stalling and stop running - BMW Luxury Touring Community
post #1 of 12 Old Feb 26th, 2014, 12:35 am Thread Starter
Ok, what has happened to me a couple of times is coming up to a stop sign or maybe just a stop and turn is the engine dies, fires right back up but kinda weird for a fuel injection, only other thing that occurs is that it will sometimes between gears just fall on its face as it were staggering and then catching again. No way it is a vapor lock right?
If it were a carburetor I would look at float adjustment and accelerator pump. I am lost on fuel injection, guessing maybe fuel filter.
This is a 1999 1200 LT new to me. So far I have removed the canister thing and the air box sensor, re adjusted the throttle sensor by turning it full on and off three times with the key on. Before I got it they put in new plugs, wires and coil or dist cap,whatever the wires come out of.
Anybody experience anything like this?
mexicoboy is offline
post #2 of 12 Old Feb 26th, 2014, 12:56 am
hallzee's Avatar
Re: stalling and stop running
Sounds like the engine temp (not water temp) sensor. Behind the number four cylinder, screwed into the engine block.
If the bike runs fine when cold, and you get these symptoms after it's warmed up, then that's probably the culprit.
I had the same problem; after riding 5 miles or so, the engine would just cut out on me. If I stoped at a light, it would just die. Let it cool - would run fine.
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #3 of 12 Old Feb 26th, 2014, 9:27 am Thread Starter
Will take a look at that for sure, It does it when colder more that when it is hot. Lot of sensors on this machine no?
post #4 of 12 Old Feb 26th, 2014, 9:50 am
Had the same problem for years and spent a ton of money trying to fix. Turned out to be a loose connection near the battery!
budzee is offline
post #5 of 12 Old Feb 26th, 2014, 9:57 am Thread Starter
Hey Budzee, will check it out, nobody told me how much fun these were. Must have been a real pisser, good possibility as I have a battery drain going on also
post #6 of 12 Old Feb 26th, 2014, 10:50 am
deanwoolsey's Avatar
Check the fuel lines in the tank. I bet you have a split or loose line.
deanwoolsey is offline
post #7 of 12 Old Feb 26th, 2014, 1:58 pm Thread Starter
Hi Dean
I am getting ready to look into the fuel tank to look at filter, hose etc. Sounds good as does checking all grounds and connections.
We live in cozumel and while they now have a Napa store , well lets just say if they can order me a filter I will be very, very happy. I have the number so that should help.
Maybe not the best place to own a bike like this but we purchased it to tour the mainland of Mexico and that we shall.
post #8 of 12 Old Feb 27th, 2014, 6:42 pm
smahon's Avatar
Had the same exact thing happen to me 3 years ago and lasted for months. This group had plenty of suggestions. Replaced the battery, the fuel filter/lines, O2 sensor, plugs; checked electrical connections. Other than the minor fact that it isn't happening any more (last year anyhow), I never did find the cause.
'15 GTLE
smahon is offline
post #9 of 12 Old Feb 28th, 2014, 3:13 pm Thread Starter
Well ,I might have gotten lucky. Saw what looked to be an oil leak on the right hand side. Pulled lower and middle plastic to expose right side of engine looking for an oil leak in a hose or something. Turned out the fuel line coming out of the bottom of the fuel pump had a small leak out of the inside fuel line. Clamp turned out to be loose. Upon tightening it up the throttle response got better. One thing for sure is that if battery dies or is dis- connected then it is a must to do the throttle position re set.
Charging the battery now and will drive it today or tomorrow but so far I believe it is fixed. Fuel pressure must be such that if it drops at all computer will not like it. Interesting bike for sure.
post #10 of 12 Old Feb 28th, 2014, 5:17 pm
Sounds like your fuel pump is about worn out if a slight leak caused those symptoms. Have to pressure check it to be sure. Should show 51 PSI or close to it. I would still check the in tank hoses.
post #11 of 12 Old Mar 1st, 2014, 6:21 pm Thread Starter
I might have to do that, will not run anymore today as some kind of box looking thing right behind the abs controller has sprung a leak. this box has a cable to the positive side of the battery and then a bunch of small wires running out of it. Have no idea what it is or why it has fluid in it. Some kind of transformer or something?
post #12 of 12 Old Mar 1st, 2014, 7:04 pm Thread Starter
Wow I think I found out what it was, Control unit for reverser, why would it have oil in it and if it fails will it cause electrical problems?
rough running '07 mioffroader K1200LT 16 Sep 5th, 2011 11:07 am
Backfiring / rough running / stalling gary2112 RT Series 6 Oct 6th, 2010 11:40 pm
Engine stalling in hot weather rdore RT Series 4 Sep 10th, 2009 9:51 am
Stalling again, air box sensor? yechave K1200LT 10 Sep 22nd, 2008 4:54 pm
