throat so that it can breathe more freely.
I don't anticipate a large mpg gain by changing oil although it's due. I will change it before the next ride. I plan to use 4 qts. of fully synthetic castrol 20w50 but am open to suggestions.
At this point I feel like the OČ sensor is the most likely culprit. If those of you that have more experience with these machines agree I plan to replace mine with a bosch 13477 if that's permissible.
Thanks for all of the help!
Dale
superstan26 is offline
post #2 of 38 Old Mar 4th, 2014, 5:13 pm
gbob's Avatar
Re: Bad OČ sensor?
My 99LT got 33mpg and lots of black smoke during hard excell , but ran well with a bad O2 sensor ( pinched wire) Replaced with Bosch universal with wire splices mileage went to 47 - 50 mpg. Also replaced plugs with Iridiam ones.
Bob G
1999 LT sold
2011 RT
gbob is offline
post #3 of 38 Old Mar 4th, 2014, 5:31 pm
Re: Bad OČ sensor?
Wondering whether a GS-911 would help here.... playing with my new one I learned about Lamda and the o2 sensor and watched it working on the live graph.... http://www.hexcode.co.za/techinfo/lambda
post #4 of 38 Old Mar 4th, 2014, 5:33 pm Thread Starter
Re: Bad OČ sensor?
Bob G
1999 LT sold
2011 RT
Now if I could just watch my tailpipe while riding a wheelie! :-)
I appreciate the info. Btw we're not that far from one another, I'm in k.c.k.
post #5 of 38 Old Mar 4th, 2014, 6:13 pm Thread Starter
Re: Bad OČ sensor?
It probably would, but I doubt it'll be helping me for this one $$$. Maybe next time? :-)
post #6 of 38 Old Mar 4th, 2014, 6:55 pm
Re: Bad OČ sensor?
My notes say the Bosch O2 sensor number is 13475. At least that's what ole Toad has as a replacement for the OEM. Maybe things have changed, butt verify first it you can. Good luck.
post #7 of 38 Old Mar 4th, 2014, 7:29 pm Thread Starter
Re: Bad OČ sensor?
I think you're right Dick. The plug was different in the number I posted. Thanks again!
post #8 of 38 Old Mar 4th, 2014, 7:52 pm
deanwoolsey's Avatar
Re: Bad OČ sensor?
Dale if you'll wait until it's warm outside (about two weeks maybe???) I would ride down and hook up my 911 for you, or meet somewhere in Lawrence and do the same. Send me a PM if interested. I'm just southeast of Topeka.
deanwoolsey is offline
post #9 of 38 Old Mar 4th, 2014, 9:02 pm
cbpip's Avatar
Re: Bad OČ sensor?
What would be best way to remove a sensor that seems to be difficult to come out. Put some significant torque on it but won't budge to back it out. Affraid of stripping out the treads.
76 Honda 750 four-departed
65 Pan head (gone)
72 Rickman 6 day Enduro
BMWMOA # 189093
BMWBMW LOCAL CHAPTER Member
BMW MARS CHAPTER Member
BMWRA # 41568
cbpip is offline
post #10 of 38 Old Mar 4th, 2014, 10:08 pm Thread Starter
Re: Bad OČ sensor?
Hi Dean,
I appreciate the offer! I received a similar offer from another member I may just change the sensor first and if that doesn't fix it get in contact with one of you.
Turns to ask for your generosity, and assistance!
post #11 of 38 Old Mar 4th, 2014, 11:19 pm
Re: Bad OČ sensor?
Get it hot and apply penetrating oil. Then let it set overnight. If that doesn't do it, tap it lightly a hundred times or so (not kidding) with a tack hammer on the flats.
post #12 of 38 Old Mar 11th, 2014, 2:00 pm Thread Starter
Re: Bad OČ sensor?
Looks like the OČ sensor fixed me! My mpg was near 40 this morning, and steadily climbing. I'm loving this bike!
post #13 of 38 Old Mar 11th, 2014, 2:22 pm
sailor's Avatar
Re: Bad OČ sensor?
Thank you for the follow-up on this ;-)
Of course with the bad fuel mileage you had mentioned in your 1st post, this would be the most probable cause.
