Dagnamit...! - BMW Luxury Touring Community
post #1 of 7 Old Feb 21st, 2014, 9:01 am Thread Starter
Brianmered's Avatar
Dagnamit...!
Pulled the tupperware and successfully fitted and wired in calliper motolights. Put it all back together and wouldn't you know it, windscreen doesn't raise...not sure when it stopped working as I hardly ever use it. I like to wash the bike with the windscreen raised as it's easy to get access under the screen for drying.
Where do I start, apart from the fuse which I have already checked. I am worse than useless at electrics....
Brianmered is offline
post #2 of 7 Old Feb 21st, 2014, 9:26 am
Re: Dagnamit...!
Darn, I wuz gonna tell ya to check 'both' fuses relative to the windshield adjustor (one for the switch 4A and one for the adjustor motor 15A as on my '99), butt just recalled that you have a 2007 LT and I don't know the fuse layout for that model year. Just check your fuse list close and see if there might be two fuses for the 2007. Stay tuned for an electric guru, coming up!
post #3 of 7 Old Feb 21st, 2014, 10:43 am
Re: Dagnamit...!
if you do not use it much likely the 4 pivot pins are seizing, have you tried helping screen to move manually while pushing button to raise, if it goes up and down with help lubricate the pins
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 7 Old Feb 21st, 2014, 12:39 pm Thread Starter
Brianmered's Avatar
Re: Dagnamit...!
Thanks Dick...I don't have my manual with me at the moment so I just went through all the fuses to be sure. I thought there was only one 15 amp fuse but I'll double check them all again to be sure. Didn't know about the 4 amp switch fuse.
Gary, I read about maintaining the lifter arms and did WD40 the pivot points while I had the windscreen off but it all looks as good as new....I tried a helping hand but to no avail.
post #5 of 7 Old Feb 21st, 2014, 12:51 pm
Re: Dagnamit...!
It is a 7.5 amp F6 on the 05 and up units vs. a 4 amp.
post #6 of 7 Old Feb 21st, 2014, 1:35 pm Thread Starter
Brianmered's Avatar
Re: Dagnamit...!
Thanks Wrencher Extraordinaire, that's worth knowing...
post #7 of 7 Old Mar 2nd, 2014, 12:59 pm Thread Starter
Brianmered's Avatar
Re: Dagnamit...!
The good Lord smiles on the righteous....wife and I went for a last spin before she (not the wife) gets crated for her trip to the UK. Tried the windscreen switch and lo and behold it worked. Can only think that I was too generous with the WD40 that I sprayed onto the lifting mechanism pivots and it somehow got into something it shouldn't have!. Anyway good news is I don't have to do anything with it when it arrives in Blighty.
