Which clutch parts to replace - BMW Luxury Touring Community
post #1 of 7 Old Mar 4th, 2014, 2:37 pm Thread Starter
fpmlt's Avatar
As you may know, I'm into my clutch again. I have removed the clutch plate, but not removed the clutch housing from the shaft. The main seal and O-ring were replaced last time.
I'll be ordering a new spring plate and the bolts/washers to put the clutch back together. My question is: whether or not to pull the housing and replace the O-ring again (not leaking), as well as the nut and compression ring. I understand both sides of the argument - 1) if it ain't broke...2) if you're in there anyway...
fpmlt is offline
post #2 of 7 Old Mar 4th, 2014, 3:03 pm
Re: Which clutch parts to replace
Why NOT replace the O-ring, compression ring & nut? Easy and cheap... As you know there is a list of "mandatory" changes in the manual. Why and with what better knowledge not ro comply with that? They are not expensive parts so why waste energy in wondering...
Born to be wild so why not
C-A-D is offline
post #3 of 7 Old Mar 4th, 2014, 3:06 pm Thread Starter
fpmlt's Avatar
All true. Would only have to comply with the mandatory replacement parts if I remove them. Haven't so far, so wouldn't necessarily be required. All hinges on the O-ring. I'm leaning hard toward replacing, but am really tired of working on this thing.
fpmlt is offline
post #4 of 7 Old Mar 4th, 2014, 4:03 pm
If you used a Viton O-ring last time, leave it alone. If not, I would get a Viton one and replace it.
post #5 of 7 Old Mar 4th, 2014, 7:32 pm
+1 on what David says. I believe in leave it a lone if you can but Viton is worth the new nut.
post #6 of 7 Old Mar 5th, 2014, 12:22 am Thread Starter
fpmlt's Avatar
Done deal. Ordered everything today.
Thanks everyone
Oh, wanted to add. Talked to RideWest BMW, where I try to get most of what I need. I had noticed that current micro fiche states that the original O-ring has been superseded by another piece. I'm told that all current O-rings sold are Viton. Can anyone verify that?
fpmlt is offline
post #7 of 7 Old Mar 5th, 2014, 8:22 pm
I do see it has been superseded but no way to tell on the material. Better safe than sorry. I would go for a known one.
Clutch parts question 14wntr K1200LT 26 Oct 15th, 2017 5:04 pm
Non BMW replace parts tony_voorn RT Series 4 Aug 8th, 2013 8:37 am
clutch job parts ebear695 K1200LT 5 Jun 9th, 2013 8:29 pm
I fought the clutch and the clutch won. Slammer Chit Chat 3 Apr 15th, 2013 12:56 am
Clutch Parts and Pics whdunn4 K1200LT 2 Jan 2nd, 2012 3:22 pm
