Increase Clutch Spring Pressure - BMW Luxury Touring Community
post #1 of 12 Old Feb 22nd, 2014, 7:37 am Thread Starter
Enjoy The Ride
saddleman's Avatar
Now that I have replaced the clutch & have a better understanding of how the clutch slave cylinder works with the clutch diaphragm spring I think you can increase the spring pressure to compensate for the clutch disc wear.
I think if you install shims between the clutch slave cylinder & the transmission to compensate for the clutch disc wear you can gain the lost clutch diaphragm spring pressure back. You could stack the BMW 23122352156 gasket or make your own thicker gasket. Gasket material is available in many different thickness sizes.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #2 of 12 Old Feb 22nd, 2014, 8:33 am
Re: Increase Clutch Spring Pressure
You think the slave is actually taking some of the spring pressure when the clutch lever is released as the clutch wears? That would be an stunningly stupid design if it is the case.
post #3 of 12 Old Feb 22nd, 2014, 8:52 am Thread Starter
Enjoy The Ride
saddleman's Avatar
Like most hydraulic clutch systems there is no adjustment for clutch disc wear.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #4 of 12 Old Feb 22nd, 2014, 8:58 am
Did you measure or get a sense of how much preload pressure is present? Are you suspecting excessive pressure is held against the pressure plate? I know on all the vehicles I've worked on with hydraulic clutches (many), there is preload when installing the slave cylinder, but it's abated by the fluid returning to the MC. Steve
Steve_in_Sunny_Fla is offline
post #5 of 12 Old Feb 22nd, 2014, 9:41 am
the piston in the slave sits in a different position when the clutch is engaged as the clutch wears, the only issue is if the piston bottoms out and therefore could no longer allow the clutch to engage. As JZ has said the fluid will rise in the master as the clutch wears exactly the opposite as the brakes where the fluid level goes down as the pistons stay further out when the pads wear down. Hydraulic clutches in cars - fluid in reservoir goes down as clutch wears. The K clutch is fairly unique in design.
the adjustment in both systems is the amount of fluid between the master cylinder piston and the slave piston when the system is at rest
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #6 of 12 Old Feb 22nd, 2014, 9:55 am
Most I've seen were like disk brakes. The "adjustment" is the fluid level in the master cylinder.
post #7 of 12 Old Feb 22nd, 2014, 9:58 am
Exactly. That was my comment about a stupid design if the slave piston reaches end of travel and is thus always carrying load from the diaphragm spring.
post #8 of 12 Old Feb 22nd, 2014, 10:05 am
!0-4, same as an automotive style diaphram or finger clutch. Still, Is JZ's contention that the clutch is still serviceable despite having reached a disc thickness that causes the slave to be fully compressed ? Steve
post #9 of 12 Old Feb 22nd, 2014, 10:57 am
highly unlikely unless the engineers were asleep during design, once the disk hits minimum it is likely prone to slipping, personally I think the spring could be
stronger but ease of use and clutch bite are a trade off, if they had put a larger diameter slave on to compensate for a stronger spring would have required a larger master to move enough fluid to disengage properly - you would feel it with the left hand
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #10 of 12 Old Feb 22nd, 2014, 3:38 pm
In my case the slave was not bottomed out and the disc was still "inside" the wear limit but close to the edge. All my slip was caused by disc thickness being so thin (and a tiny bit of engine oil from the o-ring). This was always a 5th gear forced slip that could only be done once per attempt interval of 20 minutes or so before I could induce it again.
While I don't disagree with Dave's assertion, I don't think there would be much to be gained by shimming the slave. I believe the spring has a finite limit to what it can compress on disc thickness, slave or no slave present.
post #11 of 12 Old Feb 22nd, 2014, 6:31 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
All I know is that my disc was .010" from the wear limit & it would not engage until the clutch lever was released. I think if I had shimmed the slave cylinder out I could have changed the point that the clutch lever would start to engage the clutch disc & prevent some slipping.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #12 of 12 Old Feb 22nd, 2014, 9:08 pm
If you try, let us know. I think the shims would just change the fluid level in your master cylinder as it accommodates the shims. Now if the piston is bottoming in its bore before the disk spring has applied its full force, then I agree that shims would help. I just can't believe BMW got the design that wrong, but anything is possible!
I fought the clutch and the clutch won. Slammer Chit Chat 3 Apr 15th, 2013 12:56 am
Took the clutch and housing out today. airplane K1200LT 6 Nov 15th, 2011 12:03 pm
OH NO! not another clutch thread jdunique K1200LT 5 Jan 26th, 2008 9:16 am
Clutch failure sonnata K1200LT 12 Aug 14th, 2007 11:19 am
Clutch change (very worn) picture pcra K1200LT 3 May 7th, 2007 4:51 pm