Assuming the air-filter is clean (and air intake not blocked by any critter), -AND- assuming the rest is in acceptable shape (plugs, compression, valve adjust), then only the Oxygen-sensor makes a big diff. Unless someone has played with hall-effect rotor position, the timing cannot be suddenly off.
John (Montreal, CANADA)
sailor is offline
post #14 of 38 Old Mar 11th, 2014, 3:28 pm Thread Starter
Re: Bad OČ sensor?
I checked all of the afore mentioned prior to replacing my sensor with the exception of the hall effect. The OČ sensor looked like someone got frustrated trying to install it (not sure why that would happen :-) it was damaged in more than one area like it had been smacked with a wrench, or squeezed with pliers possibly. Either way I'm glad to see the numbers rising.
Now if I could just figure out why my average speed doesn't change to the current speed if reset while riding...
post #15 of 38 Old Apr 29th, 2014, 11:28 pm
dvgb131's Avatar
Re: Bad O2 sensor?
Looks like the O2 sensor fixed me! My mpg was near 40 this morning, and steadily climbing. I'm loving this bike!
2 questions:
1. Is it possible to remove the O2 sensor without taking the exhaust off the bike? I can't seem to get much leverage in that tight space.
Flats are starting to round.
2. 7/8" or 22mm?
Thanks.
Doug B.
2000 LT purchased July 2013
dvgb131 is offline
post #16 of 38 Old Apr 30th, 2014, 8:12 am
Re: Bad O2 sensor?
Originally Posted by dvgb131 View Post
2 questions:
2. 7/8" or 22mm?
Thanks.
You do have the special sensor socket with the slot for the wire, right? If not, give strong consideration to buying one. Makes a sometimes challenging job much less challenging.
post #17 of 38 Old Apr 30th, 2014, 8:47 am
dvgb131's Avatar
Re: Bad O2 sensor?
Yes. I bought a 6-sided, 7/8" sensor socket from Harbor Freight yesterday.
It seems quite loose. I can only use it in one position. then the breaker bar hits the frame piece.
I'll get a hopefully better one today from NAPA.
Also thinking about getting a crowfoot 22mm.
I've also been doing the heat/PB'laster for two days now.
Doug B.
dvgb131 is offline
post #18 of 38 Old Apr 30th, 2014, 9:32 pm
dvgb131's Avatar
Re: Bad O2 sensor?
Got it out! I guess the PB'laster needed another day go get through the rust.
Doug B.
dvgb131 is offline
post #19 of 38 Old May 1st, 2014, 12:13 am
golf18's Avatar
Re: Bad OČ sensor?
It's a 22mm
Speed doesn't kill - Sudden impact does
golf18 is offline
post #20 of 38 Old May 6th, 2014, 7:44 am
martin280s's Avatar
Re: Bad OČ sensor?
Recently, I've noticed that I seem to be using a bit more fuel than usual. Could that indicate the O2 sensor is not working as it should?
Is there a 'universal' type we can use rather than the official Bosch sensor? Down here, the Bosch/BMW sensors cost almost USD250 each. I have found a, sensibly priced, Universal sensor from Delphi which has four wires. Will that work?
Thanks.
1999 BMW K1200LT "Galatea"
1976 MERCEDES-BENZ 280S "Lady Genevieve"
1993 MERCEDES-BENZ S320 "Lady Audrey"
martin280s is offline
post #21 of 38 Old May 6th, 2014, 10:22 am
Re: Bad OČ sensor?
Bosch 13475 Oxygen Sensor, OE Type Fitment, about $70 from Amazon. Direct replacement, no wire splicing.
Motor On ,/'
jkersh1 is offline
post #22 of 38 Old May 8th, 2014, 6:22 am
martin280s's Avatar
Re: Bad OČ sensor?
Unfortunately, Amazon is not readily accessible in Brazil plus delivery times and import taxes are prejudical. My last purchase in the US took nealy 5 months to arrive!
I went to a autofactors this week but they were unable to find this Bosch code. they told me there are some numbers missing. they also asked me how many wires are attached to the sensor. Can anyone inform me?
