Thought it was the rear seal but what's this... - BMW Luxury Touring Community
post #1 of 27 Old Feb 23rd, 2014, 9:57 pm Thread Starter
I discovered an oil drip from the rear of the engine and clutch housing and naturally assumed the rear seal was failing (65,000 miles on my '05 lt). Decided to make an adventure out of doing the repairs myself with the help of manuals and great video on YouTube, etc. Upon removing the throttle bodies I discover the rear intake is leaking like crazy.
What are the thoughts of those gurus attending? Should I continue to do the clutch and rear seals, trans seals, etc. due to the mileage? Love riding and working on this bike! Riding is a secure experience and working on it an adventure of new skills and experience!
Steve
Name:	20140223_K1200lt intakes_010.JPG
ID:	49690   Click image for larger version
Name:	20140223_K1200lt intakes_008.JPG
ID:	49698   Click image for larger version
Name:	20140223_K1200lt intakes_002.JPG
ID:	49706   Click image for larger version
Name:	20140223_K1200lt intakes_001.JPG
ID:	49714   Click image for larger version
Name:	20140223_K1200lt intakes_006.JPG
sumber101 is offline
post #2 of 27 Old Feb 23rd, 2014, 10:17 pm
Re: Thought it was the rear seal but what's this...
A common issue is the cracking of the PCV hose assembly. That then leaks oil on top of the engine. Many have replaced this over the years. Part number 11151465009. Approx. $85.
From your pictures, the assembly has been separated. Clean it off and look for splits.
post #3 of 27 Old Feb 23rd, 2014, 10:19 pm
It is the crankcase breather tubing that has deteriorated and is the source of your oil. Mine was no where near that bad. Unless your clutch has really been slipping (5th gear test), I would stop where you are. Fix the breather tubing and clean everything up. Now if you have the parts and have already removed everything else from the swing arm back you might as well go ahead and go in.
The biggest source of oil leaks on the clutch is the o-ring on the output shaft (not the rear seal) and at 65 K that sucker is brittle. Best to replace with a viton version of that 19 x 4 o-ring.
post #4 of 27 Old Feb 23rd, 2014, 10:30 pm Thread Starter
I think I should proceed with the removal of the trans and clutch since i have gone this far into her. Do you replace the trans seals even if they are not leaking?
post #5 of 27 Old Feb 23rd, 2014, 10:51 pm Thread Starter
Why is the oil so prevalent at the #4 intake?
post #6 of 27 Old Feb 24th, 2014, 11:44 pm Thread Starter
The only splits I can find are at the crankcase end of the breather hose (see pictures). I even blew compressed air into the manifold section and sprayed soapy water to look for any bubbles.
Is it really possible that these splits would allow that much oil as to weep all over the top of the engine and drip down and around the clutch housing etc.?
Appreciate your comments. Steve
ID:	49866   Click image for larger version
ID:	49874   Click image for larger version
post #7 of 27 Old Feb 25th, 2014, 12:29 am
deanwoolsey's Avatar
Yes. It's possible. That hose pulls out all the blow-by in the crankcase and is literally coated with oil on the inside when the engine is running. Then it takes up all the fumes into the airbox when the engine is shut down. I suspect it contributes to the sidestand/smoke issue as well since mine hasn't smoked a bit since I re-tooled mine and lowered it relative to the throttle bodies. Time will tell on that issue though. Not quite ready to claim that it's a cure.
deanwoolsey is offline
post #8 of 27 Old Feb 25th, 2014, 11:21 am
Pull the intake stubs and check the O-rings between them and the head.
Part Number 11611465169
post #9 of 27 Old Feb 25th, 2014, 9:35 pm
#4 is alway the oily one. Can't say why, it just is.
post #10 of 27 Old Feb 25th, 2014, 10:51 pm Thread Starter
I wondered about the intakes. I'll pull the number four tomorrow and report back. I bought the PCV manifold today and ordered a slave cylinder unit since the swing arm if off. If the clutch push-rod is clean I'll put it back together. If leaking, I'll go forward with the clutch job. I'm have a blast with this! Thanks for your advice!!!!! Steve
post #11 of 27 Old Feb 26th, 2014, 1:12 am
hallzee's Avatar
+1. I bought my '01 in '06. It had only 9,000 miles on it, but the breather tubing was already shot! I learned right away "what a great hobby working on the LT can be"!
I say that seriously. I never got pissed off if anything ever broke; just part of the hobby.
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #12 of 27 Old Feb 26th, 2014, 1:35 am
What do you mean with "clean push-rod"? It goes through the transmission and is supposed to be oily when you remove it.
