Jensen JMS 2212 Install - BMW Luxury Touring Community
post #1 of 5 Old Feb 26th, 2014, 4:31 pm Thread Starter
I just finished the Jensen install on my 2006 LT. I really struggled with getting the factory stereo repaired or going with the Jensen. In the end, the Jensen was cheaper and has more features.
The install was not too difficult but was pretty time consuming. I kept all the factory connectors outside the stingray. I soldered and shrink tubed all connections inside the stingray.
The Jensen sounds great! (In the garage that is. Still too cold in Iowa to ride. 18 deg. today.)
I wanted to thank whomever came up with this option. I also wanted to thank all that have posted about the Jensen install.
This site has been invaluable to me as I am a new LT owner. Next project is the EBC rear rotor and pads.
Lox5109 is offline
post #2 of 5 Old Feb 26th, 2014, 9:06 pm
johnbaker15's Avatar
Re: Jensen JMS 2212 Install
Since you are new here we will be gentle but...
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #3 of 5 Old Feb 27th, 2014, 2:29 am Thread Starter
See what I can do about pics. Nothing different from what others have done and posted pics of.
Lox5109 is offline
post #4 of 5 Old Feb 27th, 2014, 8:44 pm
smahon's Avatar
Anyone who has done this: What happens to the weather integrity of the stingray? I know it's not waterproof today, but every time I remove mine it appears well protected under there.
'15 GTLE
smahon is offline
post #5 of 5 Old Feb 27th, 2014, 11:19 pm Thread Starter
The Jensen control head that flush mounts has a gasket on it. There are two small holes left from the original control unit that is removed that have to be sealed. There also is a square opening from the old control unit that has to be sealed.
On mine, I had to drill a hole on the left side of the bottom of the stingray for the antenna and one for the control cable on the top of the stingray. I used a rubber grommets and silicone for these. I also soldered and shrink tubed all connections.
As long as you take the time and seal up any openings you add or create from this install, I don't see how it would be any less water tight.
The good thing is if water did get in the stingray the Jensen is waterproof.
Lox5109 is offline
Jensen JMS2212 Install with a Twist new02oldlt K1200LT 18 Apr 1st, 2014 4:28 pm
Another Jensen Install living_free K1200LT 58 Apr 9th, 2013 3:23 pm
Help Jensen 2212 install go2fast K1200LT 18 Nov 25th, 2012 2:18 pm
Wiring Details for Jensen Install? 2K1_6T8 K1200LT 14 May 18th, 2012 11:46 am
Need some Help on the Jensen JMS2212 Install tconnell K1200LT 10 Jul 9th, 2011 2:24 pm
