Alarm Back-Up Battery 2006 LT - BMW Luxury Touring Community
post #1 of 5 Old Feb 23rd, 2014, 11:13 pm Thread Starter
Miles of Smiles
Hilton's Avatar
Question Alarm Back-Up Battery 2006 LT
Anyone have any information on this little critter ?
A little background.
Have extended periods away from our bike between riding seasons. Around 8 months longest so far.
Do the long term storage preparations including disconnecting the battery earth ( No mains power available )
Alarm has always remembered previous mode. Which is good. :-)
Central locking and alarm NOT SET during storage, prior to battery disconnect.
Very long absence this time, over 2 years. :-( Got me thinking about the back-up battery in the alarm.
Maybe it's kept charged when connected to the bikes battery as in normal operations.
Or perhaps it's independent from the bikes electrics, just there to hold the mode setting in memory between battery changes.
As above, was fine even after 8 months, but it's getting older and as we know batteries don't last for ever.
Just wondering.
Cheers
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #2 of 5 Old Feb 24th, 2014, 7:31 am
jaxbobg's Avatar
Re: Alarm Back-Up Battery 2006 LT
Hilton, you should see a number of settings on your LCD display that are maintained after the battery is disconnected.
The on-board computer retains various settings just like a flash drive, which doesn't require power either for long term memory storage.
jaxbobg is offline
post #3 of 5 Old Feb 24th, 2014, 10:07 am Thread Starter
Miles of Smiles
Hilton's Avatar
Thanks Bob.
I can understand the similarities to flash drives for ECU 's etc.
But the alarm system is available as an accessory and IIRC
when armed, will power its own horn when activated - even if the bike battery is disconnected.
That means it would probably have its own battery within the module.
Even after lengthy storage my alarm has retained a memory of the mode setting. That could be similar to the flash drive, i.e. a non-volatile memory: but to power a horn will require a battery.
That's the battery I'm looking for information on.
Thanks for your input.
Cheers
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #4 of 5 Old Feb 24th, 2014, 1:50 pm
Yes the alarm has only one internal independent battery. This battery charges from the bikes system and a 2 year period with the bike battery disconnected could result in a dead alarm battery. But the best case would be a default to immobilizer on when you hook up the battery. Worst case would be a non functioning alarm, and in that case you would need to bypass it with two jumpers.
post #5 of 5 Old Feb 24th, 2014, 6:24 pm Thread Starter
Miles of Smiles
Hilton's Avatar
Thanks John.
As I thought, charged up by the bikes system.
May alter my initial maintenance actions.
Before replacing the bikes battery to bleed the wheel circuits using the ABS,
might be a good idea to have easy access to the multi pin connector for the alarm. If it starts screeching after I connect I can disconnect quickly.
Oh and I can have the bypass proceedure handy too.
Thanks for that info.
Cheers
ET4 Thing 1
ET4 Thing 2
Hilton is offline
K1200LT Battery Drain Explained dvallis K1200LT 20 Mar 11th, 2016 10:24 pm
Picture this - some salt and battery Tracus Bike Talk 1 Mar 2nd, 2013 1:13 pm
Battery & alarm question blueknightga6 K1200LT 13 Nov 2nd, 2010 5:11 pm
Charging the gel battery! gladiator99 K1200LT 4 Aug 24th, 2009 1:34 am