Thanks, Martin
post #23 of 38 Old May 8th, 2014, 8:23 am
dvgb131's Avatar
Re: Bad OČ sensor?
Thanks, Martin
4 wires.
2 white
1 black
1 brown.
I got mine from BeemerBonyard:
http://www.beemerboneyard.com/11781464492n.html
Doug B.
dvgb131 is offline
post #24 of 38 Old May 8th, 2014, 8:37 am
sailor's Avatar
Re: Bad OČ sensor?
Thanks, Martin
The full Bosch part number for this sensor is "0 258 003 475". because these are often classified as OEM original for BMW motorcycles, your automotive Bosch reseller may not have it on file.
Another option is to fit an universal 4 wires Bosch heated sensor that comes with a kit to splice your wires and insert a 4 pins sealed connector in between. The generic number for this is 15727 - these are less expensive than the full one with the OEM black connector, but they do the same job. See this page for a detailled picture:
http://www.euromotoelectrics.com/product-p/o2-bmwu.htm
Lastly, I have not tested this, but I have been told that the sensor for a car BMW 330i (2004) has the same specs, same connector, and is just a few inch longer wire. In fact, most 4 wires Bosch heated sensor are all the same except for (1) the wire length and (2) the type of connector at the end.
sailor is offline
post #25 of 38 Old May 8th, 2014, 6:04 pm
martin280s's Avatar
Re: Bad OČ sensor?
Everyone,
Thanks for all that helpful information. I accessed the MTE Thomson customer service chat line today and they informed me their part number is 7836.40.057.
I'm going to have a look tomorrow to see if I can get one locally.
Thanks again.
post #26 of 38 Old May 9th, 2014, 11:30 am
martin280s's Avatar
Re: Bad OČ sensor?
4 wires.
2 white
1 black
1 brown.
Unfortunately, it appears that the specific Bosch or MTE sensors are not available locally. However, the universal Bosch sensor 0 258 986 507 has two white wires, one black and one grey. I presume the grey partners the brown.(?)
post #27 of 38 Old May 9th, 2014, 12:11 pm
sailor's Avatar
Re: Bad OČ sensor?
No polarity on heater wires (both are white on Universal sensor).
Easy instructions exist to help you cut / install and match wire from Bosch. In fact, instructions could also be in the box when you receive it.
As a brief video tutorial:
https://www.youtube.com/watch?v=ex1Hki6-NHw
OR as a more detailed PDF document:
http://www.boschautoparts.com/BAP_Te...allGDWEB09.pdf
sailor is offline
post #28 of 38 Old May 9th, 2014, 2:23 pm
martin280s's Avatar
Re: Bad OČ sensor?
Thanks John.
post #29 of 38 Old May 13th, 2014, 6:51 am
martin280s's Avatar
Re: Bad OČ sensor?
I swapped the O2 sensor for a universal one since the specific model was not available. To do so, I disconnected the battery. Swapping the part itself is not difficult, tedious is getting to it. While the panels were off, I did lubricate the gear linkage too... a huge difference there.
However, when I took the bike for a spin, she was popping and banging, no acceleration and the very fact of the engine running seemed to be hard work! Upon returning to the garage, I turned her off and mulled! Upon restarting, she seemed better. The idle is firm at 1,000 rpm, although on the motorway, the trip meter says I'm using more fuel but I haven't got the same amount of soot on the exhaust tip and the autonomy seems to be the same, not yet sure if better. I conclude less fuel being burnt. Although, I now have an intermittant flat spot between 1,500 and 2,500 rpm which causes a slight hesitance then surge back to normal acceleration.
Anyone have any suggestions why this strange behaviour?
Thanks in advance.
post #30 of 38 Old May 13th, 2014, 7:39 am
dvgb131's Avatar
Re: Bad OČ sensor?
Thanks in advance.
Did you reset the TPS sensor after you hooked the battery back up? Turn key to on, but don't start the engine. Fully open and close the throttle 2 times. Turn key off. Start as usual.
Doug B.
dvgb131 is offline
post #31 of 38 Old May 13th, 2014, 7:53 am
martin280s's Avatar
Re: Bad OČ sensor?
