LED SIDE SIGNALS - BMW Luxury Touring Community
post #1 of 4 Old Feb 22nd, 2014, 8:35 am Thread Starter
LED SIDE SIGNALS
Was reading a thread covering someone who installed 4" LED light strips under his turn signal lenses for better visibility when whenever the lights were on. Can I safely do this except wire the LEDs to activate whenever the turn signals are on for better side visibility? I would used white LEDs and my original Amber Lenses, for the correct amber color. Thanks, Donn
dgfolkmann is offline
post #2 of 4 Old Feb 22nd, 2014, 8:54 am
gbaltyn's Avatar
Re: LED SIDE SIGNALS
It's doable but you will most likely need to add resistors to trick the electrical system in omitting a fault and getting the fast blinker. I added red LEDs under my OEM LT mirrors so those next to me can have another hint of my intention to change lanes. Looked up the formula on line, took a trip to Radio Shack and soldered directly into the turn signal wires to work. I was considering another set to help with on coming traffic so let me know how this turns out for you.
gbaltyn is offline
post #3 of 4 Old Feb 22nd, 2014, 3:58 pm
If you just add the LEDs in parallel to the original bulbs (and keep the bulbs) you need do nothing more.
post #4 of 4 Old Feb 23rd, 2014, 8:25 pm
Actually there is a lot of space in the front turn signal housing for LEDs. I have put a strip of 5050s in the reflectors on the saddle bags. So you could put more and larger LEDs in the front. If you connect the positive lead to any ignition activated hot and the negative to the hot lead of the stock signal bulb the LEDs will act as running lights normally and then wig wag turn signals.
Buff8stuff is offline
Low Side Crash - Need Advice big_ed K1200LT 35 Sep 2nd, 2011 11:18 pm
right side turn signals not working. sheldan2 K1200LT 15 Jun 11th, 2009 7:16 am
Leaking Side Cases captron4601 K1200LT 0 Jun 4th, 2009 9:01 pm
ABS lights flashing side by side jac K1200LT 15 Aug 14th, 2007 5:03 pm
