Hypro Springs Help - BMW Luxury Touring Community
post #1 of 10 Old Feb 22nd, 2014, 5:48 am Thread Starter
Defaoite's Avatar
Hypro Springs Help
I am replacing my suspension springs with Hypro springs.
I made the spring compressor as described in the forum and it works very well.
Can someone describe to me how to remove the retaining clip from the rear shock.
I have removed the grub screw on the preload unit.
I can see the retaining clip, but no matter how much I compress the spring I canít seem to get at it.
I have compressed the spring about 50mm below where the grub screw was,
do I need to go further ? Any help.
May you be in Heaven half an hour before the Devil knows your dead
Defaoite is offline
post #2 of 10 Old Feb 22nd, 2014, 7:57 am
Scouter-50's Avatar
Re: Hypro Springs Help
Can you see enough of the wire retaining ring to get a pick under it to pry it out of the shallow groove? If not then the preload adjuster is not pushed down the shock enough. If the grub screw is dragging or if the preload collar is stuck to the shock body then you will compress the shock. the preload adjuster has to slide on the shock body to be able to get to the ring. Post a pic if you can.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #3 of 10 Old Feb 22nd, 2014, 9:47 am
as Robert says mine was sticking and I had to manually pull on the top shock mount with spring compressed to get at ring
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 10 Old Feb 22nd, 2014, 1:56 pm Thread Starter
Defaoite's Avatar
Thanks so much guy's - spring removed - once you do it, it seems so easy.
Defaoite is offline
post #5 of 10 Old Sep 10th, 2014, 1:15 pm
Orcak12lt's Avatar
Hi,
I'm new here. I bought an LT this year and I'm ready to change out the springs to Hyperpro. The shocks are off the bike and I haven't found a shop that can do it or which I trust. I would much rather like to do it myself as I do my own maintenance. If someone could either sell me the spring compressor or let me borrow one (for both front and back) I would very much appreciate it! I'm in the Midwest.
Robert
Orcak12lt is offline
post #6 of 10 Old Sep 10th, 2014, 4:40 pm
bowdon's Avatar
Orcak12lt;
Thanks for the PM, if you do a search for "hyperpro springs" you should get a few pages and there are photos and drawings of the "homemade" compressor quite a few of us made and used.
You have some reading to do!!
Easy job for the rear, but the front is a little harder and longer to do but what a difference in the ride after the change!!
Good luck,
Regards,
Bowdon
Originally Posted by Orcak12lt View Post
Hi,
Robert
bowdon is offline
post #7 of 10 Old Sep 10th, 2014, 7:10 pm
Scouter-50's Avatar
Hi,
Robert
Robert, here's a drawing I made of the tool. It will probably be about the same price to have one made as shipping both ways. I am willing to ship you mine. You might look at a local shop plasma cutting a plate or possibly water cutting the same to these specs. Let me know, Robert.
File Type: pdf K1200LT Shock Spring Compressor Top Plate.pdf (23.2 KB, 99 views)
1981 R80GS
1976 R90S
post #8 of 10 Old Sep 10th, 2014, 9:23 pm
GaryEm's Avatar
Just start out by putting a Yacugar or Ohins on the rear big differs no bottom out and a big variable in your shock adjustment so you never have stiff ride or to soft of a ride just giving you a nother choice
Gary
2003 K1200LT
GaryEm is offline
post #9 of 10 Old Sep 10th, 2014, 11:56 pm
Orcak12lt's Avatar
Thanks for the replies guys. If it was winter I'd tool one up but seeing as the bike is apart and I'd like to do some riding soon and try out my new Avon Storm 2 tires ( the Metzlers were like using 2x4's in the rain), I think I'll opt for borrowing the tool. Robert, I will pm you my info. Thanks.
Robert
post #10 of 10 Old Sep 11th, 2014, 11:25 am
cwarren's Avatar
That's what I think too! Once Robert (I mean Scouter) replaced my springs, it seemed very easy for me (to watch him).
Chris W
Current
'14 K1600 GTL
Previous
'09 HD Fat Bob
'07 K1200 LT (gf misses it)
'01 Triumph Sprint ST
'79 Suzuki GS1100E
cwarren is offline
Shocks & Springs or Springs Only? JNW003 K1200LT 17 Jul 6th, 2014 10:31 am
HyperPro Springs deputy5211 K1200LT 25 Mar 26th, 2013 10:25 am
Hyperpro Springs - Huge difference! hallzee Shocks and Suspension 2 Dec 3rd, 2011 10:14 pm
Hyperpro springs installed over stock shocks kellenbenz Shocks and Suspension 11 Dec 2nd, 2008 9:44 am
Feeling a little chill tonight? Try hot springs pjessen Chit Chat 0 Feb 5th, 2006 11:42 pm