Yes, I did do that too. Exactly as you mention above.
post #32 of 38 Old Jun 20th, 2014, 1:02 pm
Re: Bad O2 sensor?
Is this an OEM tool you speak of? Can I find it elsewhere cheaper?
Thanks.
Current:
2000 BMW K1200LT - "Like riding on a rail"
Previous:
1982 Honda Goldwing Interstate - "Gas, oil and Go"
1979 Harley Sportster - "Always broken, always fixing"
1978 Yamaha 500 - "Training wheels"
imst0ked is offline
post #33 of 38 Old Jun 20th, 2014, 2:14 pm
dvgb131's Avatar
Re: Bad OČ sensor?
Swapping my O2 sensor didn't make any difference in my fuel mileage. I'm still around 32MPG after 2 tanks. I have yet to get a long distance ride in though.
Mostly 9 mile commute.
I also swapped in new Iridium plugs at same time. Old plugs were black and wet, not brown.
Engine has about 40,000 miles. Dealer replaced and adjusted the TPS previously. Is that the same as the Hall Effect Sensor?
Doug B.
dvgb131 is offline
post #34 of 38 Old Jun 20th, 2014, 3:02 pm
martin280s's Avatar
Re: Bad OČ sensor?
It turned out that the strange behaviour was related to an air leak. The bike in now in the workshop, in pieces waiting the the 'grace of BMW' to deliver said part. It's been 20 days now. I thought about importing the part idependently, but that can take even longer and the cost was no less. So, I just have to wait!
post #35 of 38 Old Jun 21st, 2014, 8:11 am
dvgb131's Avatar
Re: Bad OČ sensor?
Martin, I sent you a PM.
Doug B.
dvgb131 is offline
post #36 of 38 Old Jun 21st, 2014, 9:31 am
sailor's Avatar
Re: Bad OČ sensor?
To answer your last Question: TPS will measure the throttle opening (0 to 90 degrees roughly speaking). The HALL-Effect is in front of engine for the ignition timing (for signal to coil and plugs). Basically, the HALL-Effect sensor replaces the old ignition-points mechanical system of much older motorcycles (up to roughly 1980+).
To help pinpoint your problem, I would suggest you either:
(1) find a member with a GS911 to read fault codes and graph the oxygen-sensor data in real-time
(2) got to a good BMW dealer and ask them to to the same as above with their diagnostic computer.
In many cases, when a condition is such that the air-fuel mixture is disturbed (wrong fuel-pressure, defective Oxygen sensor, air leaks in intake...), the Motronic-ECU will log 1 or more faults that you can read with GS911. This can give you a starting point to troubleshoot.
sailor is offline
post #37 of 38 Old Jun 21st, 2014, 5:29 pm
Re: Bad OČ sensor?
I had exactly same problems and got the o2 lambda sensor changed this week, it was solid in exhaust mechanic had to remove exhaust to heat it etc to remove,
but it was all worth it 50 mpg 2 up now no more black smoke etc tickover was also reduced and cut out a few times on gear changes, that is all cured now, thanks to the help of the guys on this forum for their help, good luck but I,d get o2 changed
lonestar493 is offline
post #38 of 38 Old Jun 30th, 2014, 3:15 pm
Re: Bad OČ sensor?
Unfortunately, Amazon is not readily accessible in Brazil...
While researching causes for my LT's recent spate of 38 mpg runs, several mpg below its usual fuel consumption rate, I noticed this irony. <Insert smiley face here.>
Now, back to business.
-Richard S.
2000 K1200LT Champagne
2004 R1150RT Silver
howles is offline
Help, O2 sensor cables mixed! pozo_izquierdo K1200LT 4 Oct 20th, 2015 11:24 pm
Oxygen sensor Sac K1200LT 9 Jul 11th, 2009 2:31 am
Rain Sensor Problem - X5 bbbngai Chit Chat 15 Nov 10th, 2008 7:43 pm
Question on Oxygen Sensor MNTodd K1200LT 1 Sep 21st, 2008 4:05 pm
O2 Sensor Replacement STYLNLT K1200LT 3 Sep 27th, 2006 12:02 pm