Born to be wild so why not
C-A-D is offline
post #13 of 27 Old Feb 26th, 2014, 4:32 am
Enjoy The Ride
saddleman's Avatar
Wrong, it should always be dry.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #14 of 27 Old Feb 26th, 2014, 8:09 am
+1
The rod goes through the hollow transmission input shaft, should never be oily.
post #15 of 27 Old Mar 1st, 2014, 6:41 pm Thread Starter
Well, even after thinking the proverbial "if it aint broke, don't fix it" I decided to pull the trans and at least look into the clutch housing and am I glad I did. Black oil at the bottom of the housing (see pic). Amazing that the clutch was dry to the touch. No doubt it was a matter of time...
ID:	50314   Click image for larger version
ID:	50322   Click image for larger version
post #16 of 27 Old Mar 1st, 2014, 7:00 pm
hallzee's Avatar
Even a blind pig finds an acorn now and then...
Seriously, good thing you looked. Rear Main Seal is gone, if that's engine oil. Was the clutch slipping?
This may be the "Luck Play" of the century. The rear main is something like $35 - $40. If you can save the clutch, that's several hundred.
If any oil at all got on the clutch, it may be toast though.
Brian
MOA #136148
hallzee is offline
post #17 of 27 Old Mar 1st, 2014, 7:21 pm Thread Starter
Clutch was not slipping. With this much work to disassemble, and 65,000 miles, I think I'll do the clutch anyway.
post #18 of 27 Old Mar 1st, 2014, 8:48 pm
hallzee's Avatar
Good thinking!
Brian
MOA #136148
hallzee is offline
post #19 of 27 Old Mar 2nd, 2014, 2:11 am
Originally Posted by dshealey View Post
+1
Hmm... You might be correct here but wondering if the hollow transmission shaft is always dry, why is there shaft seals at both ends of it?
EDIT: Yes - you are of course right here - dry it should be! My memory served poorly! Glance to the pictures helped to recollect how it is set up... SORRY for wrong information...
C-A-D is offline
post #20 of 27 Old Mar 2nd, 2014, 6:22 am
The seal does not fail often, but the O-Ring on the shaft does! Always replace both the O-ring and seal. If possible get a Viton O-ring instead of the stock one. It is Metric 19X4. One place to get them: http://www.theoringstore.com/index.p...ducts_id=19200
post #21 of 27 Old Mar 2nd, 2014, 1:39 pm
fpmlt's Avatar
Sumber, what will you be replacing while you're in there?
fpmlt is offline
post #22 of 27 Old Mar 2nd, 2014, 2:33 pm
Do most buy an OEM replacement main seal or is there a better aftermarket part as with the o-ring?
post #23 of 27 Old Mar 2nd, 2014, 2:44 pm
fpmlt's Avatar
Good question. I'll be watching this as I'm tearing mine apart starting today. OH BOY!!
fpmlt is offline
post #24 of 27 Old Mar 2nd, 2014, 9:23 pm
I think most just use the OEM seal. I have not heard of anyone substituting the seal, just the O-ring, as it is usually the O-ring that fails anyway, not the seal. The stock O-ring gets brittle and cracks. Viton will last MUCH longer.
post #25 of 27 Old Mar 3rd, 2014, 11:56 pm Thread Starter
I have yet to disassemble the clutch so not sure if more than the friction plate will require replacement. For sure the main seal and o-ring. I purchased a new slave cylinder as well. I'll post pictures of the clutch internals later this week.
I heard in one of the videos from IllinoisBMWriders about a moly lube, but could not understand the name. Suggestions?
And I agree that working on this thing is a fun adventure. Go slow the first time, ask questions, make some tools, etc. Oh yea, I still have to put it back together!?!. Go slow....
Thanks for all of the advice! Steve
post #26 of 27 Old Mar 4th, 2014, 1:19 am
zippy_gg's Avatar
In my case the seal was still OK but the O-ring was all chewed up and I had to post a picture on the forum asking what that "thing" was...
I followed the advice given here and got a viton replacement.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #27 of 27 Old Mar 5th, 2014, 12:26 am Thread Starter
Dang, that is chewed up! Viton it is!
rear main seal? gpolakow K1200LT 6 Sep 4th, 2011 9:42 am
Thought I had blew by rear drive slmorley K1200LT 2 Oct 29th, 2010 11:51 am
rear main seal - TBob K1200LT 3 Jun 4th, 2009 1:19 pm
Just a thought on rear drive failures. sodbuster K1200LT 10 Sep 11th, 2007 5:11 pm
