Intermittent Cruise Control - BMW Luxury Touring Community
post #1 of 7 Old Feb 24th, 2014, 7:10 pm Thread Starter
Some days the cruise control works, some days it doesn't.
The little red light always comes on under the slider but when I flick the set/up/down/resume tongue - sometimes it works. During long days it can work at times and not at others.
When it is working I tickle the clutch or brake lever - looking to see if a sticky or over sensitive switch/sensor is the problem but I have not got any feedback that proves it is one of them.
Any other ideas ?
(The only purpose of the cruise control on the K1200LT is to allow you to adjust the seat heating with your right hand, without suddenly losing speed as you take that hand off the throttle. I can scratch my bollocks with my left hand.)
Bimbler is offline
post #2 of 7 Old Feb 24th, 2014, 7:19 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Intermittent Cruise Control
I had a similar problem with mine a few years ago. Turns out the clutch micro switch was out of adjustment. I search will turn up many posts on this problem.
Stevie Shreeve
katnapinn is offline
post #3 of 7 Old Feb 24th, 2014, 9:11 pm
sailor's Avatar
Any other ideas ?
Have you seen the video tutorial and the PDF document to help you with the cruise-control troubleshooting ?
See this link in a previous post:
http://www.bmwlt.com/forums/showthread.php?t=61130
John (Montreal, CANADA)
sailor is offline
post #4 of 7 Old Feb 24th, 2014, 9:29 pm
deanwoolsey's Avatar
If your speedometer needle bounces, you may have a break or short in the wiring from the rear wheel sensor. Common issue on the early bikes.
deanwoolsey is offline
post #5 of 7 Old Feb 25th, 2014, 7:35 am
sailor's Avatar
Good suggestion, but I see that in another post he said he had a 2002 model - so no speed sensor on top of rear-drive for this one.
For this 2nd generation K1200LT without the separate speed sensor, by far the most common cause(s) of intermittent cruise-control are:
(1) Clutch switch has become loose and has moved slightly on its pivot screw
(2) Throttle body switch acting up because cable are too tight (friction) or not enough free play adjustement
(3) Rear brake pedal switch dirty or pedal adjustment incorrectly changed behavior of switch
sailor is offline
post #6 of 7 Old Feb 25th, 2014, 9:07 am
I propose you run the cruise test procedure WHEN you have the failure on. Then you should be able to capture the faulty circuit.
Born to be wild so why not
C-A-D is offline
post #7 of 7 Old Feb 27th, 2014, 2:18 pm Thread Starter
Outstanding.
Very many thanks. Will get to work and report back.
Bimbler is offline
Brake light and cruise control intermittent BMWCharlie K1200LT 1 Jul 24th, 2013 11:57 am
Electronic Cruise Control - R1150RT LaChuparosa RT Series 9 Dec 29th, 2012 4:08 pm
Intermittent cruise control failure... KJN K1200LT 11 Sep 20th, 2010 3:26 pm
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 4:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 10:38 am
